Back when I was driving a cheap Chinese scooter to work every day, I had bought a lot of these 12V LED automotive bulbs, and the variety you showed as your first attempt was the only one I could find that worked well. I’ve tried several of the various bulb styles available, and this style was the brightest, by far, with good output pattern to work well in automotive reflector fixtures. I was concerned about heat, especially as these are enclosed in a module with no air circulation, and are used constantly while the vehicle is operating, but I never noticed any issues. I’m still using one of the bulbs in my newer bike as the main brake/taillight bulb, and it’s still going strong.
When I bought these, I was trying to free up enough surplus power in the weak charging system to let me upgrade my headlights. The factory bulbs were the Chinese style 35W bulbs. By replacing the factory cluster, brake/tail, and signal/running lights, I freed up enough wattage to upgrade the headlights to automotive H4 45W bulbs which made a huge difference. For about another month of use before the main crank bearing died, effectively killing my brand new bike after six months of use and only 5000 miles. |(
i put a luxeon altilon 1x4 in each of the reverse lights of a 71 olds 442.the lights are metal and can take the short term heat.at 1a each thats about 900 REAL lumens.EACH!it looks like daylight behind it in reverse.
i thought of a switch to flash them to back off tailgaters.the bare led is nasty to look at directly.the lense softens it a bit.
Kind of crappy picture comparing stock w16w bulb and “50W” ebay led (link above in my previous post).
It’s hard to notice any big difference, except for the tint.
Whooaaaa. Thanks for these pics. You even got me interested in this solar light! This read led light looks hella bright. Just what I might need! Is it just a remove and replace bulb or is some modding needed? Any heating issues? Re-reading the thread meanwhile for answers!
In the manual of your car you can find out what type of bulbs are used.
The led “bulbs” are avaliable with most types of fittings, but some led bulbs are larger than the standard car bulbs.
It always looks brighter on a photo because the lightmeter in the camera tries to get the lighting of the photo as correct as possible.
If there is not mucht light, the shutter stays open longer.
But the led reverse lights of my Dacia are pretty bright now, much brighter than the 21W bulbs.
I tried a couple LED “globes’ originally. YUK.
Waste of money.
Spent $35. bought a pr of 6in small LED bars, centre beam. outers spread.
Good for 30/40 yds.
Left originals in, with a dash sw to others.
Backing in dark, nobody around. It’s near daylight for 40yds back.
Anybody around. just use std. no problems.
