To widen the clip width, remove clip from flashlight, get a pair of these or regular pliers if you don’t have any. Tape clip to deter scratches. Lock pliers one half inch below the bend in clip on the side closest to the flashlight, make sure the pliers are straight, hold pliers firmly or clamp in vise, hit the area between the bend and the piers with a hammer until desired width is achieved.
Tailstanding at bedside resulted in less than 5minutes of run time with it gradually stepping down in levels then shutting off. It will turn back on but then will repeat the process.
I was hoping that all would be fine, minus batt check but that does not seem to be the case. Thanks TK for pointing out the not so obvious to me.
I have a question for those who did this group buy, put in their time and effort, and exhibited their knowledge and patience, just so we could all have incredible flashlights. How do you feel about the ungrateful, pathetic folks who buy these and hope to sell one for the entire set cost, or double their money on them, or whatever? I think it is despicable, disgraceful, obnoxious, disgusting, disdainful, contemptible and distasteful, among other things. Did you all expect this, and it doesn’t bother you? I am naive to let it bother me? What has happened to decency, respect, and knowing the difference between right and wrong? Sorry, I guess that is more than one question. Jeez.
Cabfrank - As supply dwindles I can see the retail going up slightly given what they are. Are they worth 2x...only to the ...well whoever wants to pay that. I am sure that there are profiteers running around especially since many stated "I already have an X6" when in reality they do not have "this" X6, especially the aluminum X6's which if things go right will have a 2x tube extension.
Definitely a hardware issue. It’s getting the wrong voltage levels on its sensor, so it thinks you’re always at a critical low-voltage level.
As with many driver issues, you might be able to fix it by touching up the driver’s solder joints. Maybe there’s a resistor shorted or something, likely R1 or R2. But you might also have to ask Neal for a replacement driver.
It’s also possible that some other connection is barely touching, somewhere on the power connection path. You might want to take apart the tailcap and put it back together, loosen and tighten the driver retaining ring, maybe clean the threads and end of the tube if it’s an aluminum model. Possibly swap the switches between the two lights to see if the issue follows the switch. Sometimes spurious low voltage can be caused by a faulty connection from the battery to the driver. I had a faulty switch do that once.
Fair enough. I never want the drama llama at my house for dinner, and profiteers is a nice euphemism. You are really good people, and we appreciate, almost all of us.
I order my SS/Cu set and for some reason it had defaulted to EMS shipping and I didn’t notice until after I had made the payment. Ended up paying an additional $23 for it and didn’t try to get it changed as I figured it would just arrive quickly which is a good thing anyway.
Ordered a aluminium set 2 days later and just went with the priority direct or whatever it was called, which I think was free and its already in Australia and the SS/Cu set only says “Notification of Shipping Confirmation”
Can’t wait to receive them, hopefully before I go away for work!
I had a horrible nightmare. I dreamt my set arrived in an old Nike shoe box. No packing material. Just rattling around in there together. The x6 had a huge gaping crack running through the heatsink then someone said "aww shoot it'll buff out"...
Regarding a discussion from a few pages ago: I do not agree with TK, in principle, when well build (no light from the light source can directly shine at the detector), an integrating milk-carton should be better at integration (so more accurate with varying angles and beam profiles) than the bended pipe thing. What would help is sanding the inside of the carton with fine sandpaper to make it matt instead of shiny.
SS/Cu boxed set in the low 100’s arrived yesterday. Slight dings on two of the box corners. Couldn’t be happier with the set. A huge “thank you” to all who made this happen!
Got my Cu/SS set today. Wow - so beautiful, thanks to all concerned with this amazing GB. Non-boxed set with mismatched serial numbers in basic packaging as described by others. No damage in transit.
I have a problem with the X5 that I can't work out where it keeps stepping down, from lower levels. Just did a quick and dirty tailcap current reading with a multimeter and cheap leads. Times shown below to within a second or two - in the absence of more sophisticated equipment, I simply narrated the observed readings into a voice recorder app.
Starting at level 3 (third lowest of 7) I was reading about 137mA @ 5s
120mA - 30sec
104mA - 40s
91mA - 50s
79mA - 1.00
67mA - 1.12
56mA- 1.21
49mA - 1.30
41mA - 1.38
34mA - 1.47
28mA - 1.57
23mA - 2.06
21mA - 2.18 where it seemed to stabilise.
Battery is a protected 14500 Keepower reading around 4.11V. I haven't sourced any decent IMR cells yet so the highest modes are not possible without tripping the protection circuit. I've tried this with 2 identical Keepower 14500s at around the same voltage.
I also tested a couple of Coolook LiFePO4 14500s with similar observed results. In fact, these were the first cells I tried as they are unprotected and seemed go give access to all modes albeit probably at lesser output than a good IMR due to their nominal 3.2V rating.
The stepdown almost seems somehow thermal in nature but this makes no sense at such low drive currents. If I "rest" the light for few minutes, it then takes a good 90-120sec before it starts dropping again. Ambient temp at the moment about 27C (80F).
The same thing happens starting from Level 4 but from a higher baseline current.
Hopefully one or two of the Gurus in here might have an idea what's going on. I've already used the config menu to perform a factory reset.
Potentially it is even worse. She does not work because tomorrow is her birthday But I think I have much more interesting presents for her than these lights - SHOES
