patmurris,
Can you post some pictures of the pill? All I have seen are these.
patmurris,
Looks a good product, simple design with a good driver and LED.
patmurris does the light output vary much between 2 or 3 x 26650’s?
@Jubeldum: let me look into that… The pill has two tiny holes for tweezers to grab onto. Not comfortable, but a quick try shows it will unscrew rather easily.
@Rolz: it’s hard to tell… Tail cap current with only two cells reads 4.35A (see corrections below 3.6A). The cells read 4.1V. That’s just over 35W (see corrections below 29W). Still a very good number.
Can’t wait for more info. I’m definitely in for one of these.
Here we go:
An idea of the light size:
From left to right: Convoy C8, Convoy L5, Fandyfire XHP-70 and Fandyfire UV-S5
The pill:
Some measurements:
Inside diameters driver side: 24.5mm and 27.2mm (where the driver sits)
Inside depth driver side: 14.10mm
Outside diameters: 28.5mm, 31.85mm (threads) and 32mm
PS: you can see there are a few dings and scratches on the body. My parcel arrived with a sticker “opened by customs”… and the extension tube was loose against the light body when they packed it back. Oh well…
Please note the previously measured tailcap currents where wrong.
I was using an old and cheap DMM… and i was a bit suspicious of such good numbers. I just borrowed a more reliable DMM and here are the numbers:
- 3 cells x 4.05V: 2.3A = 28W
Sorry for the confusion and optimistic numbers. These are still very decent though.
Has potential. Whats with the Clown Branding? “Fandyfire” Really, so I’m assuming that Pansyfire was already taken then?
I got the unbranded version from Kai Domain. Its pill has a press in driver, it doesn’t have the screw in driver retainer ring.
If we can get enough interest going, Nitro can have a heavy copper pill made for us.
Can you venture a guess on the Lumen output? Does it have mode memory? This light looks quite interesting.
Fandyfire XHP-70 at DX http://www.dx.com/p/fandyfire-xhp-70-1-led-5-mode-3000lm-flashlight-with-memory-black-3-x-18650-410297#.Vj6RlF9Hb7o Claims to have mode memory.
White wall shots anybody? :bigsmile:
Can anyone check the lumen output please?
This seems like the perfect candidate for the next BLF Edition light group buy.
With a copper pill, copper MPCB, increased amps and better driver, it would be interesting to see what someone could finalize the price at after it’s all said and done. I know I’m probably not alone with not having any XHP-70 or MT-G lights yet.
I was led to this forum by a google search on this flashlight. I’m wondering if there is any more interest in a group purchase.
Cheers!
google for the Thorfire S70 - nice Light with great tuning potential and a good price available also!
Sorry for the late reply…
I’m just starting to put my first lux meter to use with ceiling bounces. Compared to other lights for which i gathered some measured output through reviews, i’m guessing it to be between 2000 and 2500 lumen.
BTW: i does have a peak followed by a rather steep decay… the above estimate is after it stabilized. Not sure the batteries (2 x Soshine protected 26650 5500mAh) or the driver is to blame.
Yes it seems to have mode memory.
Patmurris, I am about to purchase a Thorfire S70. And I’m wondering if you can give any comparison of the Fandyfire to the Thorfire S70.
Even if you don’t have a S70, I wonder of you would be willing to offer your opinions based on reviews and beam shots that others have posted.
Cheers!
Looking at the reviews, the Thorfire looks much better IMO.
Better design, dual switch, more modes, hidden disco modes, battery level indicator, better output, nice packaging, spare parts…
Now i want one too!
Haha! Thanks for your help!
Much appreciated!
68mm reflector is the same size as the trustfire sst90. This 68mm Large reflector is very nice for xhp70 led and the 3 cell host is great for 12v setup .Perhaps even direct driving a good xhp70 would give 4000-5000ish lumens with select protected cells and lots heatsink compound. With a dedomed xhp70 and a sst90 smooth reflector, this could be a cheap and easy direct drive beast thrower.
