New engine seems fine, thanks for the hard work. One question tho, is there any way to get old PMs back or they are gone for good?
Seems like the signature line needs to be aligned at the bottom.
I think itās just that some users have empty lines in their signatures.
Sorry about that. I had budgetlightforum.com on the whitelist but not budgetlightforum.ddns.net. So, if you were using the temporary address it didnāt recognize the referrer.
Itās fixed now. At least, I think itās fixed. Please let me know if itās not.
The site uses a HTTP Referer check because most of my bandwidth was being used for hotlinking on random peopleās blogs. At first I tried serving up a different image, an animated gif of Kermit the Frog humping a stuffed bunny, but that didnāt really help. It was funny, but didnāt improve the bandwidth situation. So instead I redirected those requests to a password-protected directory. That worked. The downside is that I have to add every domain (like BLF) to a whitelist if I actually want to host images from other sites.
Scared me for a second. Click the āall messagesā tab and you should see them.
Thanks for reminding me about that, I put a big notice on the first post in this thread.
Aaahhh. BLF and a cup of coffee. What a great way to start the day! THANK YOU.
Everyone likes a Free Upgrade
Thank Yo for all your hard work!!!
BTW, if anyone is interested, Iāve mostly updated the BLF stylesheet for the Chrome āStylishā extension.
This basically re-themes BLF to make it a little easier on dark-adjusted eyes ā a dark theme instead of the default bright white theme. I put the files up here:
http://toykeeper.net/torches/css/
ā¦ and here is an example of how it looks (click for full size):
Itās not complete yet, but itās getting there. There are a bunch of little details I havenāt chased down, like why thereās a big blank spot at the left side. Someone else wrote this originally, I updated it a bit, then after todayās site upgrade I had to update it quite a bit more. So, Iām not totally familiar with every line of CSSā¦ but it mostly works.
Thanks a lot
That big blank spot is where the ad should be. Are you running an ad-blocker?
Iām apparently having DNS issues. In my work computer and phone on wifi (home and work wifi) the āslow dnsā link just redirects back to the same āweāre backā splash page. I canāt get to blf at all.
On my phone on LTE everything is working perfectly
I imagine itās because Google hasnāt adapted to our new IP address yet.
Normally the Adsense banner will go farther down, I just havenāt had time to set up our sponsorās normal banners in their normal positions yet.
Some routers keep a local DNS cache that may be slow to update. Thereās probably a feature to flush and renew that cache in the admin panel but its probably easier to just pull the plug and reboot them.
Awesome Job! Thank you for your dedication and perseverance!
Ahhh! Itās so good to be HOME!
Index of /torches/css
Nice, you could upload it to https://userstyles.org/ so others could find it more easily.
Now working on my work computerā¦ for the moment
Iām not able to find the thread tools options where we can change the number of posts per page. It used to be at the bottom of every thread. Is anyone else having the same issue?
Thanks SB! Looking good. I do a lot of IT work myself so I feel your pain. I have a lot of poking around to do. I actually never thought the text was too small but now that I see the difference I like it!
I hope the rest all goes well. Man itās nice to be back.
Not that the little shoutbox wasnāt fun but this is a lot homier.
Cheers!
