Nice work Khas, the spot does indeed look more intense and defined. Cool!
I just got through messing around with an old 3D MagLite that I’d modded before. I put a press fit copper heat sink in the top of the battery tube quite a while back with a COB on it. Using 3 26650’s to drive it from a Zener modified 7 mode driver the COB didn’ t like level 7 and would go blue very quickly. The tint was warmer than I like anyway, so today I pulled the COB and put 3 XP-L HI on the big copper sink, wired in series to run the 3 big cells. I used a Ledil Laila 50mm triple optic, kind of a bugger getting everything lined up but the beam profile looks nice so I’ll take it. 4400 lumens out the front.
Eight out of nine posts from PhilipSmith are Tank spam and the other one is only two words that have nothing to do with the thread topic.
hmmmm, what did I mod today, nothing flashlight related just put together a holder for welding glass to go on the front of my camera lens for long exposure photos :sunglasses:
I got some 26350 cells yesterday. I modded a supfire L5 with an LD-2 driver and xhp70. Haven’t finished yet, I screwed up the switch retaining ring trying to remove it. Also you might note the led is off centre, I did this intentionally to reduce the donut hole.
The next item on my DIY driver wish list is an Attiny conversion for the ax2002 buck driver boards. HQ’s boost boards fill that other side already. That would give us an inexpensive 1A boost and 1A buck driver both with programmable modes.
Installed a17mm MTN FET driver in my Manker E14 and used the BLF A6 driver in my Trustfire mini 02 triple XP-L.
I also modified an Xtar MC1 Plus with a voltage indicator and changed the sliding internal current switch to an external clicky so i can control whether it does the 500mA or 1A charge rate.
Normally this charger only charges cells longer than 53mm with the higher current setting.
I find this useful if i want to charge a 16340 or 18350 IMR cell a bit quicker.
CRX, your mods are the coolest IMO.
Simple, yet effective, useful and always well realized !
Your passion for epoxy glue, neodymium magnets and tidying everything up really reminds myself
I wish I had more free time (well I used to) to keep modding everything like you do.
I recently read why you got so much free time, so it helps to put things in perspective.
Keep modding, you give me ideas that I may have the time to realize one day
XP-G3’d my Lumintop Tool. Mounted on a 11mm copper sink pad with a little bit of MX4 for thermal compound. Just love it now. Does seem brighter and nicer tint then what came with the Tool.
Going to use the original xp-g2 from the Tool mount it on copper and use it to make a P60 @ 2.28 AMPs
My first flashlight mod in 3 years so I thought i’d start with working on my smallest lights. Seems my soldering has improved lol
Had to Trim the Plastic centring ring on the sides because they covered the wire pads
Stove in the background is my official new reflowing station LOL
I modified a piece of Gr 2 Ti into a Skunk beacon Saturday.
(tempting to leave it at that for curiosity sakes…)
Working on an upgrade to a Ti flashlight I built recently I was removing the large piles of Ti cuttings and placing them behind me. The Ti has a way of staying in one piece throughout the cut, sometimes going below the cutting insert and sometimes curling around and piling on top of it. Luckily I had dumped my catch box and only had a small amount of shavings in it, as some of the Grade 2 Commercially Pure Titanium stacked up on the cutting tool and caught on fire. I knocked it off the work piece and it fell into the box below, only to catch it’s contents on fire as well! My cutting oils and a gallon of WD-40 were right there, so the box had to be removed… singed the hair of my hand as the flames rose to about 2’ tall with the new ti cuttings catching fire but I got it out the door onto gravel where it could safely burn itself out. Moments later, flames still going and smoke drifting, I’ll be danged if a skunk didn’t walk right past the box and come into my shop! It totally ignored me (must be related to my wife), wandered back behind me towards the front door. I had no choice but to vacate.
I guess there were some copper cuttings in the box as well, the flames got low and the box burned away, leaving some small orange flames with a brilliant emerald green flame mixed among it. Beautiful really!
Crazy stuff. I wasn’t even using oil or cutting fluid at the time so it was pure titanium overheating and catching on fire. Who knew?
Wow Dale, that sounds like a lucky escape! I’m glad you’re alright (and the house and your indifferent wife, don’t tell her about this or she might become less indifferent )
Modified my Olight i3s and Convoy s2+ with XPL’s but that s2+ mod might end up in “What did you BREAK today?” it turns out reflowing 3 LED’s at same time it is more difficult that i imagined when you don’t have proper equipment.
I changed the stock CW XP-G2 LED that was in the i3s with something a bit more warm, XPL V3 5A3 4000-4135k and it turned out to be very nice, it is my first 4000k flashlight and i know for sure that i will buy some more, seems like this little guy is goin to be on my car keys for a long time now.
I wasn’t in the mood for lights today (I know blasphemy, right) but I did make up a thread stop for my lathe. I’ve got the basics of it, it just needs some refining.
