I’ve been using Photobucket for over 8 years now. I used to like it. But now, it is laden with video ads that consume bandwidth and wonky Adobe Flash programming that thrashes the browser so badly that it crashes. I’m sick of it!
There are other photo sharing sites out there… so much choice, but hard to know what’s really good. Any recommendations? I recently started with imgur… It’s OK. I like the folder navigation provided by Photobucket. There are some very nice features… if only they the site didn’t have such horrible Flash problems.
No flashy ads or other garbage. I use it exclusively. Nothing more in life I hate than going to read a thread somewhere and finding most or all the images gone.
Quote:
"3) How long will images be left on the server?
You can upload unlimited images per post will never have to worry about your images being removed for inactivity."
Thanks. Looks pretty quick and lightweight. Too bad you can’t nest folders… would go a long way to help organize things (like this: LED-flashlights—>Astrolux, LED-flashlights—>Jetbeam, LED-flashlights—>Nitecore, etc.)
Could someone please instruct me on how to make a mouseover? The instructions in the OP (roughly 3 1/2 year old) apparently no longer apply? Advanced Post Editor toolbar is completely different looking now, I tried Insert/Edit Image - Advanced tab, but nothing there like in the OP’s tutorial
Thanks rc, I tried* but can’t get it to work because I have absolutely no idea what I’m doing
*to try I copied and paste the line of code from SB’s post, then I subbed in the image locations in where it says “URL IMG-1” and “URL IMG-2” but in the preview I only get image 1 and no mouseover.
I even tried to replicate SB’s example from in his post, (I used quote to get the code) but same thing, only the first photo and no mouseover.
If that worked on your browser, just quote this message, select everything between and including the angle brackets, paste it somewhere like Notepad and replace the URLs with your own (be sure to get the whole URL but just the URL, leave the punctuation alone) and Preview the post as many times as you need to test it. You can always quote this message again to start over.
This gives you mouseover and onclick actions so you can add depth. Everything but the onclick should be some compatible image. You won’t win any friends putting an HTML link in a mouseover. But the onclick is what that’s for anyway. Remember to specify your Width, no more than 100%, please.
please add the following css rule for images as they break zooming on mobiles and also looks bad on desktop if the width is below a certain value. thanks
