I love the UI for this light. Would not want it for a smaller tail switch like but I think is brilliant for a forward switch turbo centric light like this.
Oh, I think I misread blue8llz UI. I am a person that likes to Click to change modes, rather than holding the switch.
I actually like having a Clicky at the back for complete power off, and side switch for switching between modes. (but that wont work with the meteor)
Double click to Turbo, Long press to Low. normal click to cycle through modes.
I’d love to put my code on this light. I looked into what it would take though, and there’s an awful lot of twisty assembly code with comments only in Russian. And its author warns against anyone modding it because it apparently “fails open”, meaning code bugs could cause explosions.
But if I could, I’d like to run an improved version of my ramping UI on it.
While off:
Single short press turns light on in last-used mode.
Double click goes to turbo.
Long press turns light on in lowest mode. Keep holding for a few seconds to enter or leave lock-out mode.
While on:
Single short press turns light off.
Double click goes to (or from) turbo.
Press-and-hold ramps smoothly and pretty quickly until button is released. Release and press again within a second or so to reverse and ramp the other way.
… and probably some extras, like for triple click.
It’s a nice light but the problem is that manufacturing small quantities of high quality product will always be expensive, that custom made noctigon MCPCB is not cheap for sure, more stock parts you use cheaper it gets…
Well originally it was going to just be a single run of 300 flashlights. But word recently came out from RMM that Hank has a second run in process that should be out in a couple weeks. This new run also contains the new tan body.
Ok so now that I have a Zebralight, it’s very similar in its layout. The Zebralight is fairly straightforward, but I’m also not a big fan of the quick press instant turbo. That said, it’s still a nice light. I like the meteor, but it isn’t the UI that’s keeping me from buying it. I can live with it. It’s really the price. Not that it isn’t a great value.
maybe if enough people vote , there could be a possibility that a more simplier meteor ui will actually get produced.
so far there is 31 people that they will consider buying it……im sure there will be alot more if it really became a reality. not everyone posts here.
If I understand correctly, the M43 driver doesn’t actually make true smooth ramping possible. It sounds like it has several different power channels at different levels, and distinct visual differences when it changes the channel. I think. I’m not sure I understood everything with the browser auto-translating from a language I don’t speak.
Anyway, it sounded like the ramps between levels aren’t actually usable as regular output levels, due to hardware limitations. The earlier versions seem to have a fair amount of discussion about hiding this limitation, minimizing the visual glitches between levels, etc. So a true ramping UI might not be feasible without driver hardware changes.
I followed this thread and took notes, specially from blueb8llz and TK. I implemented a ramping UI in Narsil, still needs some tweaks and testing, but almost there. See this post in the 25/45/85 thread:
It is a smooth ramping implementation, but not all finalized yet. Might still add a dbl or triple click to get direct to hi/turbo. Not sure I'm content with a 3 sec ramp - 2 secs might be too quick to stop where you'd like, thinking of about 2.5 secs.
