Thrower suggestions needed for long range light using 18650 budget priced.
Fandyfire STL-V6
See threads in here
Yes, I second that, the FandyFire STL-V6 is one of the best budget throwers.
The one I will recommend is the Trustfire TR-1200 5X Q5 light. Mine easily throws a beam 300+yds.
Here's a shot down my street. About 120yds to those cars on the right. That street sign past the cars on the right is probably around 200yds or so. No problem at all for this light.
Doctor Jones forced me to click the link and then get an STL-V6.....I tried to resist.
I already have an X9 driven at 2.8A.
At least I'm not on CPF....it would have been $900.
There is a Surefire that looks like the X9 and it's not even XM-L, and it costs almost $900
I don’t see how you can go wrong with the HS-802. If you don’t want even that amount of spill then you need an aspheric in a light with a larger head.
I am thinking about going with the 801 802. is within budget and size.
I didnt know what aspheric was so I looked it up and learned something...
Steve, thanks for the info. I added to my wishlist on deal extreme. Is over my budget.
And I have been on candlepowerforums looking up stuff... if you dont buy a $900 flashlight you arent in the club.. I dont think I phrased this right but you probably understand it. when i saw budgetlightforum I said this is the place to post.
I am in Texas, too and will IM you and you will understand that I use my lights. They dont sit on the shelf.
Hmm, seems I've read here that the newer versions of the TR-1200 are poorly driven. Do you think I could get a good one from Manafont? They sell the body and head separately.
I appreciate your time and effort. I did not write my requirements correctly...
Edit update: want to keep the same size as the uniquefire 802 or 801 and under $30. I apologize for not putting that in my requirements.
I am ok with a larger light and weight but need to keep same size for what I can do with it.
Thanks for your help. Added to my dealextreme wishlist. Is too large for my needs or would buy one like this since I have sooo many batteries to run thru it.
Welcome to the hobby!
You definitely want to stay with single cell lights when using cells that are unprotected and of various brands/capacities/"states of decay".
I recently got a Trustfire USA168 (from Manafont) and the "R2 pill for the HS-801" and I'm getting lux readings that damn near up to the level of my Fandyfire STL-V6 (same as the Skyray STL-V2), albeit a much smaller hotspot. Not bad for $28. :)
You should have a look on the Solarforce Skyline 1, laser-like throw, quality above budget
http://www.internationaltradingcompany.net/product_detail.php?t=LF&s=26&id=123
48mm front bezel....and you got pretty near to the STL-V6. Yes that's about right. The Solarforce Masterpiece Pro-1 (57mm bezel) is slightly above the STL-V6.
I get around 44k from the Fandy and almost 40k from the USA168. Now that’s at unreasonable currents for an XR-E (1.8A)and no regulation, so its not exactly an even comparison. Both measurements taken 15 seconds after turn-on.
I'd like a MPP-1 but I already have a bunch of throwers I never use. I'm a flood guy... these things are just toys I use to see how big of numbers I can get. :)
Thats what I thought after reading about the 2 or 3 18650s in the longer flashlights. stay single cell... but that is what i wanted to buy anyway so it works out.
looked at r2 pill for hs801 what is that?
I don't know about the newer ones. Budgetworks off ebay sells some good ones. That's where I bought my last one I believe for my son. He loves it. But I have bought 3 of them off of ebay from different sellers and all have been about the same. These lights throw a lot better than people would think. A matter of fact if they made the reflector surrounding each led deeper it would only throw farther. That's what they did with the Fenix TK70. And it will come very close I would say to the Olight SR90. Now it may not beat it, but for less than half the price, the TK70 is bad to the bone for throw. I plan on getting one soon. Maybe even for Christmas if I'm good.
sb56637,
I took this one one day last week I believe off the deck from the back of my house. This is my neighbors shed. It's about 85yds away. Even my bright Keygos KE-5 won't light it up this well. This light really is a great thower. Probably one of my best right now. But I have a Olight SR51 coming this week hopefully and a Thru-Nite Catapult V3 as well. I guess I'll be able to find out how the Trustfire TR-1200 compares to some real throwers.
Its the same thing that’s inside the USA168 only it is brass (the USA168 pill is aluminum), has better modes, and is supposedly brighter. (mine is)
Trustfire X9, very good 1x 18650 XM-L thrower can be bought for $37 shipped on ebay.
