Btw, our new Eagle Eye friend has a great deal on the X6R, even cheaper on the mobile app
Wow, that is a great deal on the X6R... They have pretty good deals on the other Eagle Eye's as well, including a X6 with an XP-L HI, A6 hosts, etc. Not many pieces sold of anything though - pretty new store, Mr. Eagle eye...
Here is a better ref: https://learn.sparkfun.com/tutorials/voltage-dividers. You can plug in our values for R1 and R2 and see what you get. I believe if you have a 5V source coming in, you need to scale it down to match against the 1.1v reference source.
For our use for LVP now, we want to measure 3V against a 1.1v ref source, so, we use 19000 ohm R1, and 4700 ohm R2, so resulting voltage is 0.59v, which is just a little over 1/2 of 1.1v, correlating to an A-D value of about 130, but have to subtract out voltage for the what the diode takes, so we use a value of 120-125 or so.
To detect the 5V source's presence, maybe a direct wire would work, and maybe it will read 0 or 255 if present, dunno.
If it read 255, wouldn’t that be perfect? It doesn’t need a precise reading, just needs to be able to tell charger vs no charger.
If I test it, 5v direct to that pin isn’t gonna fry it, is it?
Could we not really assign star 3 to any input to that pin would turn off the output?
Have our firmwares used all the pins or do we still have one left Empty?
Might be one pin free. Dunno bout the 5V going direct in, true, might be a problem, but 5V is within the normal range for these MCU's. I'm kinda learning as we go .
Blf-a6 is one of the most advanced firmwares, and it indeed has a a pin assigned to “star 3” as our fellow member already pointed out. Air wire straight from 5v input with a limiting resistor inline, then set the FW to PWM=0 whenever signal is detected on Star 3. Any reason why that won’t work?
My thoughts exactly
I just ordered my X6R yesterday, but I’ll try our theory when it gets here.
I ordered one last week keep up upto date I want to try this out as well. Thinking about using ATTiny45 for this build, thoughts?
Eagleeye=Rayus light.
Go for it!
My build is for my grandfather and will be a very, very simple UI. So i’ll be using the 13.
These ATTiny's have 8 pins: RESET, GND, VCC, then the remaining 5 pins are all I/O. Of the 5 pins, 2 can be used for PWM's.
So of the 5:
- PWM out (to FET or 7135's)
- secondary PWM out (if using a FET+1 driver) or available
- LVP in via the voltage divider circuit
- e-switch in
- available (or possible OTC with an e-switch, maybe?)
So for an X6R with e-switch, you could have 2 pins, 1 pin, or none available -- all depending, but none is highly unlikely, only if you use a FET+1 with OTC.
The RESET pin can be used for I/O but once you do that, you can't re-program with our usual $5 USB dongle - needs a special setup to clear it.
Thanks Tom. Looks like this should work for me, just need to figure out the specifics.
At least for my uses I don’t ever need both an OTC and e-switch. On dual-switch lights I want the rear to be only on/off so it can be a forward clicky and capable of signaling.
Hey Tom, would you mind doing some measuring for me? (My X6R is still in the mail)
I have been having fun playing with Eagle, so I think I want to try doing a drop-in driver that utilizes those pins.
If you are willing, can you measure:
- Diameter of the pins
- Space from pin to pin
- Space from middle pin to edge of the driver board.
- diameter of the original driver
Hhmm, got the light with me @work, but can't do much here with it. I still have the original piggyback driver though @home - I can work with that, then should be able to measure the main board that hold the charging circuitrly and switch. My 2nd X6R is on the way, think in the country now. Oh boy, hope I can remember this eve....
That’s fine. In the mean time, I’ll see if I can get everything else to fit. I was going to add a pad and resistor/diode/cap pad for pin 3, and a pad for your Fet gate-to-ground resistor. Or maybe I’ll forget those, and try to fit the attiny85 instead… we’ll see.
That’s the Ali store linked in this thread above:
Shenzhen jin lang electronics co., LTD
China (Mainland) (Guangdong)
First draft.
All it should need is for the pin size/location to be dialed in and adjust the ground ring around them.
- Single-sided FET+1*7135
- Footprint for ATTINY85V-10SU
- Same pinout as usual
- Maintained at least 1mm “keepout” around the outside
- 2.2mm drill pass-through for LED+ (also standard LED+ pad)
- Pad and series resistor (to connect to the charging circuit so the MCU knows when USB is connected)
- Pad for resistor on FET between PWM and GND
That is sweet. I was planning on designing this very board myself but I’m still in the VERY early stages of using eagle.
This board has everything! Nice work!
