BLF Kronos X6/X5 GB - Group Buy now closed.
samsat, 11k works really nicely. I stacked 2 of the 22K I use building drivers, very low .15mA draw.
Thanks DB. Always there with quick useful answers.
You must have the vision of an eagle and the hands of a surgeon!
Itā€™s going to be a challenge to solder just one SMD resistor in place let alone stacking 2 of them!
Iā€™ll look at some of the PCBā€™s I have to see what values I can harvest.
I see I have some 103 (10k) which is close enough to your 11k.
Damn I knew I shouldnā€™t have had that double espresso come on hands slow down!
Calico version.
My X6 had a fingerprint mark also. It rubbed right off with minimal effort and some saliva. :wink:
Tried to work on my too-narrow X5 clip to see if I could increase the depth to make it more usable, and only succeeded in breaking it right at the bend :frowning:
At least I got it off the light without leaving any marks. Probably wasnā€™t going to use it much if at all anyway, but you never know. So, if anyone finds a clip that fits, be sure to let all of us know.
You know, it has a thermometer built in to help with that. :slight_smile:
There wasnā€™t anywhere near enough room for a proper PID algorithm, but it still does okay managing the heat after the heat has had time to reach the MCU. You could also improve this by cramming in some thermal transfer foam between the MCU and the pill, to help it sense heat faster.
I tried, and failed, to open up my Al X5 clip. Not enough heat? Went too fast? I donā€™t know. It snapped and thatā€™s all she wrote. :frowning:
If they can make more of the good ones Iā€™d be willing to buy a replacement or three.
Just got mine today. This is my first real flashlight, so for those of you whoā€™ve been jaded by your collection, you might not remember this feeling, but: OMG.
It took a couple minutes to get the hang of moving through all the modes, but itā€™s pretty easy now. Very nicely done, all around.
Thanks,
Dudunphy did an amazing job with the A6 thread, helping countless people with the issues they encountered. I really wasnā€™t expecting anyone to take on so much work for the sake of others. But this is BLF, after all, and people are pretty awesome here. :slight_smile:
Thereā€™s a small issue with requiring people to post on BLF before they can get help from the retailer. It requires people to have an account. It adds another layer of inconvenience when itā€™s already too difficult to get good support.
As for the QA ideas, it sounds great. But first there needs to be actual formal QA, and before that there needs to be direct communication with no translators in the middle. That would likely solve most issues. :slight_smile:
ā€œYou could also improve this by cramming in some thermal transfer foam between the MCU and the pill, to help it sense heat faster.ā€ ā€” TK
Have you had success with this on an MTG too? I have a light where the center is very yellow, and my two I just received also have this problem, yellow center surrounded by blue.
I think thatā€™s pretty standard for MTG2 in a smooth reflector
my tracking number said my lights were delivered feb 3rd, and i thought they had been stolen, but they came today, the 5th, and i have ss# 225.
they are very nice and i am NOT going to test them, or ever open them or do anything but let them sit there in their box #225 .
i will be open to offers for the set, by PM and i will be busy a lot and will not be checking messages regularly. i ordered NW.
OK, interesting, I havent had this happen except on an MTG light.
I am a bit disappointed in the tint on the two sets I just received just since I wanted WW and got a blue-y ringed beam due to a focus issue, Iā€™ve got to figure how to resolve looks like. However I do like this tint more than any other CW Iā€™ve had, even blue tinged its generally a nice white, not sure Iā€™d call it NW, is it possible the bin is off?
Tint aside, absolutely beautiful lights, beautifully functioning driver, beautiful amount of light too! My wife has already complained about the tailcap glow though, how am I going to keep this next to my bed? :confused:
Just get those WW tint selections next time and a warmer NW purdy please :slight_smile:
I have a yellow hotspot with blue spill on pretty much every reflector-based light Iā€™ve ever used. Side effect of the ā€œCree rainbowā€. Usually the entire hotspot is yellow though, instead of just part of it. The XP-L HI certainly improves overall beam consistency, but it seems to make the color contrast a bit more noticeable sometimes.
Swap the resistor for something larger. Dale posted a few days ago that he stacked a couple in his for 11K total resistance and had good results. Just this afternoon I pulled the resistor out of mine and swapped in a 12K. Its great, in my opinion. Very dim but still easily seen.
I put in a 10K and it's less bright, but maybe not low enough for my nightstand. Might try a 15K-18K. I did this on a NW Ss/Cu X6, and also tweaked it up:
  • TK's latest (Jan 16) firmware upgrade
  • centered the LED
  • replaced the 24 AWG wires with shortest possible 22 AWG
  • 22 AWG wire bypass in driver spring
  • pulled out the inside spring in the tail and put in a 22 AWG bypass
  • all retainer ring/PCB contacts coated with NO-OX-ID,
  • all threaded body connections w/o-rings (3) treated w/Nyogel
Results are impressive:
  • the time to hold the button for reverse is much shorter, much improved
  • beam pattern looks improved, bout perfect to me (I love this 3B tint btw)
  • tail amps: 5.74A on a clamp meter
  • lumens: 1540 @start, 1472 @30 secs -- this is for the 3B NW tint Smile
how much is a boxed set worth ss# 225
