I’m not sure what’s wrong, but none of the pictures I have been posting are embedding correctly anymore. Sb, I’m guessing you are working on soemthing, but maybe you can use this thread if you need a case study. My pictures were working fine earlier today.
Ah, thanks pilotdog68. It looks like I’ll have to revert the fix that I tried on Bort’s observation about broken links. Looks like to add links with dashes in them we’ll have to use the insert link button when using the Simple Post Editor.
If it’s to your liking, you could also try the BLF dark theme… but I’m not much of a graphic designer and my CSS is rusty, so it may very well be worse than 1990s vibes.
(for anyone else who might be interested, this is your notification that the theme thingie has its own thread now because I didn’t want to clutter this thread)
Making explicitly mobile-friendly sites is kind of a pain. The server needs to check your browser’s User-Agent header (if provided) against a sizable database to determine what kind of client it’s talking to, categorize it into one of a few supported types (like recent desktop, old desktop, recent mobile, old mobile, bot, etc), then render each page completely differently based on the client type. This requires a full set of templates for each type, and code inside the entire rendering chain (and sometimes functional logic too) to behave differently according to the client type. And then if you want to customize the theme, like applying the BLF theme, you have to customize it for every supported client type. And if you later upgrade the site, you may have to re-do those customizations repeatedly. And, of course, the person who does this needs access to one of each client device for testing and development. It’s a lot of time and effort.
If the framework supports it, a custom multi-platform theme might be do-able in a day for an experienced and efficient web designer… but it could also take much longer.
If it’s not already built deeply into the web framework, it’s not even remotely worth the effort.
Anyway, if it happens, I think we would collectively owe sb56637 at least a year worth of beer. As if we don’t already.
As someone else indicated in their post, I believe you have to add text, or a period, or something, maybe a space. I just tried to post a photo only and it didn’t work. No problem. Thanks.
Or, for those who are so inclined, the forum still allows quite a bit of HTML in the simple post editor. It’s very useful, and the syntax is pretty easy, but it can take some getting used to.
So, if it’s giving you trouble, you can write it this way instead:
<a href=“http://some.site.com/foo/bar/baz”>The Foo Bar Baz site</a>
(also, FWIW, I may have just found a bug… it still auto-links things which look like links, even inside of the <notextile> tags which are supposed to disable that… which suggests that the auto-linking thing may be running in a separate pass)
