20mm quad mcpcb will fit. Quad 24mm Copper TPAD DTP
Triple won`t looks good (to small optics size in such head), but triple and quad optics are same height so triple convertion can be also maken.
Not sure. X6 more yes than no, X5 much more no than yes.
X6 is available for sale as host at many sites, I have some cute-3 optics, spacer is sufficient cheap. The only problem is XP32 mcpcb that need to be sanded in diameter. So both variants (spacer and set) may be sold on ebay.
X5 light is still rare, it doesn`t sold as host, complete lights are to expensive, we still don`t have quad pcb, copper spacer with second part (tube) would be more expensive.
Just got my spacers. Sent same day is I ordered, received 9 days later (Sweden). That’s rather fast, thanks.
I did a test mount and the “#3 Copper spacer for Carclo triple Convoy S2+/S3” works nicely in the pill-less S3.
As I remember, I have sent you the first one that was on photo. If both flat surfaces look frosted, this means that I have tried to polish them. There can be some defects that are lower that main plane, but I don`t think that there can be defects that are out from plane.
Neverless, if you will measure that temperature difference between pcb and spacer (soldered together) with spacer “as is” is several degrees higher than with ideal polished spacer, I will refund you $1 for each degree Celsius.
Do you have any of those copper X6 spacers left?
I don’t worry too much about perfect as I sand and lap all my spacers and MCPCBs anyway.
Ive got four more X6 in the mail so I’d like four or more aluminum X6 spacers as soon as possible.
Afraid I’ve not received my X6 spacer. Ordered 7th March.
Tracking seems to have stopped on the 14th March.
Post of Russia
He is waiting to be sent from Russia
March 14, 2016, 22:01 102972, Mr A ^ MMPO shop Vnukovo-2
Issued by customs
March 14, 2016, 4:28 102972, Mr A ^ MMPO shop Vnukovo-2
Admission to the customs
Arriving at the Russian border
March 14, 2016, 04:08 102972, Mr A ^ MMPO shop Vnukovo-2
Left the sorting center
March 11, 2016, 9:14 347949, Taganrog
Adopted at the post office
March 9, 2016, 11:20 347900 Taganrog
