SKILHUNT H03 H03R led headlamp release, 1200 LED lemens
110 posts / 0 new
SKILHUNT
SKILHUNT's picture
Last seen: 1 day 17 hours ago
H03 headlamp
LED: CREE XM-L2 U4
Max output: ANSI 1000 Lumens / 1200 LED Lumens
Max runtime: Few months
Max beam distance: 123 meters
Max peak beam intensity: 3800cd
Waterproof: IPX-8
Impact resistant: 1 Meter
Battery: 1×18650 , 2x CR123A , 2x RCR123A
Rated Range: 2.7V ~ 8.4V
Dimension:
Length 99.9mm / 3.93 inch
Head diameter 23.5mm / 0.93 inch
Body diameter 21.6mm/0.85 inch
Weight: 44g / 1.55oz (without battery)
Accessories: Headband, clip, lanyard, magnet replace rubber pad, Operator’s manual, Warranty card, Spare O-ring
Operation
Battery installation & Replace magnet:Insert the battery into the flashlight,the battery positive pole toward the light head.
Ensure batteries are inserted correctly, the flashlight will not operate with incorrectly inserted batteries. Ensure when the light turning on,the beam is directed away from the eyes.
When take the light with Bankcards(magnetic) or Cell phone,should replaced Magnet with rubber pad.
Flashlight turning on/off:
When the flashlight was OFF status:
Press the side switch to memorized brightness level.
Press and hold the side switch 0.5 second,to low mode.
Quickly double press side switch to turbo mode.
Quickly triple press side switch to strobe mode.
When the flashlight was ON(any mode) status:
Press and hold the side switch 0.5 second to turn off.
Brightness & mode selection:
Brightness level:
Press side switch to Low-Mid-High-Turbo, cycle.
Quickly double press the side switch to Sub-level(i.e between L1 & L2), turn off memorized the last brightness.
Special modes:
Quickly triple press the side switch to Strobe (S1), then double-click to switch S1/S2/S3 mode, Press side switch back to previous brightness level.
Low voltage indication
When the battery voltage drop down lower than 3.3V, indicator flash twice every 2 seconds. Battery voltage drop down to lower than 3V, indicator flash 3 times every second.
Location indicator & Lock-out function:
When turn off the flashlight, press switch 1.5 seconds, location indicator switch on and lock-out function activation at the same time, Press button onl can switch the indicator on/off.
The indicator light flash every second, locate the flashlight, easy find the flashlight in the dark quickly. Hold press the switch 1.5 seconds, switch button unlock and enter into low mode.
Features
Super bright & latestCREE XML-2 U4 LED, Max 1200 LED lumens. High-Performance, High-Efficiency and energy conservation.
Bead surface lens ,wide and uniform flood beamshot.
Flat tail cap with strong magnet to secure to ferrous surfaces.
Rugged indestructible aluminum body with anti-scratching type III hard anodization
Multi-level dissipating heat design and thermoelectric separation
copper star-board, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity.
Side switch button to transferring mode user-friendly interface to adjust output.
Eightoutput levels and three Strobe, suitable for different environment.
Wide input range provides more choices of batteries. High efficiency driver circuit, no visible flash in any mode.
Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
Reverse polarity protection, to protect from improper battery installation.
Low-voltage prompts function, the light will flash when the battery is low,remind user replace the battery on time.
Engineered anti-slip knurling for a tightly firm grip.
Dual recoil absorbingsprings, better impact resistance.
Tail stand as a candle-light.
New intelligent temperature control technology for headlamp stable and safe use
Low standby current below 0.5uA
New side switch lock-out function.
http://www.skilhunt.com/product-deta…-led-headlamp/
The Miller
The Miller's picture
Last seen: 2 years 1 month ago
Wauw looks good!
Nice UI
And those optics look like they eliminate a hotspot making it a nice work light.
rafalklis
Last seen: 3 months 4 days ago
Very nice headlamp. Low weight, short, Low-voltage prompts function, temperature control technology Thumbs Up
I want one.
zelee
zelee's picture
Any NW tint version?
beam0
beam0's picture
Last seen: 14 hours 19 min ago
Nice, can I trade in my defective H02? (bad driver)
I contacted Skilhunt and here was their reply:
“Please try to tighten the aluminum ring that fix the driver.
If still not work, please contact the dealer that you purchased from to get warranty.”
Well I tightened it but it still not work, and the dealer is Gearbest.
Bought it in March last year so it’s well within the 24 months warranty period. But the warranty covers replacement only for the first 15 days, after that it’s “Free repair” (but labor only!) customer pays for parts and shipping which would probably be close to or more than I paid for the light.
