Such high frequencies may not be a problem here, but for some circuits, interference is reduced by making more of the board copper, even where not needed for lower resistance. That is from the capacitance between the sides of the board. That also helps with heat flow. On the other, hand, narrow traces to the control unit might protect it with their resistance and possibly their inductance.
Yeah thanks for doing this PD. Very nice to get pre done bypass holes also.
Feels great you having taken the higher amp capable switch board to the logical BLF end game. As we realized with Daleās testing of the lighted version and his bypass of it, the gain is a possible little less than one % but if we donāt want lighted tailcaps in a build why not get a max amp one instead
And love the grin design, it grins just as much as i will when i put it to good use knowing that perfectionist pleasure that the switch pcb is pushed as far as possible, in lowering resistance and minimizing that precious volt drop to the high Vf cree led we all like to use in our brightest builds :bigsmile:
Fritz t. Cat had an interesting point above here about lots of copper in the boards, i think it is likely that these higher amp switch boards should reduce switch failures by being better heatsinks for the switches also.
Just a suggestion but the highest source current occurs at the fet so the most gnd vias should be there, next is the 7135 source, then the mcu, and lastly the voltage divider and OTC so the vias should be allocated accordingly. Most drivers seem to be designed with only led+ given high current capability forgetting that single sided drivers often need to get current to B- through the bottom of the pcb. Glad both you and Rich are paying attention to this.
Iāve caught up on adding links to the op. There are a number of projects out there on the forum that arenāt listed partly due to their prototype nature and also due to my reluctance to mine the forum for these things without their creators stated approval. If youāve posted something and Iāve missed it or wish something to be added go ahead and list it here or feel free to wack me with a pm.
A special stackup intended for a variety of high-power and low weight circuit designs. This service features a 0.032ā (0.8mm) thick PCB, and includes 2oz (2.8mil, 70um) copper. Thatās half the thickness of our standard boards, and with twice the copper!
Thin board, thick copperā¦imagine the current J)
P.S. Pilotdogā¦been watching your shares on OSHParkā¦wowzerā¦you are off the chain on designing manā¦great job!
Man this is sweetā¦ā¦ Same price as the original boards too! For drivers the thickness was fine, (but still an upgrade to the copper) but the half-thickness is fantastic for the tailcap boards. Iām ordering some right now!
A lighted tailcap controlled by a small MCU. Something like mashm did, but with one or two proper boards for it. Yeah, and while youāre at it, please add a smd-fuse as a short circuit protection like LegolasGT did. Yeah if we could have them all combined, would be neat, donāt you think so? But again, I was just joking around. Iāve yet to try out any kind of LTC, so which of your boards should I try?
I can draw a board in eagle, but I donāt know how to design a circuit. Mashmās solution is awesome, but I would need some help to do that. Iām not really sure what the point of the fuses is though. Seems like it would add a whole lot of resistance.
Of my boards, it depends how many extra parts you want to buy. I suggest reading the LTC OP and last few pages of the thread to see the newest stuff
Yes, thought that too. But I liked the idea of an additional safety feature for high-drain-unprotected-cells-power-build applications. I think he came up with that in combination with his 3,7V->6V 3A-out boost driver, maybe it made more sense in an electronics-way with that driver.
