Calibration with the sun like this will work, but your calibration will not be independant from your luxmeter's calibration, if your lux is off, your lumen will be off. And luxmeters cheaper than several hundred dollars have big tolerances, even if they are correctly calibrated (which the cheap ones will not be).
Perhaps the best 'budget' calibration is using a household reflector led bulb of a trusted brand (Philips, Osram come to mind, they usually come with a (multiple) TIR), switch it on and let it settle for half a hour before using it for calibration. Your entrance hole must be big enough for it (50mm)
Do not paint your sphere black, with its thin walls it is even advised to paint it white for improved reflectivity. For a sun calibration event, put it in a cardboard box with a hole or something like that.
Thanks for your comments and suggestions. I don’t know how large is the error of my luxmeter. I will keep this in mind.
As for using household lamps for calibration, the problem is that my inlet light port is not large enough. In any case, I just want to have an idea about the flashlights that I have anyway.
I will let you know once I have more test results.
Glad I stumbled on this thread. Great work Djozz! Looks like I can locally pickup (2) 12 inch half balls @ $8each. Question, with a 12 inch ball (30.5cm), what's the largest size hole I could use and be within reason for decent results? Can I go up to 75mm? (i.e. for a Courui?) My use would be for bike lights which could also involve shapes that are not round (more oval).
Hi Gary, a 30.5cm outer diameter is about 26cm inner diameter. You're fine with a 75mm hole in that, it will affect the amount of integration quite a lot, but even up to 116mm is within 5% of the inner surface area (5% of the inner surface taken up by holes is a rule-of-thumb-maximum for proper integration, according to the Labsphere theory, but that is with a very high reflective inner surface, and sanded polystyrene is pretty white but not that white). But you could also make an insert in the 75mm hole for a smaller hole, say 42mm (a C8 would fit in that) by re-using the cut-out of the 75mm hole, if the cut is neatly made with a scalpel or exacto-knife. You need to use a separate multiplier for the two holes (so calibrate the sphere for each hole separately).
(for real accuracy the multiplier should be adjusted for each measured flashlight, but then you need to make use of an multiplier measurement light and that was not the focus of the 'cheap and easy one' :-) ).
I repeat this because someone above made a hole for the luxmeter also: do not make a hole for the luxmeter, the light is measured through the styrofoam in this design. The design of the OP assumes a wall thickness of around 2cm, this reduces the amount of light reaching the luxmeter enough to get the lumen-measurements into a workable range.
Cool! What did you use for the base and the “rings” for the light entrance and light meter? Looks like the base is thin cardboard? And the rings thin PVC?
My new lux meter should be coming tomorrow! (Curious to check it against my HS1010 to see if my HS1010 is off as badly as I suspect.)
Looking immaculate!
I see that your entrance hole is quite long, so could you do a little experiment for me that I’m curious of?: could you check how (in percentage) the luxmeter reading differs while you move the flashlight up and down the hole. The reflecting mirror surface should make that the difference is not much (all light should be directed into the sphere, and the reflectivity should not differ too much either), I would like to know how much.
I think I must make one of these. It appears to hit a sweet spot between effort and accuracy.
BTW I’ve been using white paperboard stencils around the head of each light on my old light box. I assume the same could be used here to minimize light leakage, with no significant ill effects?
My old light box is also wrapped in aluminum foil to prevent contamination from outside light. Would that be pointless here, or might it still be relevant?
Yep - all the assumptions are correct. Base is just a ring of cardboard and the rings are made out of plastic pill containers. I managed to find the exact right fit for the light meter, so I don’t have to fix it with tape:)
The difference was indeed not much, but I will get back to you with some exact numbers.
The intention of a good working light box is not keeping as much light in as possible (although you need to keep the light loss under a certain minimum to obtain enough integration) , but to keep the light loss as constant as possible (in other words: make the combined internal reflectivity of the sphere constant), which is a different thing. Then the multiplier is constant and the box is accurate. The flashlight that is held in the entrance hole provides the light for measuring, but also influences the combined reflectivity of the sphere. Wether you need white stencils around the light, or grey or even black, is not known, what you want is creating the same reflectivity as when the reference light was measured.
Outside light probably is usually so much less than your flashlight (unless moonlight is measured), that alu-foil is not really necessary, but it does no harm either, I think it would make me feel better too
It just occurred to me:
-the measuring range of the 15cm sphere of the OP is 0-17,000 lumen (which is a useful range)
-with the same build, a 30cm sphere (with the same 2cm wall thickness) would have a range of 0-68,000 lumen, which is less useful because you will never measure this high output, and the resolution at the lowest light levels gets too low.
-to solve that, you could slice the wall of the sphere thinner at the position of the detector (actually like I sliced a bit off the sphere where I made the entrance hole), before attaching the ring, this will get more light to the detector and therefore bring the range down. So you can adjust the range by slicing more or less styrofoam off at the detector spot, and I can not think of a reason why this would affect integration in a grossly negative way.
First of all a little explanation why I left entrance port longer. I wanted to keep the inner surface vs ports ratio very small (about 3%) and still get a usable reading form some lights that are just a bit too large for the opening. So I tried to be a bit sneaky. I hope the pictures explain my plan a bit better…
The port is covered with aluminum tape, depth is about 32mm and the diameter is almost perfect for X6 and D80. So these will be the test lights.
X6 triple test1
X6 triple test2 – different output mode
So basically very little difference in lux reading when traveling almost 3cm up or down. When the head is pushed too far down inside the sphere, there is off course a sudden drop in numbers.
D80 test1
D80 test2
The last picture shows a drop, because the head is already too deep inside.
But as you can see, the numbers are not so stable anymore. Almost 10% difference. My best guess is that the culprit is reflective bezel?
So the position in the entrance hole does make quite a difference, even with its reflective walls. Pity, that implies that you will have to define a fixed depth for your measurements (not that much of a problem though). Yes, it is the reflector that is increasing the overall reflectivity of the sphere, and when it is too deep in, the side of the head is eating light, and with so many reflections going on, it is soon adding up to a considerable loss of reflectivity. With a bigger sphere the things going on in the entrance hole will have less influence on the reflectivity (multiplier).
If you like this DIY tinkering, you could build a reflectivity measuring light into your sphere, to compensate for entrance hole effects, but it will definitively not be a fast build anymore. See for an example my integrating sphere #3.
The first two tests done with X6 triple had very stable results. Surprisingly stable!? But this was a triple with tir optics = no reflecting surfaces whatsoever.
From 444 -> 455 and from 217 -> 222. That is only 2,5% increase if you consider that the travel distance inside the entrance was over one inch.
With lights giving more unstable results (like the D80 in this example) it’s very intuitive to find the sweet spot. You start lowering the light inside (lux numbers climbing) and the moment the numbers start to decrease you pull the light back just a little bit.
I found that this basically means that the flashlight is almost flush with the inner surface or just a bit higher.
But these were just a few quick tests. I have not had a lot of time to play with my ball
