In the age old tradition of BLF ... I bought a bunch .
Glad you guys are enjoying it . I'm thinking of starting a new affiliate shill program where anyone who sells 50 sheets gets one eighth of one eighth of an inch ..So get in on the ground floor here ..If you can get 5 associate shillers under you you will receive 1/16th of a sixteenth of an inch of anything they sell ..* Some restrictions may apply ......do not use if taking any other medications ask your doctor before using .If you have any rashes itching ,burning or headaches please stop using at once and call a licensed family therapist to have your head examined .objects in the mirror appear larger than they really are .Please remain seated until the captain has turned off the no smoking lights and thank you for flying Dc fixed wing airlines .....We will now return you to your normally scheduled program . This is truly an opportunity of a lifetime .
....Talk to an expert
Years of experience
Scientifically proven
Award-winning
Fast acting
Lowest price
Save money
Best value
Special offer
Cost-effective
Free consultation
Results overnight
Beat the system
Secret technique
Secret tip
Treat yourself
Limited supply
Offer ends soon
Act now....
I am still surprised that the others that have ordered this have not chimed in… I know it is not every ones cup of tea, but it would be nice to hear of others opinions.
Just used on on the Xtar H2 16340/CR123 headlight.
its a very narrow (especially for a head light) stock the CW emitter was not bad but I dropped in a 219C and then added the DC-Fix.
now, these very reasonably priced lights, are just right for CQL (Close Quarters Living) not a throwing light anymore but a small head lamp was never really throwy to start with.
Also soldering in there 219C emitters was about as small as I want to solder.
I got a letter in the mail a couple of days ago, upon opening it, I found several sheets of what appeared to be paper. After several minutes of head scratching, some pondering, and a little contemplation, I realized it was the famous DC-Fix.
Well now, I have a perfect candidate for the famous DC-Fix, an irritatingly spotty, and post dedoming ringy headlamp, containing one particularly filthy latticebright LED.
Thanks for the beamshots Lord Niksidor I’m guessing there is even less hotspot than the camera is showing . i’ve diffused a jacob A60 just for fun but never done a Lattice bright … thats a classic
Quite true, to the eye the hotspot is less discernable, but I suspect given the still fairly impressive throw that the intensity in the hotspot shown on the camera is a fair bit higher than the rest of the spill, even out at 175 degrees there is usable light, very awesome. Also a fairly noticeable color temperature shift, maybe 7500k down to 6500k, something I'm certainly not complaining about. That LB LED is gone as soon as my fasttech order arrives :evil:
Might as well de-dome it and see if you win the tint lottery … whats the worst thing that could happen ? it’s not like you’ll ever want to put it in anything else anyway
I need some of this on my BLF A6 Special Edition flashlights. If that works as expected, I might try some on my Nitecore P36. Pretty soon, I'll be putting it on everything.
My thoughts exactly, Hot de-domed last night with minimal tint shift. I don't know how good it would be for reading, but it would be awesome for driving. Increase peripheral vision, very safe, soon everyone will be doing it. :wink:
Received mine. Thanks a lot! It works great. Here the result of applying it to Xtar H3 (ignore the tint, white balance was completely off, it’s actually whiter with DC-FIX).
Before/After:
It looks dimmer because the spill is a lot wider now. There is a smooth transition from hotspot to spill to darkness.
Now I might actually keep the head lamp. It fixes both too tight and too bright beam. Have to wait for darkness to test it futher.
I never used dc fix on a jacob a60 …everything i’ve had prior to dc fix was non stick /no adhesive so the diffuser film on the jacob A-60 lasted about 3 minutes …I did it just to see if it was possible to make a laser tight beam floody other lights i’ve tried diffuser film on/or still have film on them are >>2 D maglite clone ultrafire mcu-c88 ,blf x6 eagle eye,tank 566,convoy s2 ,s2+,streamlight tasklight2L, 12-5mm uv light modded with a p-60 drop-in no lens so i used diffuser film to protect the reflector / emitter of the drop in . de-domed Supfire s5, O-pen clone ,again no lens so the diffuser film protects the emitter .2nd tank 566 nichia 219a, blf aay-4e xpg-2, tank 701ssc,. hugsby xp-2 , Sunwayman V20cy, BLF A6, nitefighter L1A headlamp … Some of these lights had beams so poor spreading butter on the lens would be an improvement …I’ve got some antique mods and some lantern mods that will need serious diffusin since the reflectors are made for incan light.
