We tested both XML2-U3 and U4 leds with the 6 amp board and they blew instantly. They are however stable and will run continuously at 4.5 amps. XPL-HI will take the 6 amps but only for few minutes then stepdown needed.
Did several runtime tests for both medium and high modes for new 2X and high (360+k) recorded 70-74 minutes, while medium (260+k) recorded 100+ minutes. Batteries for all testing = panasonic/maxtoch 3400 protected buttontops.
Had some trouble getting one panasonic out of 2X when shooting on friday night. Checked later and other panasonics fitted easily - variation was in the battery diameter from panasonic - not a torch issue. Just something to bear in mind.
I am not a fan now of the XPL-HI. Significantly lower lux output than XML2-U3 and U4 in side by side testing (including tests in same light), and its cool white tint blues and washes out color and picture clarity. We tested a BLF-TE 4.5 amp M24 with XPL-HI at about 250k lux. We then swapped a dedomed U4 into this torch and it improved hugely - jumped to 290-300k lux, and with vastly improved colour/picture clarity. If there are any guys who have bought the BLF M24 in recent GB, get Richard at Mountain Electronics to dedome a U4 and put that into it. Makes a fabulous hunter and superb long distance light.
We tested the BLF M24 with a U4 in it (290-300k) beside this new 2X when it had the 6 amp board and XPL-HI measuring 370k, and the U4 M24 was clearly better past 2-300 meters than the higher lux (80k more) 2X with XPL. That cool XPL-HI beam glares alot more but does not travel as well, and in misty conditions the warmer dedomed U4 is much better at cutting through the atmosphere.
I agree Mitko - I’d say about 400gms is max for a hunting weapon mounted light, so the challenge was for maxtoch to produce an extreme performer at just 300 or so grams. 2X is 308 on my kitchen scales. And achieving right CRI colour faithfulness plus picture clarity down range was a big factor for us - we’ve nailed that pretty well too. Also alot of hunters like long runtimes so we set the mode outputs very exactly for hunting purposes. High mode at 360-370k is for super long range scanning. Medium mode is set up at 260-270k lux - huge performance but with 100+ minutes runtime which is ideal. The medium 260-270k with its much improved color/picture clarity and over 1000 meter range is amazing in the field - was shooting with it on friday night, and I very seldom clicked into high. Low range is set at about 45k lux - ideal for possums up trees - this is for the Aussies and New Zealanders
We keep a close eye on new Cree led products, all the leading torch makers etc and I’d say the new 2X is the best all-purpose hunter light ex factory in the world in terms of specs/performance/quality/price. And right with it is that brilliant little BLF-TE M24 with the XPL-HI removed and a dedomed U4 in it - pushed it up to 290-300k lux. I have both and they are legend…
The air was much clearer tonight and got some much better beamshots, The NEW beamshots are now the slide show in the OP if anyone would care to go back and see the better shots. (still not perfect conditions but much better)
The New 2X hit Aliexpress today. Maxtoch will be doing an “introductory” pricing other than what is listed ($93.50 regular price)from what I understand.
Also I am talking with Amanda at Maxtoch about a possible Group Buy for the forum , so unless you just can’t stand to wait a few more days then here is the link with the regular price.
I am not sue how they dedome the emitters, that is something Maxtoch probably does not like to discuss pucblicy, you know like a trade secret.
I am sure they will be done just fine though , as they have been dedoming U3’s for sometime now in the M24’s.
I have been waiting on this light since you and mudgripz were talking about it in the M24 GB thread. This and the Convoy L6 will make for a great combination
Muto,
All I can do is ask if they will sell heads separately and let you know.
This is only my opinion but , I don’t see it saving much to be honest maybe 10 bucks over buying the whole light, and then you have double the wear on the head threads and the tube threads on both changing the tube out.
The 2X started out with XP-L Hi and a 6amp driver in it to achieve the same 360 to 370K lux output that the 4.5 amp with dedomed XM-L2 U4 1A is doing. The 6 amp version also required a stepdown after 2 to 3 minutes where the 4.5 amp version does not. Also longer run times with the 4.5 amp version.
I also tested my M24 with 4.5 amp driver and XP-L Hi in it originally , from the GB I did last year. It also had a signifigant gain in output when the emitter was changed to the dedomed XM-L2 U4 from the HI. the M24 goes from 250K lux to 300K lux with the simple emitter swap.
The U3 emitter will be about 10K lux less then the U4 I think.
Also I am talking with Amanda at Maxtoch about a possible Group Buy for the forum. This would consist of making a list and waiting to get to the minimum number of pieces (not yet determined) to get the GB price. I am shooting for an even lower price than the introductory offer of $88.83 , but I can make no guarantees that it will go any lower than the introductory price is now.
So if you are wiling to gamble on a lower price or the numbers being high enough after this introductory offer , the choice is there, we just gotta decide to gamble on , save 5 bucks now , or gamble on getting enough names for the number of required pieces for a GB.
Best information I can give ya for now folks but I am tryin.
Everything about this light is purpose designed for hunting - head size, tube diameter, light weight, optimized tint for best target picture down range, mode output ratios for different hunting tasks, runtimes, beam balance between throw/flood etc. But … I think its gonna be equally useful as a general purpose outdoors light. The light weight, very big throw, plus some flood will be ideal for that. I use mine alot for walking in the country as well as hunting, and the low mode (about 45k) is great for walking - has beam range out to about 400 meters max, and great for spotting possums up trees
The mode I find most useful though is the medium or hunting mode. This pumps out a whopping 260-265k (more than the Olight Javelot M3X-UT on high), and has great colour picture down range. I very seldom have to use the 365k high beam because medium is daylighting stuff at hundreds of meters.
I am interested to see what Dale, Tom E (who helped in earlier Maxtoch design) and other modders might get out of this light. I suspect 450-500k could be achievable if you are not concerned with runtimes etc.
Note Maxtoch have a remote switch and single batt tube available for this light.
I’ll wait for the GB. If it parallels the last one in size it won’t take long to fill the list, and for good reason. I’ve become nervous with some other manufacturers after seeing GB results but MaxToch impresses me quite nicely.
