But seriously, Drupal isn’t primarily intended as a forum platform. It’s a complex, full-featured web app framework originally designed as a content management and publishing system, and it just happens to have a forum module which can be plugged in. It’s very … complicated. Some things are easy to change or fix, others are a bottomless rabbit hole, and it’s not easy to predict which will be which.
At least they’re not on the latest new drug. They call it being “on rails”.
Okay, Ruby on Rails isn’t really so bad. Clever design, and spurred some useful discussions elsewhere in its field. It’s just led by a rather, um, opinionated developer whose official stance toward everyone except himself is a phrase which violates BLF’s policy on obscenity.
Dangit, I’m doing it again. Off-topic rambling. I thought I was getting better about that. Maybe the time tracker thingie I just made will help me avoid these things.
Some people ramble and what you come away with from reading their posts is not a whole lot of anything interesting. But I don’t recall that ever happening with your posts. Maybe for someone with zero interest in linux or programing. But they’ll live! Some of the best stuff I’ve read on BLF has been completely off-topic. Off-topic is not evil here. Don’t feel the need to avoid “rambling”.
There’s a site-wide search widget at the top left of each page, a per-thread one at the top of each thread page, and two per-user ones on each user profile. How many more are needed?
If you don’t see a search box in the top left bar above the “Main Menu” it’s probably because you have an ad blocker running. BTW that’s not a trick of mine to force people to disable their ad blockers, it’s just an element that happens to get blocked by many of the default ad blocker lists due to its Google origins.
Its the aspartame in coke zero i tell you (once mouseover is fixed coke zero will appear in my signature)
It looks like SB pasted a link, while i pasted a link as a link with the text being the link
Nope, sorry, but I really can’t find a way to work around the broken links with many-dashes-in-them. Please just make the text and the link the same for those troublesome links, as Bort did above:
Unfortunately it’s not good for mobile / touch device users, of which we have a large percentage, so not a good default.
I would strongly encourage everyone to use the “Simple Post Editor” for everything except posts and reviews that need very complex formatting.
And sorry I didn’t answer your previous post yet about selecting the default editor in the user preferences. I’ve researched it extensively, and there is definitely not an easy or straightforward way to do that.
Added user account settings for “Use the Advanced Post Editor for new threads” and “Use the Advanced Post Editor in existing threads”. This preference is served by a janky Javascript call, so please let me know if you run into any oddities.
As mentioned previously, I would strongly recommend using the Simple Post Editor for everything except highly complex posts that need a lot of formatting, so this option to use the Advanced Post Editor by default is not recommended.
