can’t retrieve the site. I was hopping somebody as the link.
4K・8K放送対応 スタジアムビームLED投光器を発売~Ra:90かつ、R9:80の光で高品質な映像表現をサポート
パナソニックグループのプレスリリース(2017年11月14日 13時00分)4K・8K放送対応 スタジアムビームLED投光器を発売~Ra:90かつ、R9:80の光で高品質な映像表現をサポート
Ebay
http://www.ebay.com/itm/True-Copper-pill-slug-to-install-Carclo-6mm-height-triple-TIR-into-Convoy-S2-S3-/261940436045?pt=LH_DefaultDomain_0&hash=item3cfcdddc4d
It’s ended and for triple.
Sorry.
If you want 6.2 amps, I expect the NCR18650B is not the best battery.
I bought the BFL Special Edition A6 flashlight. It, of course, uses the same driver you are getting. In the A6, I am running a Samsung 30Q.
Maybe you can adjust the resistance with the springs and wires to get six amps with a particular cell type. More than six would definitely be bad.
Right!
I neglected to say that I am barely getting 4 amps out my A6s. That's because I do not have the springs bypassed.
Hum thank’s for every answer.
But I want to understand something.
I have my Jax Z1 with sbt 70 and a FET driver.And with a NCR18650B and I got 8.90 amps.
But I know the vf of the sbt70 is 3.3v. The 219c as 3.8volts? If I’m right the fet driver can deliver the maximum amps the diode need?
But I don’t planned to lower the resistance of all springs to limite the current.
4.5 amps with the ncr18650b is possible? Or you got the max amps with a 30q?
If I don’t get blue tint shift I’m okay.
Edit: I don’t want to get the maximum amps in the led. This light will be my EDC light. I’m waiting every parts of the light.
How do you adjuste the resistance? If I let the spring whitout any solder braid. It will limite the current. I think I will get a great 4 amps.
Hum thank’s for every answer. But I want to understand something. I have my Jax Z1 with sbt 70 and a FET driver.And with a NCR18650B and I got 8.90 amps. But I know the vf of the sbt70 is 3.3v. The 219c as 3.8volts? If I’m right the fet driver can deliver the maximum amps the diode need? But I don’t planned to lower the resistance of all springs to limite the current. 4.5 amps with the ncr18650b is possible? Or you got the max amps with a 30q? If I don’t get blue tint shift I’m okay. Edit: I don’t want to get the maximum amps in the led. This light will be my EDC light. I’m waiting every parts of the light.
Sorry to say, I am not qualified to help out with your mods. Hopefully, someone will be able to add to what you have posted.
I am concerned, however, that pulling 8.90 amps from a Sanyo/Panasonic NCR18650B exceeds the maximum continuous discharge current specified by the manufacturer for that battery. I have one (evidently older) document from Sanyo that specifies 4.875 amps as the maximum. On web sites like Orbtronic's, I frequently see 6.8 amps (2C).
I believe NCR18650B are Panasonics.
Right. Panasonic purchased Sanyo, including its battery division. I have edited my post above to say Sanyo/Panasonic instead of Sanyo.
A rose by any other name is still a rose. It looks like an 8.90-amp draw is significantly more than this battery is rated for. What say you?
uff…too bad my english.i ask-will be a big difference i output between xpl triple hi and this?:
http://www.kaidomain.com/product/details.S022932
uff…too bad my english.i ask-will be a big difference i output between xpl triple hi and this?: http://www.kaidomain.com/product/details.S022932
your link goes to a Nichia 219A triple, this comes nowhere near the output of the Nichia 219C . But the XP-L Hi will still have a higher output as a Nichia 219C, but the triple beam will be a little less nice.
Kaidomain offers that triple in two configurations. One wires the emitters in “series” and the other in “parallel”.
Your link points to the “series” configuration. It is highly likely that you would want/need the parallel configuration at the following link.
http://www.kaidomain.com/product/Details.S022933
But don’t take my word for it. Just be sure you get the configuration that is appropriate for your intended driver.
i knw,there is a paralell…i want to know,if there is a big difference between tripple old nichia and triple xlp hi:)
The Nichia site used to mark all 90CRI 219C’s ‘under developement’.
I already heard rumours (from clemence), but now also on the website for the 3500/4000K version that marking has gone, so I guess they officially started producing them.
here’s the 219D
Wow, good find, can’t even get there via the home page! No time to look into it now, excited to see what’s new about it
I don’t even have a high-CRI 219c yet, and the 219d is out already?
Regardless, looking forward to more details.
So,according to specs the 70 cri version is about 5% brighter than the equivalent 219C and almost the same as a XP-G2 S4, 336lm @ 700mA
here’s the 219D
Currently published data limited to R7000. Actual product are available up to R8000. Will take months or years until the R9050/80 launched.
Also, theres 7070 package ready to launch with weird but practical footprint: 149AM (9V)
Available up to R9050. Designed for stadium lighting.
And 8080 package too
And there’s rumour that 149AM R9080 is already there made exclusively for Panasonic
Football is very popular in Japan……And I guess that’s why there’s a special request for it.
パナソニックのLED投光器 ナイター照明「スタジアムビーム【4K8K放送対応】」は、超高精細度テレビジョン放送(4K・8K広色域)に配慮し、色再現性 を高めた「平均演色評価数Ra90」かつ「赤色の特殊演色評価数R9 80」を誇る最先端技術の照明器具です。
- Clemence
