Thanks TP. Those steel springs do seem quite long to efficiently carry current. I was surprised by your results after adding braid. What an improvement! Do you know of a simple way to get rid of the memory âfeatureâ.
I added some thick copper single strand wire that I stripped from the center of some heavy coaxial satellite cable. I wrapped the strands around a thin steel rod and made a few copper springs slightly longer than the stock ones already in the flashlight. Placing the new copper springs inside the stock steel ones was all that was required before reassembly. No solder required⊠its probably the fastest & easiest mod Ive ever done.
With Tenergy 10,000 mAh D cells. Tail cap measurements 30 seconds after turn-on:
Before: 2.86A
After: 3.32A
Now Im contemplating an AR lens, if I can find one.
Significantly noticeable results for a SUPER EASY MOD. Thanks TP! :bigsmile:
Adding a 3 amp regulated driver would probably decrease the output some since it can do more amps with the stock driver. You would get a better set of modes though⊠I was thinking of sticking a Qlite in one. I put Qlites in the Defiant Super ThrowerâŠ
not bad - I knew i was going to lose a bit of output⊠especially if the cool white in it is a u3 or a u2 (dont know what bin it was though)
losing 15% output is acceptable to me for a nicer tint
the reflector was stippled a few months ago when i bought the light⊠cant find a glass lens⊠i might look into getting some nimhs⊠but the problem is you can never buy 3 of them since they come in packs of two⊠and i have no need for 6
My thoughts on the 3D ArmorMax vs the DST 3C, as I own both: My ArmorMax has a noticeably brighter spot at a long distance and more throw than the DST, but only by a noticeable amount when the beams are both on at the same time and shining side-by-side. In practical terms, these two lights have the same beam range. The ArmorMax however does have a good bit more light output and beats the DST quite easily in a ceiling bounce or at lighting up a scene close-up.
With that being said, the DST does have a more tightly focused hotspot and lower beam divergence than the ArmorMax. The ArmorMax has a wider spot that is quite average looking in flashlight beam profile. The DST looks laser like (I use this term loosely) by comparison, and if I wanted to impress someone, I would definitely go with the DST. Its intense beam profile is just awesome looking, especially shining up into the air! Get the DST if you just want to impress with both the looks of the flashlight and a lightsaber beam.
I posted my comparison pics and reviews of these two in the new Defiant 5C 625 lumen thread.
Ok I grabbed the 3D and the Tactical Super Thrower 3C today, very nice for the money!
The Defiant ArmorMax 3D came with the XM-L U2 is that what everyoneâs is coming with? My star board says XML-U2 other pics I have seen posted just said XML.
I noticed that the 3D 590 lumen Defiant ArmorMax at the Home Depotâs close to my home uses the Cree XM-L2 nowâŠ.at your allâs Home Depot locationâs do they have this light incorporating this LED also?
I ask because I was about to order a couple online because the closest Home Depot to me is about a 40 minute drive and I see alot of folkâs have either the XML-T6 or XML-U2 in theirâs.
Makes me wish I grabbed a few while I was at the stores because now Iâm afraid to order from them online if they have sporadic partâs they use in these lightâs.
I have a couple of last yearâs 3D 650 lumen model with a single mode and XM-L2 in them and they have been amazing durable lightâs just heavy but nice to have a few good lightâs around that use standard regular batteries.
Most of the Home Depots I have been to have this light on clearance for $15
EDIT:
As of today, April 19, all Home Depots seem to now have them at $14.06. That decrease of 94 cents to 14.06 means that they intend to eventually clear them out. If they donât sell at $14.06 the will at some time in the future go to a â3â price. I am guessing around $7.53. Matbe in 6 weeks or so. Keep an eye out for them
I bought one for $14.06 two days ago. Not impressed by the plastic reflector that scratched taking it apart. Maybe with a decent driver and cells it might be a decent light. Itâs definitely the thickest, heaviest host Iâve purchased so far. Can anyone recommend a reflector?
I saw it. The store in my area that had them only had 6 left at the $14.06 price and Iâd be willing to bet they were gone before the price drop. i did buy one so I think Iâm better off setting aside what I would spend on gas for the trip toward the blf srk fet driver and xhp-70 for a 2s4p powered srk style light Iâm accumulating parts for. Currently waiting for a Boruit RJ-2013 style light with no markings to be delivered. The head will be grafted to part of an srk head to distance and insulate the driver from the emitters, increase cooling surface, and help with refinement of the design for the head of my big head srk quad. The thermal step-down will help deciding on cooling fin changes.
I was in HD waiting for the mini Mags to go down and an employee suggested I buy them at the higher price and get refunded the difference when the price goes down.
