Please test the Vapex AA 2500mAh low self-discharge Rechargeable batteries
On order
I do only have a few NiMH in queue, but I do not know when I will test them (The test station is used for chargers at the moment).
Efest IMR 3000mAh.
I think… That all the 3Ah rated IMR batteries we are gonna see from now on should behave very similar to the 30Q
anyway…i do not know if HKJ has the necessary stuff to test 200/400A peak currents but it is now few months I’m intrigued by this
Hi!
If possible, could you review one of these: http://www.banggood.com/9V-800mah-USB-Lithium-Rechargeable-Battery-p-986563.html ?
I think it’s an interesting concept and 800mAh wouldn’t be too shabby for a 9v battery.
According to the reviews on the item @ banggood, you get about 300mha to 400mha depending on how low volt your 9v equipment works at. Not bad but it is not 800mha.
I ordered that battery a couple of days ago. I forget to turn off my dmm sometimes, draining batteries in vain. so I hope this battery will work in my dmm.
I’m still curious about red trustfire imr-batteries also.
Just seen you already have tested the 10180 battery for DQG SPY/HOBI
I’m curious because with my charger @50mA charging current , but also with the specific DQG charger for micro usb, i never pass the capacity is ridiculously low… And I mean ridiculously
Tested the blue and the white version… Both are pathetic in the same way.
I am thinking about added 9V batteries to my testing.
I have tested them, they are in the "ready to publish" queue, but I do not know when I will publish them.
Some update and more info about the brown Aosibo 2600mha 60A cell from Mooch
Thanks to light-wolff for posting the link about the Aosibo in another thread, i don’t check out vaping forums for cell info frequently.
And you guys should read Mooch’s review on the Brillipower 40A 3100mAh 18650
Another rewrapper who fake specs & even make a fool of themselves by questioning the result while showing big holes in basic understand about how cells work…….scary stuff.
I am glad i am not a vaper because it seem it is the wild west out there in rewrapper land & most seem to target the vapers with inflated max amp ratings.
I’d like to see these batteries tested King Kong 26700 5000mah http://www.mtnelectronics.com/index.php?route=product/product&path=59_108&product_id=312
They’ve become my favorites for lights that take the length. Getting good run times and great amp reading as opposed to other 26650’s.
Please test the Kinoko high drain IMR10440 400mha cell
According to vinh they “seem about equivalent with my testing” to the Efest IMR10440.
But who knows maybe they are of updated chemistry, it was years since Efest released the IMR10440. And a lot has happened in performance in all the other sizes.
At least this means another producer of IMR10440 cells and that hopefully means more availability of good IMR10440 cells.
Maybe they are the same as vinh says, and Efest had some form of a few years exclusivity agreement on the IMR10440 cells, from whatever factory makes all these various Chinese made lithium cells that shows up with the same base cell at the various rewrappers.
I would request these batteries to be reviewed, high capacity at a good price (and sanyo)
https://www.fasttech.com/product/1905300
Wolfdog1226 - The easiest way to locate an overseas seller is on ebay - and select a filter that is not in USA, then search for your item, and look for seller's location, find someone in Europe for these items. Also - these are high drain batteries, really not suitable for flashlight, more for vaping.
-LG HG2 IMR 18650 3000 mAh20A Ebay Link Here
-AWT IMR 18650 3000 mAh 35A Germany Ebay ( comes from US) but still good price w/ free shipping
- Samsung IMR 30Q 18650 3000mAh 15A Note INR ?? Same shipping as above
I have tested the AWT cell and the other I have ordered from other places, the shipping from your links are about the same as the batteries.
I would love to see a review from you for the new Fenix ARBL18 (High-Capacity 18650 Battery - 3500mAh) and the Fenix ARB-L14-800 14500 Battery.
I guess you do have a big queue for 2016 already (and maybe 2017…?).
Wondering about the claimed “PTC cathodal block protection”. The “3500mAh” cells I know (NCR GA, SDI 35E, LG MJ1) all have no integrated PTC. Does Fenix add a PTC at the cathode (the PCB is at the anode)? Or is it neither of these 3 cells? Looks like someone should do a teardown.
I will consider them.
Not really.
I have a few left from last year, then I have all the new high capacity cells and last I have a large pile of Efest cells.
I do also have a couple of tested cells that is not published yet.
I think, Panasonic, Sanyo and all the others are cheating on us.
They sell theire 3400mAh batteries for 8-10$ - but Ultrafire sells 9900mAh ones for ony a little over 1$ per cell.
