All sold out: ReyLight Custom,Lumintop Tool AAA Copper. (Driver available)
Will the copper be coated or un coated? I would prefer un coated, but either is good…
Any updates on whether pwm could be increased? This light is going to be a nice one.
It uses current-control.
Yay, no PWM!
Yay, no Cool White!
Yay, High CRI
Yay, Copper!!!
Yay, Mode sequence LMH
guesstimations (assumes stock XP-G2 is 110 lumens and N219 drops brightness by 30%)
0.38 lumen low, 15 lumen medium, 77 lumen high
btw future product interest:
A twisty Copper version (ala Maratac), with the DelRey no PWM circuit and N219 LED, with 4 modes :heart_eyes:
Been wondering this too…hoping for uncoated…
I am awaiting this light with so many excellent features! And I do believe is has a GITD ring under the lens - yes?
Please Add me to list to buy one light. What’s the next step? Thanks. Jerry
I just picked up a stock CU Tool from the Post Office.
The stock CU Tool does have PWM on medium and low, same as the Maratac. The Tool modes are M-L-H 32lm, 5lm, 110 lm.
Note the BLF ReyLight version uses a different driver and mode sequence, as well as different LED than the stock tool Im posting photos of.
the clickie Tool also works as a twisty. The click switch is audible and positive click on and off. Changing modes requires a half press, that has no click sound.
No it does not go all the way to the first bend in the clip, there is a secondary bend. imo it IS very secure.
imo the CU Tool actually is MORE secure than the CU Maratac, because there is a little more body of the Tool, resting on the hat, so less front heavy. It is also easier to change modes on the clickie, while on a hat, as the twisty interface risks popping the clip off more easily.
The CU Maratac weighs 27 grams empty. The CU Tool weighs 33 grams empty… add 11 gm for an eneloop or 7gm for an ultimate Lithium
UNcoated
Yes there is a green O ring on the lens (GID very little, and not for long)
The Tool will not tail stand, as stated, due to the ears around the cap being too short. A split ring on the ears rubs on the rubber cap,
and a split ring through the hole in the pocket clip, rubs on the body.
Neither imo is ideal, I dont consider this a keyring light. Note that hanging by the split ring on the pocket clip means you can “quick release” the light from the pocket clip (unless you superglue the clip to prevent that)
I do LOVE the formfactor of the Clickie Tool, it makes me smile.
REALLY excited to get the ReyLight version with No PWM, plus High CRI LED.
future product idea:
a short tail cap to eliminate the clickie on the Tool, so it can tailstand and have a viable keyring option. (note the cap clip is quite long, the tailcap needs to be longer to allow tailstanding, something a Maratac wont do unless you grind the end of clip like I did):
I recommend the tail ring attachment design of the Thrunite, as also used on the Olight i3s:
Please sign me up for 2 pcs of this nice one. Love copper very much. Thanks.
Awesome.
Just received 2 ALU versions in the mail and I noticed* NO PWM* in any of the modes, Since lumintop already makes an ALU twisty, maybe it wouldn’t be that hard for them to include some copper twisty tailcaps?
Getting excited. You can throw in an 1w led and I'd still buy it!
congrats on your cool new lights, what LEDs do they use?
regarding PWM
did you try waving it up and down like this just arrived CU Tool with PWM and XPG2. Is your mode sequence MLH like mine? If so, you got PWM bro, and you dont even care (thats ok too, lol)
To get back on Topic
I think its AWESOME that the upcoming ReyLight CU Tool will have NO PWM!! :slight_smile:
And the LED will NOT be a cool white XPG2
And the modes will NOT be MLH
Rey Lights Is building us a Better Tool, for Less Money!
Happy Holidays :slight_smile:
Is a slower shutter speed the only thing needed to take a picture of pwm like that?
Both are 3 mode, MLH, and use an xp-g2. I don’t have them in front of me at the moment but you could be right, I only did a brief visual check…with lots of ambient light.
EDIT: Discussion of the original light is a bit off topic to the GB so I’ve moved the post one of the review threads.
Thanks jon_slider for the weight measurement :slight_smile: i have been wondering for months how much these things are going to weigh.
The easiest way I’ve found to check for PWM is to wave a thin white card rapidly through the beam, against a dark background. With this method, I’ve been able to see PWM up to about 20 kHz.
Here are a couple pics showing how it looks… first at ~500 Hz and then at 4.5 kHz:
Or, with a sensor (or an LED) connected to a nice DMM, the frequency can be measured directly. With this method, I can get precise speed measurements for everything I’ve ever tried (the fastest I tried was 31 kHz, and it worked well).
Thanks jon_slider
Those ball cap pics were just what I wanted to see. It looks like it’ll work great!
I would take one in copper :-), hold the magnet, change to keyring style that does not prevent tailstanding
Great images, fortunately we wont be needing to worry about PWM with the ReyLight Tool… Im really impressed with the package hes put together.
Looking forward
Put me down for a CU Tool please.
I’d like one too.
Thanks
I’m in for one, thx.
Which Nichia, what CRI?
afaik The N219c is only 80CRI.
Hoping we got an N219 a or b, with 90CRI, yes?:slight_smile:
Looking forward!
