Nitecore EA21 - has red light for super low lumens, can start in 1 lumen low mode or turbo from off, side switch so it doesn’t wake up the wife
Also have the DQG Tiny AA stuck to the bed frame as a nice little reading light.
Trying out the BLF A01 Copper but I will probably go back to my Nitecore T0.
Long live 5mm LEDs!
I have 2 by the bed… I have a Thorfire VG10 with stock driver, XM-L2 4C and a GITD with red and orange LED’s, I find them good for sleeping and the ML mode on the VG10 is wonderful. I also have an S2 with triple XP-G2 3C with a very dim GITD tailcap with green LED’s. This is the one I grab if I think I need a lot of light!
Copper BLF A01.
A Thorfire tg06 as my “doing a quick scout of the house light”, and my sunwayman d40a as my “the power is out” candle substitute, with a diffuser on.
amber modded SK68 or amber modded #3 zoomie, and amber modded headlight — for getting around in the dark without waking the household with bright white light.
Something stunning if I need that as backup.
Nitecore sr3
For the same reasons many people mentioned above ……It is very stable face down because of the large wide SS bezel . I never liked knocking stuff over when reaching for a light in the dark .
forward clicky/ variable ring .
Rock solid
LED LENSER A3
Convoy S2+ 18350 blue host w/ Moonlight Special 1+3*7135 driver and Nichia 219b emitter. Low moonlight is perfect to leave running on the nightstand, great tint, 18350 is plenty to run it for awhile and doesn’t need to get super bright.
A big crowbar.
Will make someone see the stars, even if it’s not a light.
Convoy C8, all purpose doing everything light. defaults to moonlight but FET/DD if needed………………
Olight S1
Fenix LD50
Spring bypassed Nitecore SRT7 for my left hand and a heavily modified Glock 22 for my right hand.
Armytek wizard Hi Cri
I don’t have a flashlight on the bedside table, just an RGB nightlight set to red only, behind a chair, and an amber one in the hall. If I need to find something without waking my wife up, I can take the red Inova Microlight out of my shirt pocket which hangs near.
Solraforce L2N with an intl-outdoor P60 (4 mode moon-low-med-high) drop-in from back in the day when I thought that cool-white is cool. With a Keeppower 3400mAh cell.
Olight S15ti on Eneloop. My loo light. The first couple of times I used it I managed to double click -> STROBE
That’s disco fever!
I have a little Xtar WK41 that I put a diffusor on.
On the lowest mode it works just fine :innocent: when getting up in the middle of the night.
Currently have a 47’s X3VN , a modified convoy c8(xml-hi, spring bypass and fet driver)
and my big light is a TK75VNQ Fiat Lux to blind someone with,lol.