Maybe cheaper to replace the driver myself but I’d have to fiddle around with making a contact board (original driver is 20.9mm dia.)
If you search on here you’ll find others who have had driver issues with their H02.
I like the upgrades on this new H03, great to see it has a copper DTP MCPCB, maybe it allows them to drive it a little harder for those extra lumens.
I hope they made the driver more reliable. And make a NW version. I’d give them another shot if I could get some satisfaction for my issue with my H02.
The way I see it having to pay for parts and shipping pretty much makes their warranty 15 days, not 2 years.
Skilhunt please post or PM me with a solution!
will34
will34's picture
Last seen: 1 hour 10 min ago
Very nice looking headlamp, UI is perfect EXCEPT for hold to OFF
eebowler
eebowler's picture
Last seen: 1 week 3 days ago
Am I understanding the UI correctly: From off, pressing the switch for 0.5 sec will turn the light on in low mode?
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
Firelight2
Firelight2's picture
Last seen: 34 min 23 sec ago
This is a 1200 “lemen” light?
Are lemens related to lemurs? Innocent
will34
will34's picture
I believe its lumen in french Smile
Martini
Martini's picture
Last seen: 10 months 3 weeks ago
Looks like another winning headlamp from Skilhunt.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
beam0
beam0's picture
Yes that’s what I’m seeing, and that’s how my H02 works. (when it was working Flat Stare )
On this H03 a press and hold will bring you to Low 1, and from there it shows a double click brings it up to Low 2, or another press and hold brings it up to Med 1.
It looks like the same UI as the H02, with 2 stages added to every level, and you double click to move up to the 2nd stage within each level. And press – hold again to advance to the next level. Double click to Turbo from off.
beam0
beam0's picture
Note that 1200lm is LED Lumens, (which really has no meaning except marketing?)
And the ANSI 1000lm rating is only with 2xCR123A
It’s rated 900lm ANSI on 18650 Li-ion, (which I assume is what most of us would use) Not to say 900lm isn’t bright but until I took a good look at the specs I was under the impression it had 1200lm.
H02 is 960 LED Lumens / 820lm ANSI, so H03 is only slightly brighter than H02. But H02 was very bright indeed.
Also this H03 is 10mm shorter than H02, so a big size improvement there over the H02.
Tom E
Tom E's picture
Last seen: 16 min 22 sec ago
beam0 wrote:
Nice, can I trade in my defective H02? (bad driver) ...
I'm working on upgrading my H15 to a FET+1 that will utilize the LED's in the button - to run the latest Narsil with smooth ramping. It's gonna get a decent NW XM-L2 on a Noctigon - the stock MCPCB is typical aluminum in the H15. I'm using an XM-L2 because the optics are made for it.
Mine also is the 21 mm driver, but a 17 will fit in there nice on top of the 21 stock driver - I've wired it up for multiple grnd contact points already.
The smooth ramping UI and pure power should be awesome in this light. What I like is the surface the MCPCB sits on is all one piece with the body, and the cooling fins are directly connected and behind that surface - best direct connection to outside heat sink fins I've seen. Of course it's a small 14500 (AA size) light, so I'm sure it will get hot at 4.5-5A, as I'm expecting to get.
eebowler
eebowler's picture
Thanks beam0 Smile
lionheart_2281
lionheart_2281's picture
Last seen: 11 hours 3 min ago
I agree, the press to turn off is awful!!! Why can’t it be press and hold to CYCLE and click to turn off?! Apart from that I still love my H02, but the UI gets me every time.
Nicolicous
Nicolicous's picture
Last seen: 11 months 3 weeks ago
seems like a good price and Im giving it a go as my first skillhunt light.
I have been collecting Zebralights for years and have almost all models but decided time to break the ice with other brand now as Zebralight is just way too expensive.
Anyone have any info on the low mode runtime?
Nico -.-
beam0
beam0's picture
Tom E wrote:
beam0 wrote:
Nice, can I trade in my defective H02? (bad driver) …
I’m working on upgrading my H15 to a FET+1 that will utilize the LED’s in the button – to run the latest Narsil with smooth ramping. It’s gonna get a decent NW XM-L2 on a Noctigon – the stock MCPCB is typical aluminum in the H15. I’m using an XM-L2 because the optics are made for it.
I’d like to do something special with my H02, like an MT-G2 or XPH50
Tom E wrote:
Mine also is the 21 mm driver, but a 17 will fit in there nice on top of the 21 stock driver - I’ve wired it up for multiple grnd contact points already.
Thanks tom, yes there’s a lot of room in the H20 above the horozontal board, guess I’d have to remove the vertical board and clear all the components off to make it into a contact board. Mtn. Electronics lists a 21mm contact board but I’ve never seen it in stock since I’ve been looking, I’ve yet to check FT or others though.
