It has been a lot of time since i posted v004 (I have been a bit busy due to exams), but today i’ve finished a new version.
Theese are the changes from v004:
–0603 diode pads (for zener mod)
-More exposed copper on top GND ring
-Added copper pour under MCU for temp sensoring
-Wider bottom GND ring near FET vias
Nice, one question is it “only” a design change to wights A17DD-L or is there any extra functionality?
Is it possible to drill through that LED+ pad and push a cable through? Could you already make a hole there? This way you can use the same cable to bypass the spring and to get to the LED.
Or rotate R1 90 degrees, then you can fit all three resistors side by side closer to the center, leaving plenty of room for a 0805 OTC pad.
But myself, I wouldn’t bother. I use 0603 on all my boards.
Don’t you consider soldering a 0805 cap on the 0603 pads?, I don´t know how difficult it is, but it fits (like in the right diagram)
Do you prefer the 0805 option?, if so it could be done performing both of your suggestion, i see some potential clearance problems but i think they could be solved.
Yet another untested monstrosity… This implements what is intended to be a snubber for 1s applications, plus a bleeder for pilotdog68’s tailcap LED system, plus an OTC pulldown, plus a gate pulldown, plus a 3mm via for the BAT+ wire. There was no space for a BAT+ pad on top, so it’s bypass or go home. At first I thought that I was going to be forced to increase my normal 1mm physical keepout, but somehow I got away with it.
This board is really dense populated! you made a great job!
I have already changed OTC pads size to 0805, i have had to remove some vias, and voltage resistors may not be easy accesible, placed that way between tall components, but i think it is done.
Your board is clearly improving, but here are a few things (in no particular order):
Your silk lines are way too thin to be produced as specified. OSH Park or the fab will automatically thicken them for you, but I prefer to thicken them myself (for full control). The worst offender is the marking “PDR” - I suspect that this may not be legible after thickening. I don’t remember how thin OSH Park goes and I can’t find it on the specs page right now: OSH Park Docs ~ Services ~ 2 Layer Prototype Service Maybe someone else can help. Maybe I normally use approximately 6mil minimum? I’m not certain at the moment.
I still don’t think that the board is setup well for a Zener mod. If you’re still not clear on the Zener circuit maybe someone will throw up a quick diagram at some point. Clearly Zener compatibility is not required - it’s just something to think about.
R2 looks suspiciously close to the MCU for a stock programming clip to fit. R1 is definitely OK, the clip doesn’t extend into that area.
Version numbering seemed to stop at v5 where the the driver’s “H1” designation just started getting extra letters added to it? I suppose that’s related to the bypass hole.
Thank you too! it is improving thanks to all of your help.
I going to reply in the same order:
I didn’t know, i’ve took a look at a v003 I ordered to see how things were goin, and yes, silkscreen lines are thickened, but there is no small markings to check legibility :-/
Darn! i thought i got it, thanks for pointing it out.
Sure it is not a mandatary, i will see what i can do, but if it is not done like i thought, i am affraid it wont be possible.
Well, my clip is not wider than MCU, but now i see the other clip version on google, seems that it could suffer this problem.
Yes, it is related to the bypass hole and the bigger cap.
I have no clear how to mark them, as a new version or as a different branches.
I dont want people to think newer boards are better, when they are only different, but i am not happy neither with the extra letters, i think i am going to back to numbers as it keep things simpler.
Is a chinese no branded one you can find on ebay, aliexpress and many other sites.
I got it from this seller: Henny Liu’s store , but i don’t recommend him/her as i got different clip from which is shown on advert images, so random version could be sent.
I need some help. So far everything I’ve done has had a perfectly circular milling layer. How do I do other shapes accurately? Like an SRK driver with the tabs, or a tailboard in the SRK “flower” shape or for a ZY-T08?
Easy for you to say Richard! But this comes from a guy that build a D01 contact board and could not make a basic FET driver fit on board… I really suck at that program.
