H03 headlamp
LED: CREE XM-L2 U4
Max output: ANSI 1000 Lumens / 1200 LED Lumens
Max runtime: Few months
Max beam distance: 123 meters
Max peak beam intensity: 3800cd
Waterproof: IPX-8
Impact resistant: 1 Meter
Battery: 1×18650 , 2x CR123A , 2x RCR123A
Rated Range: 2.7V ~ 8.4V
Dimension:
Length 99.9mm / 3.93 inch
Head diameter 23.5mm / 0.93 inch
Body diameter 21.6mm/0.85 inch
Weight: 44g / 1.55oz (without battery)
Accessories: Headband, clip, lanyard, magnet replace rubber pad, Operator’s manual, Warranty card, Spare O-ring
Operation
Battery installation & Replace magnet:Insert the battery into the flashlight,the battery positive pole toward the light head.
Ensure batteries are inserted correctly, the flashlight will not operate with incorrectly inserted batteries. Ensure when the light turning on,the beam is directed away from the eyes.
When take the light with Bankcards(magnetic) or Cell phone,should replaced Magnet with rubber pad.
Flashlight turning on/off:
When the flashlight was OFF status:
Press the side switch to memorized brightness level.
Press and hold the side switch 0.5 second,to low mode.
Quickly double press side switch to turbo mode.
Quickly triple press side switch to strobe mode.
When the flashlight was ON (any mode) status:
Press and hold the side switch 0.5 second to turn off.
Brightness & mode selection:
Brightness level:
Press side switch to Low-Mid-High-Turbo, cycle.
Quickly double press the side switch to Sub-level(i.e between L1 & L2), turn off memorized the last brightness.
Special modes:
Quickly triple press the side switch to Strobe (S1), then double-click to switch S1/S2/S3 mode, Press side switch back to previous brightness level.
Low voltage indication
When the battery voltage drop down lower than 3.3V, indicator flash twice every 2 seconds. Battery voltage drop down to lower than 3V, indicator flash 3 times every second.
Location indicator & Lock-out function:
When turn off the flashlight, press switch 1.5 seconds, location indicator switch on and lock-out function activation at the same time, Press button onl can switch the indicator on/off.
The indicator light flash every second, locate the flashlight, easy find the flashlight in the dark quickly. Hold press the switch 1.5 seconds, switch button unlock and enter into low mode.
Features
Super bright & latestCREE XML-2 U4 LED, Max 1200 LED lumens. High-Performance, High-Efficiency and energy conservation.
Bead surface lens ,wide and uniform flood beamshot.
Flat tail cap with strong magnet to secure to ferrous surfaces.
Rugged indestructible aluminum body with anti-scratching type III hard anodization
Multi-level dissipating heat design and thermoelectric separation
copper star-board, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity.
Side switch button to transferring mode user-friendly interface to adjust output.
Eightoutput levels and three Strobe, suitable for different environment.
Wide input range provides more choices of batteries. High efficiency driver circuit, no visible flash in any mode.
Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
Reverse polarity protection, to protect from improper battery installation.
Low-voltage prompts function, the light will flash when the battery is low,remind user replace the battery on time.
Engineered anti-slip knurling for a tightly firm grip.
Dual recoil absorbingsprings, better impact resistance.
Tail stand as a candle-light.
New intelligent temperature control technology for headlamp stable and safe use
Low standby current below 0.5uA
New side switch lock-out function.
http://www.skilhunt.com/product-deta…-led-headlamp/
