I dont think it is either. I am starting to lean toward it being the layout on my board. I ordered some of yours and some of your components so I can try and pin down the problem.
I dug out a board I had of yours from a long time ago and it was still populated with mostly your components ( accept for some I had robbed) and it eliminated the slow strobe I was getting.
I needed a working driver with strobe asap so I did no other testing yet.
Ok, I am making some progress now.
I do think a dirty trace is part of my problem. Starting with the dual switch firmware.
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/view/head:/JonnyC/STAR/STAR_dual_switch/STAR_dual_switch.c
Your board with my components does much better. I still get skips or auto changes but it cut it by about 90% on the 2 cell board. ( even mine worked fine with the 1 cell setup)
Using your boards and your components reduced this further ( another 5 % or so), but i could still get it to change modes on occasion just by touching the end of the switch + wire with my fingers.
What I am wandering now is this. Do you think that I might be able to reduce that over sensitivity by changing the firmware a little? I see that there is a place where the amount of time considered to be a "long" press can be changed. How about if I changed what is considered a "short" press or a click to be a few milliseconds longer?
Do you know which line of code would need to be modified to do this?
EIDT: Also is there a rampdown function for the turbo timer on this one, I did not see anything to set it?
If you handle that in firmware, you’re probably looking at adding or extending some de-bounce logic. By default, it requires four 1s in a row before it considers the button press, but you can make that longer.
I still think that something is wonky. Firmware fix is just a bandaid for it. I would add some more capacitance to it and see what happens.
Also, that switch behavior with it unhooked is seen in a lot of drivers. I can often get them to change modes by touching the reset pin, even without any wires attached. Your body has enough charge sometimes to do some funky stuff. Try it with a real switch hooked up and make sure that's not the problem.
Your correct again. Using a real switch isolated by a rubber boot did complete the task.
It appears you may also be using better caps than I am. Since the switch issue was solved I did not try this on an e-switch board, but when I switched the cap I had on my board to an 11uf robbed from another it actually helped my strobe function issue almost as much as using one of your base boards. No idea why, but glad it helped.
Would you mind telling me what brand/part number of cap you use for these boards?
Also I think the FET your using might be different. Can quite read the numbers, but this is the one I use.
http://www.mouser.com/Search/ProductDetail.aspx?R=PSMN3R0-30YLDXvirtualkey66800000virtualkey771-PSMN3R0-30YLDX
As long as you mentioned it… I recently ran into an issue with strobe too. Strobe modes were actually making the driver reboot.
I thought it must be a flaky diode, or maybe C1 was getting overloaded, or maybe I had a weak solder connection… but no.
It turns out the issue was a weak spring. I guess going from zero to 100% FET in a single clock cycle was enough to literally knock the spring off the cell, for just long enough to interrupt power and cause a reboot.
I have used several different capacitors depending on availability. Regardless, you want a 10V+ at least X6S capacitor. X7R or X7S is even better. Preference should also be given to 10% instead of 20%. The ones I sent you are 16V X6S 10% Murata. I usually use Murata (Japanese made) but there are lots of good manufacturers; just don't buy Y5V capacitors or capacitors from unknown sources. The cheaper capacitors suffer from more DC bias derating, temperature derating, and their lifespan isn't as good. When you're building an expensive driver or light it's worth it to spend the extra pennies and get a capacitor that will go the distance.
Here are a few suitable capacitors.
I also use the PMSN3R0-YLDX and also the PSMN4R0-YLDX depending on the board and what I can get. There was a while when the 3R0 was unavailable so I had to buy some 4R0.
Thanks RMM. X7Rs on the way..
I was wandering if anyone knows, will this board work for both the 1S and 2S driver? The boards I use now have 2 different pads for the 10uf cap C1 and Cznr. I only see one spot on this.
A usefull mosfet update: i got my hands on AP1A003GMT-HF-3TR MOSFET lately (PMPAK®5x6, INFO HERE)
Using this one vs the default recommended i got steady 5-8% better high amps on both XPG2/XPL emitters
thanks for letting us know. Any hint where you got them from? I recently ordered the board vestureofblood posted above and all I am missing is the FET. not sure which ones/where to get them from.
Since you are in the US try MNT or Mouser( Element 14 aka Newark NEVER- bloody thieves they are), or Ali for the default ones
Those that i mentioned came from a local EU vendor but i am sure Mouser have those too, bought them mainly for their price…with the vat( we do love vat in EU, 22) and tax( 4.5) 52 cents/pc :bigsmile: …and they turn out good ones
Thanks Mitko! I'll be checking those out too. Sounds like a real nice bump for those high Vf LED's, I assume better than the SIR800DP.
Thanks Mitko
Can't locate those MOSFET's anywhere. The manufacturer, APEC, doesn't seem to be popular. Can't find them on Mouser or DigiKey.
Hm… strange, i posted those cause in Europe they are cheap( 52cents with our huge taxes) and good, was thining they would be an easy find in the US
At least we have something that cant be found in US!
P.S
I am on a night swifth making some of those atm btw, hunters got pretty active lately, maybe cause of the Xmass
Tom i have a question, do you also like me recieve every time those with a different minus contact area thickness?
Those on the photo got thick minus contact rings, sometimes my order comes with thin ones, sometimes even the contact circle is covered completely and i have to rework them
Mitko is this the version of the board your using?
Boy, I'm confused... I'm only using FET+1 drivers - wights v009 version, same one that the BLF A6 driver was based on. I really love having the single 7135 to have very efficient low modes.
Think what you (VOB) and Mitko have are FET only boards - I never ordered that specific board - I used to use the ones in the OP though. OSHPark support told me they've had these weird masking problems with wight's boards (a few) intermittently - they dunno what's causing it, couldn't explain it. I got a batch in once with pads covered, asked them, and they rushed out a new set free of charge, even though I could scrape off the contacts and salvage the bad ones -- OSHPark has great support, try them.
For the masking of the ground (I think you mean the outer ring?), don't think I've seen that specifically, accept the set of boards that came in that one time completely covered, but it wasn't this board.
Actualy that masking isnt that big issue….just asking, OSHPARK are quite good to me anyway
Yeah i am using mostly v44 cause most of my stuff simply dont need fet+1 drivers, plus i `ve discovered something interesting: some XPG2 emitters dont like FET+1 driver, for instance S2 1A from FT- i have absolutely no idea why
Hunters flashlights usualy dont have that low mode 700ma, max, battery check, things like that…ppl got annoyed with too many modes
But ofc i am using Fet +1 too, just not that often, like 6-7 monthly
Ordered Attiny 85s btw, have to try our your new firmaware
Thanks for developing it TOm, greatly appreciated
Thanks . Ahh - true, good point bout the simpler mode sets. For tail power switch lights, the high mode count and advanced features can be frustrating - for me it's more awkward to deal with than a side switch., though I'd still like to have 2 e-switch's.
Can't recall - was there any advantage to this PCB alternate layout vs. the one in the OP?
VOB - sorry, what exactly is the 1S and 2S driver, and what is a Cznr pad? Think something to a with a cap and/or zener - not sure. Couldn't answer your question cause couldn't understand it.
