Awesome!! no problem for the H03 cap being longer, that’s a good thing actually!
As you can see the H02 threads are a lot shorter than on most other lights… in the pictures you see H02 head and cap + Astrolux S1 short tube. I doubt the H03 tailcap would be long enough to cover the oring on the S1 tube but no problem for that, I have a spare tube that I’ve planned to mod for that purpose.
I believe the cap from the 03 will come very close to that oring. I can check later today. I have a short tube with h02 head as well. Right now I’m using that cap from a 503b and it covers up the oring. But no magnet.
Yes, the 503 b fits and covers the oring. I don’t care for the look though. I checked the 03 cap on the astrolux short tube and it goes up to about the center of the oring where you have it place. However, the oring can be moved to the slot right after the threads and the 03 cap completely covers the oring and it fits and looks nice.
No problem. I can’t give much more information though. I showed it to a friend and… Well, I have no more light. I do have another one. I will be trying to open that up soon. Hopefully I can repeat the results without collateral damage.
ye i know what you mean,
i love mine, it’s light, bright, but dam that strap is tight, so much that it leaves an impression on my forehead when i take it off
one other thing is the battery compartment,
dam is that small
here’s my non edited review (so it may look like poop )
size considerations
depth of battery holder/sleave 071.93 mm minus the spring (their are some tiny components on the pcb, probably about 1.2 mm in height at one side)
depth of battery holder/sleave to spring 066.62 mm (uncompressed)
negatives:
strap is a bit tight, and i only have a small head, although it’s still reasonably comfortable
battery compartment could have been a few millimeters bigger for larger protected batteries without compressing the spring to much
Some of the Batteries i’ve tried
samsung icr18650-22e sdi 64.88mm (non protected from a laptop battery someone left at the house) fits best
xtar 68.99 mm
skilhunt mm 69.71
the skilhunt BL-134 3400mAh sticks out by 3.65mm (spring uncompressed) although it does fit with a squeeze
final thoughts
a well made light, very bright, very light weight, wide angled beam which is great if you need to light up a large area no noticeable hot spots (neutral white version)
turbo is insanely bright
9.5/10
i might buy another
Ah, yes, the threadlocked H03….
Well, i ruined my battery tube, but i got it off…
Does SKILHUNT communicate here or just post new models?
Because it would be awesome if they sold a 18350 tube for the H03.
I have a Asrolux S1 BLF A6 shorty tube now, and it’s even cuter than the Olight Nova thingy, but it could be better.
Threads don’t match perfectly and i can’t put on the clip. [edit] i use the 18350 tube of my Astrolux S1 now and it fits perfectly [/edit]
Maybe i can construct a shorty tube from the remains of the stock battery tube, but a real Skilhunt 18350 tube would rock!
By the way, the H03 is a great light.
It’s smaller and better looking than the H02
So, I want to bite the bullet on getting a few H03Rs to mod. The loctite on the head treads still bothers me. Does anybody have further comments on this? I’m not feeling comfortable having a 50/50 success rate on opening them up? Its 1 thing getting them open and spending time cleaning the thread, its another thing spoiling the thread.
If you heat the body there is no failing if you dont do anything stupid
The tube has flat sides so you dont need force to depend on grip of the knurling, resulting on crushing the tube
If you use a bench and small wise its really easy to open up
The head has flat sides as well easily get torgue applied
I used this to hold the tube with wood pieces to protect the tube in a horizontal orientation
And this to grip the head with cardbox to protect the head
