[07-MAR-2016] Current status of BLF upgrade process
Technically he has only been on “BLF” for 2 days so your insight is valid
Making explicitly mobile-friendly sites is kind of a pain. The server needs to check your browser’s User-Agent header (if provided) against a sizable database to determine what kind of client it’s talking to, categorize it into one of a few supported types (like recent desktop, old desktop, recent mobile, old mobile, bot, etc), then render each page completely differently based on the client type. This requires a full set of templates for each type, and code inside the entire rendering chain (and sometimes functional logic too) to behave differently according to the client type. And then if you want to customize the theme, like applying the BLF theme, you have to customize it for every supported client type. And if you later upgrade the site, you may have to re-do those customizations repeatedly. And, of course, the person who does this needs access to one of each client device for testing and development. It’s a lot of time and effort.
If the framework supports it, a custom multi-platform theme might be do-able in a day for an experienced and efficient web designer… but it could also take much longer.
If it’s not already built deeply into the web framework, it’s not even remotely worth the effort.
Anyway, if it happens, I think we would collectively owe sb56637 at least a year worth of beer. As if we don’t already. :slight_smile:
aye carumba. i had no idea, i usually go to desktop mode anyways because they take out features i need at least half the time
As someone else indicated in their post, I believe you have to add text, or a period, or something, maybe a space. I just tried to post a photo only and it didn’t work. No problem. Thanks.
Or, for those who are so inclined, the forum still allows quite a bit of HTML in the simple post editor. It’s very useful, and the syntax is pretty easy, but it can take some getting used to.
So, if it’s giving you trouble, you can write it this way instead:
<a href=“http://some.site.com/foo/bar/baz”>The Foo Bar Baz site</a>
It’ll show up like this:
You can also do this for images. The syntax is similar:
<img src=“http://example.com/example.jpg” />
(also, FWIW, I may have just found a bug… it still auto-links things which look like links, even inside of the <notextile> tags which are supposed to disable that… which suggests that the auto-linking thing may be running in a separate pass)
Since you have to add them one by one, here are our old simileys Compose tips | Lyrics Translate Of course, whenever you get the time.
Ok reposting…
Sending messages is not working.
I do use that, but it is not the same as my phone saying DING when somebody post in a thread I follow.
How can we see our previous posts in the new system? It used to be under “My Account” before, but now I don’t see it.
We can’t at the moment.
The new system is a work in progress.
Nice, thank you Halo!
Could you give a bit more detail here please?
Added to the TODO list in the first post on this page.
Thanks a lot ToyKeeper. Let’s try this other Textile code markup:
Inline code, surrounded by @@@ chars: <a href="http://some.site.com/foo/bar/baz">The Foo Bar Baz site</a> Followed by normal Textile-rendered text.
Code block, start with “bc… ” and a newline:
http://example.com
<img src="http://example.com/example.jpg">
-dashes- should not cause strike through
_underscores_ should not be underlined
And close the code block with "p. "
Hint: this is the only known way to type @_the_@'s username. :)
again thanks for all the work
A tiny simple thing I would like to see returned…(I know these are mostly the worst questions sorry) the locations under the users.
I've always wondered how to write @_the_@'s username. Now I know! :)
...except I'll prolly forget anyway. :(
Hey SB. I know this has to be a ridiculous amount of work tuning out all the little bugs and I don’t envy you right now.
Great job overall but I suppose I may as well throw my complaints and suggestions out there too.
  • User rank (star system) is gone. Not a huge deal I guess but I liked it. I was so proud when I got my fourth star! :smiley:
  • I know it’s on the list already but location is really important in a global forum like this. It helped me a lot with how to respond to certain questions.
  • White space… There is SO much of it now mostly at the bottom of each post. For those who don’t have a signature line on my 24” monitor I’m looking at 2 1/2 inches of blank space at the bottom of each post. I’m wearing out the scroll button on my mouse. One place at least 1/4 inch could be saved would be shrinking the height of the “Top…Quote…Reply” line under each post. It seems overly large now. It looks like the “Send PM” button is half the height of those bottom buttons and that is more than large enough IMO.
  • I never thought I could hate emoticons… These new cross-eyed, dopey looking dorks with a sprout of hair are driving me bonkers! :open_mouth: Ok I like the new crazy eyed one but I actually get mad looking at the winking one. Ok maybe I have some anger issues to work out. LOL I miss the old ones though. Perhaps you’re working on them already because now I only have 5 to choose from…
Ending on a happy note the new beer mug has increased capacity! :beer:
Yup… Adding a photo without any other content doesn’t work. It needs a space or other input in the text field, otherwise the Save/Preview buttons remain grayed out.
Things I’m missing:
1. I liked having the member location listed; this was helpful when assisting with locating sources for hardware. (eg., are you in the US? Buy from Mtn! Are you overseas? get free shipping from FastTech.)
2. A searchable list of threads participated in by each member. This was very helpful… (I recall Djozz started a thread yesterday but I didn’t subscribe, now I want to find that again… Also, this is extremely helpful in identifying Giveaway Spammers who aren’t contributing members and only join to get free stuff.)
3. The automatic subscription to threads I participate in of course… :slight_smile:
4. The full list of Smileys in the drop-down box from the text editor… :slight_smile:
Hey there, thanks for the comments!
Ah, I was wondering if anybody would notice. :slight_smile: I believe I can put it back, but I was kind of thinking that it didn’t make a lot of sense to equate number of posts with “quality” or “reputation” of the user. Take me for example, I had 5 stars and yet I can barely insert a battery into a flashlight! :stuck_out_tongue: (And let’s not even talk about threading lanyards into the little holes on the tailcap…)
Meanwhile don’t forget that you can just click on the user’s name and see their location if it’s filled in.
Hmm, I don’t really see it any different than the way it was before. I think it’s pretty much unavoidable given the author’s details that require a certain amount of vertical space for every post. But I wonder if you’re running into some kind of browser incompatibility. Here’s what it looks like for me on Firefox in fullscreen (15.4” hi-dpi):
http://s18.postimg.org/mtr8qkgs9/Screenshot_from_2016_02_12_10_47_05.png
Yep, I think I’ll just put back the old ones.
Hi there keltex78,
I’m not sure if I can work around this one unfortunately.
All on the TODO list. :slight_smile:
