I knew I’d said the dog’s name before, guess I have to rename him Jared.
JaredM got it first, Shadow is the dogs name. When he was a puppy he followed me around as though he were my shadow, so my son called him that… Daniel was 5 then.
SOOO, JaredM gets a neat little DQG Tiny 26650 that has XP-G2 emitters on 10mm Sinkpad’s and an FET driver with ToyKeepers 64 level ramping firmware.
With an Efest Purple 26650 it makes 5.97 lumens at it’s lowest, 1631.85 lumens at it’s highest. I don’t remember the emitters used, specifically, I’ll see if I can dig that up. They have a color similar to a Nichia 219 or a 3D Cree, nice neutral tint.
All 3 of these lights came to me from forum members. This particular DQG had the driver missing or blown, so I put the FET in it and redid the emitter mcpcb as it was aluminum if I can remember that right. The reversing ramping firmware makes it very neat, press and hold for moon, press twice from off to go directly to turbo. It also has last level memory, coming on at the level you last used wherever that falls on the ramp. I love this firmware, press and hold to go up… ooops! that’s too much, press again to reverse. If you pause a couple of seconds the ramp will continue in the same direction till it reaches top/bottom.
These kinds of things sound complicated in writing, this one is super easy to use and get used to, which is why I love it.
Jared, shoot me a PM and I’ll get this little DQG Tiny headed your way!
Dale…you talk too much but what you say helps us all out a lot. I’m building some pretty cool lights now because of some of the things you’ve discussed in DETAIL, lol.
