cool, i should have checked that before asking
Edit: We need a new smiley, is there a homer simpson d’oh smiley available?
Greetings & Salutations SB,
In BLF's previous incarnation, we could select in Settings whether we wanted to use the Advanced Post Editor or the Simple Post Editor by default when posting.
Any chance of bringing this setting back? As right now there is no choice, & the default is the Simple Post Editor.
Thank you Very Much for all you are doing for us. GREATLY Appreciated.
Best Regards,
George
I feel bad adding to SBs workload but links are not posting properly like they used to with the new software
an example
Please tell me the DIFFERENCE in these Flash Lights… Thank You!
an example
Ok, a made a little change. It seems to fix the links, but I’m not sure if there will be other side effects.
Test http://www.banggood.com/BLF-A6-CREE-XPL-3D-74modes-Flashlight-Nitecore-UM20-2x18650-p-998532.html
Nur US$34.64, kaufen Sie den besten BLF A6 XPL 1600Lumens 7/4modes EDC LED Flashlight 18650 Online-Shop zum Großhandelspreis.
Quote myself.
Pretty picture:
Bort:I feel bad adding to SBs workload but links are not posting properly like they used to with the new software
an example
Please tell me the DIFFERENCE in these Flash LightsOk, a made a little change. It seems to fix the links, but I’m not sure if there will be other side effects.
Common boilerplate side effects from treatments include nausea, dry mouth, headache, dizziness. :GRADE:
Nope, sorry. If I fix links with dashes in them I end up breaking other more important functions like posting images.
Simple URLs usually work still: New Arrivals for - The Greatest Discount on Top Quality Products at Banggood
The best way to post those long ugly URLs is by using link text like this.
why did it work before but not now?
sb56637:Nope, sorry. If I fix links with dashes in them I end up breaking other more important functions like posting images.
It’s never worked correctly since the upgrade. I tried a way to fix the links, but it broke posting images.
In what way did the fix break images? It seems like automatically picking out images should be easy since the string starts with a “!” symbol.
Bort: sb56637:Nope, sorry. If I fix links with dashes in them I end up breaking other more important functions like posting images.
i meant before the upgrade
sb56637: Bort: sb56637:Nope, sorry. If I fix links with dashes in them I end up breaking other more important functions like posting images.
It’s different code now after the upgrade, and there is an unfixed bug which will probably never get fixed.
Things remaining to do:
Tweak the theme, text too smallEnable sending emails / re-enable new user registrations, which are currently disabledOptimize for performanceConfigure a quick temporary system for email notifications on new postsRe-create the BLF community moderated spam controlsGradually enable relevant smileys (one by one…)Add functionality to views lists (and search?) of a user’s postsFigure out how to add the “Location” fieldto post author details-Re-create the BLF email notification system- Mouseover image button for Simple Post Editor
I don’t see the ability to quote the OP on your list.
Is that not possible?
Otherwise it is a PITB re-creating the original text, like I did above.
Or trying to decipher what the OP is talking about, as in the previously mentioned: Please tell me the DIFFERENCE in these Flash Lights
sb56637:It’s never worked correctly since the upgrade. I tried a way to fix the links, but it broke posting images.
The fix requires filtering for links that start with http://
before interpreting the “Textile” markup format. So it ends up seeing a Textile marked-up image link that looks something like… !<a href="http://example.com/image.jpg">!
… which is wrong for Textile.
sb56637:Things remaining to do:
Unfortunately no.
The simplified syntax for links or images may have varying results… but writing them as regular HTML consistently works. And I greatly appreciate the way the forum allows HTML in posts; it can really make a huge difference in how expressive the posts can be.
I treat BLF’s Textile (simple post editor) format as basically the same as HTML, except that newlines get converted to <br /> tags so it’s not necessary to manually put in all the paragraph or linebreak tags. And I don’t need to remember yet another markup language in order to post here, since I can just use standard HTML. Oh, and the Textile quote tag… I use that one too. Very useful.
Most comments are fine with no extra markup, or with only images and links, maybe even light use of italic or bold. These are all pretty simple in HTML. It’s nice having the option to get fancier though, on occasion.
Bort: sb56637: Bort: sb56637:Nope, sorry. If I fix links with dashes in them I end up breaking other more important functions like posting images.
what?
are these forum software people on glue?
headache, dizziness and nausea are the least of their concerns >:-/
