Sorry yall! I took a break from flashlight work for a while because I was too busy but THIS SALE IS BACK ON. Please re-submit a purchase request if you had previously proposed a size and still want it. All old requests are still in the original post.
These will now be made from black acetal instead of white nylon.
Simple washers and spacers are now $1 each; centering rings are still $2 each.
Added Kenjii’s XM to XP adapters [post #58] to the new queue.
UPDATE:
These are pretty tricky to machine. The prototype is a little loose on the 219C; I will tighten the spacer pocket by up to .002” per side. I need add a deburring cycle to the program as well.
Circular pockets seem to be all the rage these days to avoid the dreaded centering ring dedome. On these larger gaskets this is an option. Which would you prefer nofearek9? Round or square?
Round pockets will also alleviate the solder bead interference problem.
@Nofearek9: If you need me to add slots or some other provision like a back side pocket to allow clearance for the wires on those centering rings let me know, I can do that. Not sure what your plan is. Hammer some solid core copper wire flat and you’ve got yourself a handy flat lead.
@MG: Sounds good. I’ll get the Convoy rings modeled up with round center holes and added to the queue. Let me know if you’d prefer a square center hole.
As long as you can keep the tolerances good, round is OK, but at least with the plastic spacers it seems like the round ones have a much wider tolerance range, which often makes them end up loose.
Ok, managed to squeeze in some more machine time for these. They came out nice though the picture doesn’t look that great. My process is getting better. I’ll shoot you fellas a PM.
I should add copperclad circuit boards to this thread. (contact plates, etc) I already have a bunch of 1/16” thick 4oz double sided board material. Some 1/32” 1oz double-clad as well.
Do you mean are turning down the actual sinkpads? If so, is it possible to get a couple? I’ve not been as successful at avoiding shorts and even when I get it working, I don’t trust led+ trace a knife blade away from shorting out.
You know… I’m embarrassed to say I didn’t even try a hand file. :–5 I was using a dremel and trying to clean it up with a utility knife. I imagine my difficulties are a result of my methods. I had such a hard time with the first two I did that I mentally gave up on trying to find a better method. I’ll give the hand file a try on the next one.
