The code is open source and itās likely that rich at MtnE will probably have them at some point. The A6 driver is sold separately already so this probably will be as well.
It seems like more people have been āon edgeā lately. Iām not sure why, but I suspect itās a combination of several things. In particular, BLFās overall growth and its gradual shift toward being more of a market and proportionally less of a hacker hangout. I think. And more people means more friction.
Iām not making excuses for it, just trying to describe what I think Iāve seen happening. It bothers me too, but I donāt really know what to think of it since itās a complex change with many tradeoffs. We get more cool stuff and more cool people, but we also get more trolls and more drama. And some of the drama has a chilling effect, as seen in the disclaimers well-meaning people include in their posts.
I donāt know how to make things better, but I feel like itād probably help to add more cowbell. Er, I mean, more Foy. Foybell? More lighthearted reminders that this is a playground. I could ask people to behave, to follow good netiquette, but ā¦ who am I kidding? Humans havenāt changed much for thousands of years.
Regardless, individual efforts to swim upstream, to be nicer than the average bear, are greatly appreciated. Keep up the good work.
When you cherry pick just part of what i said, and i read just that, I sort of get why Bugsy gets upset. I donāt mean that Iām upset that you cherry picked some words of mine, I mean I see where Bugsy and others feel like itās a darned if you do, darned if you donāt situation.
I sincerely hope any of what I said is seen more like an SITREP and not a COMPLAINT.
People need to be more grateful, calling out no one in particular. These are by far the best flashlights for the money I have ever purchased. Even with a minor defect or two, these are still a heck of a deal and worth many times the price paid. Nitpicking on thease minor flaws is very discouraging to all the people involved in making this group buy happen.
Dented box corner, small scratches, mismatched serial numbers, why care about any of these pety things. This is one hell of a light for the money.
Ahhh, ok, yes - it's a metal one, but only in 1 of 6 lights, but I had no clue - maybe the alum X6 was supposed to have one.
Soooo, can I politely, possibly ask Neal for a plastic replacement? I could check thru my parts bins first, might have something around to fit or trim to fit.
Oh. It was a long post and I didnāt want to quote the whole thing so I only quoted the beginning. Perhaps āmy two centās worth after reading the last twenty or so pagesā would have been a more appropriate snippet.
Symptom of people being more āon edgeā than usual. Like how a light tap usually goes unnoticed but the same tap can hurt if it hits something which is already sore. Common elbow-bumping seems to get bigger responses lately.
Elbow pads (or flameproof pants) and smiles may be of use.
I donāt know what material is used for o-rings, I donāt know if natural rubber is used anywhere, but if it is, a petroleum-based grease is not recommended. If youād like to use silicone grease on your silicone o-rings, more power to you, but you can expect them to swell and foul your action as well as snap and lose your water seal.
I didnāt mean to come up head to head with you, just figured you were shooting from the hip. If youād take a few minutes to do some Google Fu, I am confident you will be reminded. Its an easy thing to flip flop. The CPF Comprehensive Lube thread is a unified resource great for the purpose of flashlight thread and o-ring lubrication, but there are plenty of other sources of information backing up my claims regarding compatible lube for the kind of material. Donāt take my word for it, see for yourself. But please lets not just naysay each other, kind of pointless.
Fwiw I think there is probably a difference in application between divers needing to seal out water under great pressures and flashaholics needing to seal out water of no or marginal pressure and dust AND have decent lubrication for threaded action. Often, flashaholics will simply remove the o-ring completely, as their need for water seal is minimal but their desire for smooth action is great. Sounds like for diving appliations what you want is a damn tight seal, and in that application, silicone lube works for the purpose. For flashlight o-rings, you wonāt want that kind of seal.
Also, galling is simply metals in contact siezing, and can be, is often caused by galvonic corrosion, which is itself caused by a metal, like Fe or Stainless Steel from one batch, corroding in preferential to another, maybe like Cu, or even Stainless Steel with slightly different amounts of its constituents from another batch, when they are in electrical contact, like in a flashlight tube, in the presence of a conducting solution, say, lube, even if a vanishingly small amount.
After checking the tracking about a thousand timesā¦ Yay!
These lights are absolutely incredible, worth every penny and more. My youngest kid thinks the little one is for him, as others have said these lights are kid magnets!
Great job guys, you knocked it out of the park.
P.S. The etching for āKRONOSā looks amazing, I like the font too, how the N dips a little below etc. Great little details to enjoy. Thanks again!
Mine arrived today and I got matching serial numbers (both lights and they match the box). I havenāt been keeping up with this thread, but I thought that the tailcap light could be locked out by loosening the tailcap?
