I’m scrapping a 3-year old ASUS ultrabook that bit the dust, and I found it had (2) flat Li-Polys, and the pack was marked as 7.4v 5100 mAh. Trying to think of a good use for those. Maybe build emergency area lights around each one? Anyone try to use these flat cells or have any other good uses in mind?
acer chromebook packs also contain sanyo purple 16650.purple are 4.35v?
I had my first successful laptop pull
I opened 3 Lenovo L11S6Y01 rated at 10.8V and 4400mAh. The ebay seller said they won’t charge any more in the laptop. That was strange since they are not old at all (manifactured in April 2014). Each of them contained 6 Sanyo UR18650A.
In 2 of the 3 packs all cells had 3.66V. I did a discharge test with my Opus BT-C3100 at 1A and they all hold more than 2300mAh (they have a cut off voltage of 3V but the Opus discharges to 2.8V). All have internal resistance <100mΩ.
In the third pack all cells were at 2.53V. I must have shorted one pair while I took them apart since one pair was at 2.3V suddenly. I gave them a try and they also have more than 2300mAh and less than 100mΩ.
So there was no bad cell in 3 battery packs. Pretty strange…
I got a pretty good score today.
A bunch (8) packs labelled Dell 97Wh Type M5Y0X
Inside each are 9 x 3000mAh cells - some LGABD11865 and some ICR18650-30B
Preparing to do discharge tests. All came out of the packs at 3.8 - 4.2V
Got 2 packs, after prying them open I got 6 samsung icr18650-26c and 6 ‘n18650 t25l l19r1 18073’, what looks like to be DLG’s? Never heard of those, think that they are some Chinese brand. They came out a non-original replacement pack.
The dlg’s where at 2.4/2.7 volts, they are being charged right now. Unfortunately the Samsung’s are around 1.9 volts, I’ll try to charge them carefully, I hope they’ll recover…
Amazingly, after digging into two laptop batteries I had at home, I started looking in the Lowes and Home Depot battery recycling bins and, after about two weeks and four battery packs (and one was completely dead - all 5 batteries were at 0v and wouldn’t even register in a charger) I now have about 25 good working 18650 batteries with probably 15 more waiting in two more 18v battery packs, a double-sized Ryobi and a regular-sized Husky. I’m not even anxious to get to them. I had to get a special plastic container to store them in and since I don’t have any Ryobi or other electric tools I’ve stopped checking in the bins. All due to reading this thread. Thanks.
Just cut my hands and lost an hour prying open dead Asus G73 battery pack. Pulled out 8 LGDBB31865 2600mAh cells. 6 of them at around 0.1V, 2 at 2.884V. HKJ rated them as very good cells back in 2011 with 1.5C max discharge rate, I suppose they are safe to charge?
I’d charge the 2x that came out @2.884v and expect them to have some life left in them, though probably at significantly reduced capacity given the state of the other cells in the pack. I wouldn’t do anything with the others except put them in the nearest electronics recycling bin.
That’s what I had in mind, thanks. Good enough to power some electronics projects I’m planning or LB zoomie.
Some of my battery pulls.
Don’t know from which laptop packs anymore…
On all of them I have used dremmel to clean remains from poles and all double heatshrinked because some had minor damage on heatshrink and I wanted to be safe.
Wrote numbers and capacity (tested by Lii-500) before heatshrinking.
Got this from a friend :)
A lot of testing to do :)
EDIT:
Here are specifications:
Acer AL10B31 ___ 6x Sanyo UR16650ZT
Acer AS07A75 ___ 6x Samsung ICR18650-22F
Acer AS07B51 ___ 6x Panasonic CGR18650CG
Acer AS09A31 ___ 6x Sanyo UR18650A
Acer AS10D51 ___ 6x Panasonic CGR18650CG
Acer UM09H36 ___ 6x Sanyo UR18650ZT
Asus A32-K52 ___ 6x Moli ICR-18650H
Dell 127VC ___ 6x Samsung ICR18650-28A
Fujitsu CP033616-01 ___ 9x Panasonic CGR17670HC
HP HSTNN-IB88 ___ 6x Samsung ICR18650-22F
HP HSTNN-LB09 ___ 6x LG LGDS218650
HP HSTNN-OB88 ___ 6x Sony US18650GR
HP HSTNN-YB0W ___ 6x Sanyo URI18650A
IBM 02K7054 ___ 8x HKGFHT5 032397 and engraved ih shrinkwrap H49A ???
Toshiba PA3534U-1BRS ___ 6x Panasonic CGR17670CE
Wow, you have nice friends.
Hey xxxman
When you tear a pack apart write down the manufacture the model 3 and what cells came out of which pack . that was / is still the reason for this thread . the info will possibly be helpful to another member .
Great pic with lots of pretty colors
i see sonys sanyos lg’s ….purplr panasonic 16650’s /17650’s probably from a sony laptop pack( thought it kind of odd to find pannasonic cells in an oem sony laptop pack )
i have a ton of packs that dont work in laptops.
good ones are saved to fix up laptops we get in and refurb.
but these “bad” packs are going to get torn down once we get this big board build done.
btw most packs are built by companies who specialize in such.
i had an oem sony pack that was new but the latches were broke.was built by simplo.had panasonic 3100’s in it.12 of them!
i wish i had the idea to log the info here.talk about a winner!
Will edit post with specifications later, I just have to take piece of paper where I wrote it from my garage. :+1:
When uploaded pictures I realised I forgot to take it with me and it was too late to go get it :person_facepalming:
Very nice thread. Didn’t know it existed.
My last batch was not as worthwhile as past finds. Had 6 die on the charger and several red ones (no markings) generate too much heat to feel safe using, charging @ 0.5A. Have yet to check capacity of the survivors of this batch.
Previous batches were pretty successful with most rate over 2000mAh and 10+ up to 2700mAh.
Will certainly take notes from now on to see if there is info I can offer.
Have used and upgraded several items around the house.
Shark 20V hand vacuum
Portable O2Cool fan
Harborfreight 3W spotlight to 6 cell.
Just install a 5.5X2.1mm connector and use my balance charger on them.
3100’s as in 3,100 mAh You sure about that?
Twelve of them would be 137Wh, which would be well over the 100Wh limit placed by various safety regs.
Edited previous post (one with pictures) with information about cells.
Any info on cells with this markings?
Look similar to some Sanyo I have but no info…
Got 5 more dead HP packs from a friend so more pictures soon
New here but I pulled 6x Samsung ICR18650-26D 2600maH out of a Dell PT434 and it read 11.1v 56Wh manufactured Feb 2009
Is anyone else getting charged from their local bulk e-waste centers for these old laptop batteries by the pound? They told me they could sell it to me for $1.20 per pound because that’s what they sell it to scrappers for or so they say. This is the only e-waste center for at least 30 miles and majority of the corporations send their packs to them so they do have many newer ones. That breaks down to less than $1 per 6-cell pack. Is it worth it?
hp td09
9 samsung icr-18650-28a.
lilac.
btw a battery shop near me gives me tool and laptop packs.
they do not have a buyer for them in less than container loads.
and everyone there uses 18650 now.i make sure they have a lifetime supply and a good charger.
they even make sure that any battery device they buy can use 18650 natively or i can mod it to.
talk about spreading the disease!
