I just tested this with a KeepPower 18350 in my S2+ with one of RMM’s triple 219C’s from the recent sale.
I used a clamp on ammeter and some 12ga stranded copper (5 inches long) from negative on battery to side of tube.
I got 11.2 A initially, from an 18350…
I held it for about 10 seconds until it got too hot, it was down to 10.7 A
Holy smokes these 219C’s are awesome for pulling amps… That is about 3.5A for each emitter and according to Djozz’s chart in the OP, about 3000 LED lumen.
As for the heat, ten seconds was all I could handle holding it in one hand. I will have to adjust the firmware. With the XP-G2 S4 2B triple prior, I had it start to step down at 15 seconds, taking about 35 more seconds to ramp down to 50%…. That will not do for these little heat generators.
Yes, it will never be a pocket-rocket but it is possible. You will have to remove some resitances in your flashlight, mainly bypassing the spring(s), then the 219C should run at up to 1.5A direct drive on a LiFePo. I like LiFePo's because the chemistry is relatively safe. :-)
I looked at HKJ's test of a 14500 LiFePo cell and compared the currents/voltages with the 219C current/voltage and that comes down to a bit over 1.5A, ignoring any resistances in the system. A 18650 size LiFePo cell should do a bit better.
Well this is interesting, I had not considered that LiFePO4 cells would be good for DD until reading this. Would be interesting in the Noctigon Meteor M43 that Richard had with the 219C… Plenty of light, pretty cool for the amount of light being put out and safer chemistry…
An old Illumina Ti LED/MCPCB upgrade mod to a 219C 4000K (Cutter):
Stock light did 241 lumens @30secs, 219C/10mm SinkPAD does 296 @30 secs in a much better tint and better beam pattern as well. Both tests were done on a EFEST 10440.
Yea, was think'n bout replacing the driver for sure. Actually I got another one I want to mod as well - might do with the 5000K from Richard. Since it's a contact board/driver design, should be perfect for our 2 sided FET based 10mm driver... Hhhmmm... I know I got a couple.
Also need to do something better with that alignment piece, and the contact board is not sitting down flat, so it's a little more flaky switching modes that it used to be. I left the tiny stock LED wires - might be ok with the low Vf of the 219C, but definitely could get more power and heat for sure out of a FET with heavier wires. Didn't have much time of course.
I am working on a Olight I3S & that Illumina Ti led holder & the pill looks identical, i wonder if Olight is the OEM for the Illumina Ti.
The biggest difference seem to be Olight used lots of threadlock + glued the driver well in place unfortunately, i have gotten the threadlock lose but haven’t attacked the glued in driver yet i want to test an XP-L on it before i have to probably destroy it to get it out
Good point about contact board & the 2 sided 10mm fet driver, the pill is very deep for something so small, i will have to see if the I3S also has that setup also, the pill should be deep enough for it anyway.
If you are going to test an 10mm fet driver in the Ti wouldn’t the alu pill very quick get overheated due to the bad heatsinking of Ti?
I guess you could use an very short turbo timer to save it destroying it self though.
I hope you try it, it is always interesting to see more hotrodded 10440 lights pushed to the edge
Did test the 219c 5k. The tint isn't very nice (not if you are used to the A or B series) Too flat (dull) and has some greenish/blue hue (that is the reason why it slightly outperform the 219b in term of lumens... "less red" emitted)
I’m not sure where to ask this… Has anyone done testing on the 219B V1? The tint is very nice in my BLF-348, and I remember having a talk about it’s Vf being the same as as the 219c, but I’m wondering about lumens and how much current they can take…
Finally got around to installing some 219Cs last night.
I installed two in small 1x14500 zoomies, and 3 more inside my Jetbeam TCR-01 triple. Previously all 3 lights had been running with Nichia 219B.
My impression: Not bad at all! All 3 lights are producing considerably more lumens than before. The new emitters aren’t high-CRI like the 219Bs I previously had installed, but they more than make up for it with the increased output. My TCR-01 triple with triple 219C and stock driver (not sure the about… my guess is maybe 2 amps), is producing a beam that is fairly close in brightness to a similar light with triple 219B and FET driver (both on IMR 18350).
I also like the low forward voltage on these emitters. Hopefully they will keep their max output in these lights longer than on the previous emitters or XPL HI. I’ve previously tried XPL HI in small 1x14500 zoomies at 3 amps. Output looks great initially, but they start to step down pretty fast as the battery depletes.
No, there is no test, many still confuse them with 219B (discontinued) and they will forever I assume since Nichia's specifications are still vastly not comprehended by most people. Yes undoubtedly you can check the datasheets and see the Vf is the same, but you know they will come in different Vfs bins anyway (3 bins: L1 L2 M1 , lower to higher voltage), so far the 219C is not disclosed as to what Vf is, by none of the sellers, so I would like to see a L2 vs L2 comaparison not something like M1 vs L1.
A few weeks ago I tried to order a few 4500K 90CRI V1's from illumination supply, asking them for cheaper shipping to Europe, but got no answer yet. If they ever make it to me I will do an output test. That only will give some information on one led, but it will give an rough indication of where the 219B V1 is situated between 219B and 219C.
I assume you mean the 4000K at Ilumn, not 4500K. Well you can get the other 219B-V1 from IOS, a few weeks sounds like a lot of time.
But anyway, even if the Vfs of the 219C and 219B-V1 are the same, that is, the voltage bins are the same, the thermal resistance is not the same, 219C being rated for a lower thermal resistance.
