Hmm, it seems to work for me with the Simple Post Editor:
Perhaps i have not explained it well, if i see a page that says for example “2 new” i can click on “2 new” and it goes to the right post
If i click on the thread and not “2 new”, it opens from the start, it says 2 new near the top right, but there is not a link to go to the first new post like there used to be.
And in the Advanced Post Editor:
sb56637: Bort:I noticed from the recent page you can click on the new post on a thread, but if you click on the thread itself it opens and says “X new”, but you can’t click on it to get to the first new post.
Hmm, seems to work for me. Is it possibly the issue I mentioned earlier in this thread where slow-loading images cause the page to “bounce” even though it starts off loading at the right post?
Ah sorry, gotcha now. Did you try the “First unread” button?
Bort: sb56637: Bort:I noticed from the recent page you can click on the new post on a thread, but if you click on the thread itself it opens and says “X new”, but you can’t click on it to get to the first new post.
If i click on the thread and not “2 new”, it opens from the start, it says 2 new near the top right, but there is not a link to go to the first new post like there used to be.Ah sorry, gotcha now. Did you try the “First unread” button?
I did not notice it, i used to click on the X new, legacy knowledge scratch_one-s_head
sorry about that
Update looks good! Like others, I miss seeing the users location (without clucking to see their profile). I came to this thread about email notifications not working, but I see it’s already a known issue (i.e. I’m not getting any BLF emails for new posts in threads I’m subscribed to).
-Garry
2. Emoticons with asterisks, like scratch_one-s_head and smile don’t work.
Ah thanks, the smiley configuration is really janky on this version. I’ll basically have to add them in one by one.
- No longer can respond directly using only emoticons. Not a big deal. Members will quickly learn how to deal with it, by adding text or a space. (You can even add then immediately delete the text or space to get the emoticons to “stick”.)
Interesting observation, thanks.
- I miss my listing of posts that used to be under My Account. Is that feature permanently gone under this revision? Or has it been relocated somewhere else?
Still looking for a solution. I thought I had it yesterday with the “Tracker” functionality, but that had the side effect of showing everyone’s browsing habits to the entire world, so not a good solution. I’ll figure something out though.
-Garry
I just now added the user location thing to the first post in this thread.
How do i see my browsing habits?
Can i make a suggestion, signatures seem to look like part of a reply, not sure why they didn’t before the upgrade, but perhaps smaller test, or italics or something or some spaces might help?
This is another gotcha. I’ll add it to my todo list.
sb56637:Still looking for a solution. I thought I had it yesterday with the “Tracker” functionality, but that had the side effect of showing everyone’s browsing habits to the entire world, so not a good solution. I’ll figure something out though.
That was the problem, I had to disable it because making it visible to you would make it visible to everyone.
SB, for whatever reason the “mark all read” button is missing the button image on my system. Even after several page reloads. Did the image get lost?
I’m not sure what’s wrong, but none of the pictures I have been posting are embedding correctly anymore. Sb, I’m guessing you are working on soemthing, but maybe you can use this thread if you need a case study. My pictures were working fine earlier today.
http://m.banggood.com/Ultrafire-C8-CREE-XM-L-T6-1300LM-5Modes-LED-Flashlight-Suit-p-912655.html
Ah, thanks pilotdog68. It looks like I’ll have to revert the fix that I tried on Bort’s observation about broken links. Looks like to add links with dashes in them we’ll have to use the insert link button when using the Simple Post Editor.
Yep.
Something is amiss.
Not just pictures.
Some of the emoticons that were working earlier aren’t working either.
Maybe they are out on strike.
Yep.
Something is amiss.
Not just pictures.
Yes, I realized that I will have to configure each and every emoticon. I just added a few essentials, and I’ll add more as time allows.
I know you're new to BLF and all, so I'll let you in on a little secret:
That charger and those batteries are junk!
sb56637:http://m.banggood.com/Ultrafire-C8-CREE-XM-L-T6-1300LM-5Modes-LED-Flashlight-Suit-p-912655.html
I know you’re new to BLF and all, so I’ll let you in on a little secret:
Aww man!
