My Xintd X3, the biggest of all my flashlights and i like it a lot.
Count me in!
Here's a pair of BLF A6 Special Edition flashlights, flanking a ZebraLight SC62w. I just got the short 18350 battery tube for the A6, and now the SC62 is beginning to feel some competition.
Nice lights with high output and copper.
This is my favorite light and gets most of the EDC time
EagleTac TX25C2 with the following modifications
Cut down and polished clip and used blue Locktite on the metal ring nut holding the clip so it doesn’t loosen with use as it usually did.
XP-L HI V3 1C from Kaidomain, on 16mm Noctigon copper MPCB, love the tint! I centered it on the reflector with a modified plastic centering ring
Found a slightly bigger and deeper smooth reflector than the stock one on Kaidomain that gives it a slightly tighter hotspot for more throw
Lapped and polished the Base and the copper MPCB and used Artic Silver 5 for better heat transfer to the body of the flashlight
FET 22mm e-switch driver with Moppydrv multi-group firmware, mostly use it on group mode 11
Thicker silicon wires (20ga)
Solder braided the driver spring and also solder braided the tail cap spring to the aluminum tail cap to reduce resistance
I only run it on either a NCR18650GA or LG18650MJ1 3500mah batteries for added runtime
I definetly love this light!
Can’t help but to show my collection of lights given by a member here (djozz) (thanks again )
about 90% of his unused lights were my weekly lights that I use now.
What if I don’t have a camera? - I have 32 lights (4 are Olight), but no way to show you.
Yeah, I know that’s it’s on the Smart Phones too, but I don’t have (or even want) one of them either. - I Hate being bothered by phones, though I do have a magicJack just for my ‘family’ - VOIP.
I guess that I’m just too old and stuck in my ways to enter, but really think that the new S2 is cool!
So - Thanks anyway,
-Chuck
My lights: JetBeam WL-S1, Thorefire PF04, Lumapower Avenger RX (2 AAA configuration) and BLF A6 SE
Each is used in a specific setting and performs amazingly. The JetBeam is my favorite because of the amazing range of battery types it can take with no additional tubes.
knives. Another favorite is EDC is my S15 Baton Titanium which unfortunately I had to send in for no hassle warranty repairs.
currently my favourite edc flashlight :party:
I bought this from Sam’s before finding flashoholic support online, it was all tan paint with yellow accents. The threads were glued so the paint got damaged on the battery tube. The missing paint on the tail cap came off with the masking tape. The gunmetal grey is Solid Film Lubricant, a molybdenum epoxy in aerosol format that can be used to coat aluminum firearm receivers when the ano has worn off. So I thought it might work on the bare Al of a flashlight.
The driver has been replaced with a FET+7135 the emitter is dedomed XP-L V6 3D and it has C8 style reflector. Under the ridged collar is a usb port that can be used to charge a portable device or charge the proprietary 18650. I kind of have an idea for making it work with any 18650 but it might take some tweaking. As it is now the charging feature charges the cell reliably to 4.16v and outputs 5v @ 1A. The screw down collar actually sucks heat out of the body pretty well after I cleaned the threads and put a bit of thermal compound on them. It runs fairly cool on high and competes with any others of the same class for brightness and throw with an IMR. It’s not my favorite but I’ve grown kind of attached to it and can see having it for years. I might even just remove the gimmicky usb cca and just add more brass under the driver.
Works like a hundred dollar light now. But the s2 would sit better in my pocket
Does anybody see anything wrong with this picture? … no Olights!… :_( ive always dreamt of having one ever since ive gotten on board the blf. They are just d**n good looking! Currently my favorate is my Thorfire C8 but that could change real quick if I win this Olight. Good luck to all! Edit: i got thw picture to show up.
From the SupFire M6 Group Buy. Shown with homemade handle.
I’m at my parent’s home for a few days & so this is all I can find lying around
An old 4-7’s FL I had done YEARS ago.
A #’s ti Quark that I sent out to have beadblasted. I then anodized it to two different shades on bronze. I had swapped the LED it to a then still engineering sample of XP-G 4000k R4 (& I doubt I’ll bother updating b/c there now seem to be so many funner/more exciting hosts out there to do) & so yes, I desperately need an update. =)
EDITED on 12/13 to lower/correct the pic size
My most recent arrival. Tremendous value! Compact, like the mode separation.
My most carried torch.
I think S2 should fit here:
This is my S20 Baton. It's my everyday work light. I ve been carrying it for years. At one time I replaced the older style emitter for an XPG2. Love the lockout, and the magnetic tail.
That Olight would be perfect in my line-up.
Thanks for another great giveaway :bigsmile:
Press and hold “fire” button -> mind blowing output
