Possibly.
With the new option from OSHPark we can get thinner boards with double copper!!!
Hey guys, the 16mm clear boots are at Convoy now. Lot of 10 is $4.05, free shipping.
http://www.aliexpress.com/store/product/Flashlight-tailcap-translucent/330416_32596868733.html
I ordered a batch. Hopefully they will arrive in decent time.
Thanks for the heads-up PD!
The only thing missing now is that beautiful glow. And I have to remind Simon that the clip goes one groove back! :bigsmile:
I ordered a couple batches of those :) thanks for the pot board!
I went to lowes yesterday and picked up a piece of plexiglass and a hole saw. Ended up making about 50 clear washers that let practically all the light through. Pretty much doubled the brightness in my sinner tailcap!
I got the sinner with mtn17DD/guppydrv rev2 working like it's supposed to. I didn't have the right resistors but I had 2 200ohm ones here, those in parallel make 100ohms, and after adjusting the potentiometer a few times everything is back to normal with the firmware.
I put in a couple rather large orders for everything. Hopefully I got the right diodes.
I’m beginning to think my nylon washers are blocking more light than I originally thought, even though the light diffusion is nice. I think I’ll do the same with the lexan and a hole saw. Maybe I’ll add some DC Fix too, we’ll see.
Also, my potentiometers came this week. I ordered the 20k range, and they work quite well. Thanks pyro for sharing the Eagle part, it fits perfectly.
Tight fit but looks pretty good nice job
Yep, it’s definitely tight. This is the little 16mm board, the 20mm is a bit more roomy.
Ok, just got back from Home Depot. I grabbed a 7/8” hole saw bit and a sheet of the cheapest and thinnest plastic sheet. It is sold as a replacement for glass in picture frames. On the left is the ring I made from that sheet, on the right is the nylon ring I had been using. In the middle is what I think I will be using from now on. As you can see the middle one is a lot more translucent than the nylon washer, but should give a more even spread of light than the totally clear sheet from HD. It’s also stronger and less brittle than the clear sheet. Anybody want to guess what plastic I made it from?
PVC plastic, some food packaging? (But which?) :~ How’s that for a non-answer!
How thick is it?
It’s about the same thickness as the nylon washer, approx 0.07”. And no, not from any kind of packaging
I’ll just tell you. It’s the same plastic I used to make a replacement lens for my Nitefighter L1A. I cut it from the drawers of a set like this:
Lol brilliant! I ordered 10 and 20k pots, wasn't sure which one would be better.
The sinner modes went finnicky on me yesterday. It wouldnt change groups then it was fine. 20 minutes later it quit changing modes and started comming on on high, 3 minutes later it was back to normal. I don't know why it's doing that, hasn't happened today.
Zoom: that’s weird about the modes, any chance heat could have something to do with it?
Has anyone tried removing the metal button on a colored S2+?
TK posted pictures of a disassembled button. Somewhere.
yea I think heat has something to do with it. it would go back to normal after it cooled down. I got the pots and new resistors in, and diodes. I ordered 200mA/30V schottky diodes which seem fine as long as the line is on the right side, which is the left, closer to the LED. With these 120ohm resistors and the new brighter leds I cannot get the modes to work 100%. There is only one spot on the 100k pot that modes will work at all, between 75&80%(3/4 or a little more from full right) and it is always a "next mode memory" even when there isn't supposed to be memory. I am now using a convoy s6 with triple nichia and BLF A6(mtn17DDm) firmware as well as a triple XPL sinner with guppydrv rev1(mtn17DD) for testing, both with 120ohm bleeder resistors.
The 10k pots are small, I haven't tried to fit one yet, kind of doubt they will work. The 20k pots were the right size but they have a tab right between the two legs that wants to contact one side or the other which causes the pot (and leds) not to work at all. More searching through digikey is required for a 20k pot that might work easier, for now I'm just using the 100k.
I paralleled 120ohm resistors and I have the same issue, with modes working fine until the light warms up, and then the modes do weird things, stuck on low, no memory, reverting to turbo then strobe and beacon with normal fast presses, until the light cools and it goes back to normal.
I can't help but wonder if swapping for a different value capacitor would remedy the situation, I hate to go with a bleeder resistor that will let too much more power leak off. Richard told me that I could try it, so that will be the next thing I try.
Well the issue is definitely that the capacitor is being inconsistent. Maybe it’s just a damaged cap, or maybe it does need a different value. I’m not sure, I’ve never had issues persist this long.
I've been using 3 different drivers, one just went to a friend with an s2+. Without the bleeder resistors everything is kosher. I am getting parts for more drivers in the next day or two so I'll swap drivers with different value capacitors when I get a chance. These drivers don't look fresh and clean anymore after all the flux I've used so they need cycled out anyway lol
So, I pulled the bleeder resistors off the drivers and I'm still getting a parasitic drain. Has to be a bad component on the drivers. They weren't doing this before so I wonder if something in the lighted tailcaps caused the failure?
How much parasitic drain? The lvp circuit lets some current through, but normally the tail switch stops that when the light is off. Since we essentially bypassed the tail switch with the LTC, it allows the lvp voltage divider to drain some.
I have had issues with the Convoy S2 triple that I built. If I run it on high for very long and then shift modes, I do not always get the mode I want. Sometimes it is back to ML or further back to battery check. I am pretty sure it is a heat issue, if I avoid the top 2 modes things stay good and a couple minute cooldown brings back normal function. Bear in mind, this is a triple on solid copper with a FET+1 running BLF A6, a lighted tailcap battery + contact is a copper disk and tailcap spring is bypassed. I run it with a 30q, so the power is flowing freely! Draws about 5.2 amps at start on high!
It serves duty as my nightstand light and an occasional holy crap light when someone wants to see one.
