Thats the proper way to do it . I usually just take out my socket set ,find one that fits inside the bezel and use it to trace a circle , Carefully cut it out and stick it on the outside of the lens .You want to do a pretty good job so you don’t have any light leaking around the diffuser .
I now have this on my BLF A6, the one I have an XPL HI swapped in place of the stock emitter. The previous hotspot is now well blended into the edges of the beam. It really does give a good smoothing to the beam profile.
You swapped out the stock emitter for a XPL HI (tighter spot, more throw) and then negated your efforts by affixing DC Fix to the lens? (obfuscated spot, more flood)
Tell me how that makes sense, please. I don’t understand.
Any info how much heat can this thing take? I would like cover some spotlights around the house running from mains voltage. It’s probably not designed for that kind of abuse.
It is a V3 2D XPL HI. Better tint than the blueberry infused stock 1A for starters. The “increased throw” is just a bit tighter hotspot, it still has that now, but the edges blur into the spill. It does cut the throw some, but still better than stock….
Not to mess with you, but all this is for experimentation anyway, sorry to leave you scratching your head at my follies.
I am contemplating a hole in the center of the DC Fix to see what that would look like…
I will have to look for one of those hobby stamps or cutters that cuts about 1/2” circle with jagged edges. I think that it will be hard enough to line up on center, but a jagged edge should minimize this somewhat…
I will post pics if I do this, but I do not know if I will have time.
In a reflector light, the hotspot comes from around the edges and the spill from the center area. You would be adding a little spill, possibly, and a few new artifacts to the otherwise smooth beam profile, and not much else. If you really want to play experiment, instead of having a hole in the center of the DC Fix, you could add another color to the center to replace the rainbow effect that Cree forgot to install into the XPL’s.
Anyway… So, are you saying that the difference of a tighter hotspot that you got from changing to the XPL HI is bigger (stronger effect) than the difference in the other direction that you got from putting DC Fix on the lens? I’ve never used DC Fix, so I’m trying to learn about it.
Yes, I switched the DC Fix lens to my Eagle Eye A6 with a Nichia 219C and the flood is more than with the XPL HI on the BLF A6. I like the profile of the EE A6 with the DC Fix more, it is not as bright as the BLF A6 and makes a great flood as well as a more neutral tint.
Like I said, the XPL HI with the DC Fix was good, and still throws about like a regular XPL, with a brighter middle and less defined (but still brighter) hotspot. So the DC Fix is not a total wash for throwers either. I may order an extra C8 lens to experiment with…
I really like the DC Fix on the optic of my DQG Tiny III 18650, now it is a flood…
Ok, I tried this with one of my headlights. It’s a 3xAA Rayovac that I like using for close working. It has a TIR lens, but it’s got a really/ugly-shaped beam and very bright/distinct hotspot.
My wife cut a piece of the DC-fix to fit over the TIR, and I just peeled the backing off and stuck it on the front of the TIR.
The beam is much “nicer” (no more ugly shape and weird artifacts), and the hotspot doesn’t seem as intense as before. I still can’t use it on high mode for really close up work, but the medium is very useable now.
Many Thanks once again for “Bulk Buying” this for us.
Been wanting to try some of this for ages!
I ran a quick test with a Lucky Sun P26650 I had modded (warmer tint LED on Noctigon, and 105C driver), and diffusion-filmed as I wanted a more “spill” beam, and used some generic privacy film for house windows, purchased off eBay.
Readings off light meter at 1 meter using old film were:
Low 03 Medium 09 High 24, and This Film:
Low 05 Medium 15 High 43,
so (if my math is right) +67% for Low and Medium, with High +75%
Good result and still has slight “hotspot” definition with great “Spill” too. I’m Very Happy with the results.
Thanks for the info splott. 75% better than your old generic film is impressive …This just reaffirms Selfbuilts numbers .
i did some quick seat of the pants tests on two BLF A6’s
- Stock light at 36” inches off the floor the edge of the spill hits the floor at about 4 and a half feet
-With DC-fix
it hits the floor at 6 inches
increases the flood so wide i’m always blown away .
perfect for headlamps .
I use diffuser film on lights in place of lanterns or a traffic wand diffusers because they cause way too much glare .
diffuser film is much easier on the eyes .
