Here's a picture of the board in the "deworld" charger from Radio Shack (mentioned above as a suggestion).
I haven't figured out some new trick about making flickr pictures appear, it used to work straightforwardly; educate me by PM, anyone
Curious if this is enough to identify any useful information about this. It seems to terminate (or trickle?) -- at 4.21v (light changes from red to green).
I have posted some basic info and teardown of the ML202 here:
About the ML-102 V9.0 I can’t detect any significant difference with my V8.0 other than a sightly more stable USB output, charge current and termination seem to be the same.
It’d be nice if you could make a graph for the ego output. I have a sneaking suspicion most ego USB-powered chargers people use are terrible (IC in pic is an LM324) and the Nitecore could be a reliable alternative that I can recommend.
Hi HKJ. Do you have experience with this charger? The physical quality is good, but I’d like to know if it would be safe for unprotected high drain cells… if so, it would be a great ‘gift’ charger.
Ok. thanks!So they are not software related….
My NITECORE i4 exploded last evening, so I’m looking for a better replacement and the usual suspects are always the same Lii-500 and C3100, I like haveing 2A but not the PWM, but also having a decent impedance meter is nice, without to have to use my hobby charger
nevermind, i will flip the coin and decide if the (pwm) OPUS is worth the price 50% more of the (linear) Lii-500