Too bad they didn’t make the head sidewalls just a wee bit thicker and that driver shelf could have been wide enough for a 20mm, on the H02 the driver ledge is about 21mm. also thought about grinding down the edges of a 22mm driver but I’m not sure there would be enough of the grounding contact ring left? And the 22 is FET, not FET+1.
Tom E wrote:
The smooth ramping UI and pure power should be awesome in this light. What I like is the surface the MCPCB sits on is all one piece with the body, and the cooling fins are directly connected and behind that surface – best direct connection to outside heat sink fins I’ve seen. Of course it’s a small 14500 (AA size) light, so I’m sure it will get hot at 4.5-5A, as I’m expecting to get.
On the H02 the MCPCB surface is also one piece with the body, but attached only on the sides, and unfortunately there are no cooling fins. Behind the surface is just wide open space, a second cavity with the surface being like a separator in the middle of the head, and the surface is quite thin, it looks about the same thickness of (or slightly thinner than) the stock MCPCB, about 2mm or less. I haven’t dug into that area yet but at least it appears the MCPCB is nicely secured with 2 screws.
Is there a FET+1 driver off the shelf that will run the LED’s in the button? Or did you custom build one for that?
It really looks like this new H03 would be an excellent candidate for a FET driver swap, especially if the MCPCB surface is directly connected to the cooling fins like your H15. It already has the copper DTP so just drop in a FET/DD and you’re ready to blaze!
beam0
beam0's picture
Just checked and NW is available on the Skilhunt site!!
GB has these listed now on Pre-sale, someone please give us a discount code deal!
EDIT- GB not listing NW version Sad
Well on the chart in the OP it shows Low2 (3lm) is 450hrs. on 18650, but no spec shown for Low1 (0.5lm) but I assume double the Low2, so maybe 900hrs??
beam0
beam0's picture
Check this out:
H03F, “F” for Flood? (looks like a Mule set up with a flip open cover)
It’s shown at Gearbest but no mention in the OP and I don’t see it on the Skilhunt site.
But again no NW version listed.
Tom E
Tom E's picture
huh? Wow, that's unique! Tha green look' square around the LED is throwing me off - looks like an old XML
bugsy36
bugsy36's picture
We have to wait but I will get us a code. Keep in mind that they will not be at the blowout pricing that we've been seeing for the H02...which is a steal at the moment.
It would be nice if Skilhunt has started potting their drivers and offering replacement drivers (not under warranty) to repair those that have stopped working from getting dropped which is not a manufacturing defect.
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
beam0
beam0's picture
In the photo on the left the cover appears slightly transparent, but in the other (open) photo it looks like a solid plug.
This gave me a great idea (maybe) if the swing open door was a TIR optic instead, then you could have the best of both worlds.
The swing open TIR “door” could be o-ringed for water resistance during use when closed.
djburkes
djburkes's picture
Last seen: 4 years 2 days ago
I’ve got an H02 and love it, I’m sure the H03 will be awesome too.
pilotdog68
pilotdog68's picture
Last seen: 8 months 3 weeks ago
Both of these pictures look like computer renders (which may be obvious but thought I’d point it out). So It may be hard to get a consistent opacity to the generated optics, etc. It may also explain the old green square around the LED.
looks interesting though
dekozn
10mm shorter than the H02, will it still be able to hold the 3400mAh Panasonic NCR18650B cells?
The H02 I got had an other headband than pictured and it’s too small for my head.
I know it’s a minor detail but for a headlamp a decent headband is a must. I don’t have a particular large head, I mean if a use a headlamp from a friend I find that most of the time I have to make the headband smaller. So most of my friends won’t be able to use the H02 just because of that and even for me it’s way to small. I ordered an ultrafire headband, hope my H02 fits.
Idiot proofing something only creates improved idiots.
MountainKing
Last seen: 4 months 1 week ago
Too expensive…Need lower pricing!
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
Mr.Scott
Last seen: 4 months 17 hours ago
What is the difference between the H03 and the H03R?
Thanks!
Mr.Scott
Ok, after a little digging I see the difference in the light. How different is the beam?
charles lin
charles lin's picture
Last seen: 1 month 4 weeks ago
Mr.Scott
bugsy36
bugsy36's picture
The "R" has a very very noticable spot. If you like being able to see a defined spot or will be using this in outdoor applications like hiking and camping then you probably want the "R".
I use my H02 primarily indoors so I do not prefer the reflector version in my application. Even when I am working outdoors I have grown accustomed to the TIR.
My coworkers prefer the R and other reflector equipped lights because they like that concentrated spot.
Hope this helps
