Can this driver utilise e-switch? because there is a soldering point with “Key” printed beside? (Presumably other lead would be soldered to ground but I am not sure, that would be 8.4V thru teeny tiny e-button)!
So with 1.5A you get about 2000 lumens. But the XM-L2 can be driven at 6A with copper DTP, resulting in about 1600 lumens or so? A few hundred lumens less which is not so visible, but the smaller die results in (much) higher lux values with the XM-L2 or not? So what makes this LD-51 driver so interesting?
I’m not sure of the exact numbers but you have to convert the power usage to watts to get a better perspective. If the XHP35 is a 12 volt led, 12V x 1.5A = 18 watts.
XML2 leds will only go to a max of 5 amps these days. 5A x 3.5V = 17.5 watts.
I suspect that this is pretty much comparable to what I did. With a comparable efficacy this results in higher lux values for the smaller die XM-L2 with comparable lumen values. So what makes the XHP35 emitter interesting?
Its lumen output /the auto industry (mainly due to its working voltage)/oveall 12v applications: at 12v you can straight use it with a siple resistor as a driver
Thanks for your input. But I meant what makes the XHP35 emitter with this particular driver interesting for flashlights. For instance, I want to do some emitter/driver swaps with my Convoy L6. Why would I use this driver with the XHP35 emitter, if I can have an XM-L2 at around 5A resulting (I think) in slightly less lumens, but much higher lux values?
Its all about marketing m8, a good binned V6/U4 will give you nearly 1900 lumens output and way better candelas, yet companies use XHP35 cause its new, have more lumens at its default values that XML/XPL and will bring aditional sales
Most of those companies used and are still using Cree XB-H for the same reason: its new, atracive…and they all need your money
Ofc XHP35 is way more usable in a flashlight than XB-H yet its main idea is different
But also great throw has been achieved with xhp35, like Acebeam K70 and Thrunite tn42 (But ofcourse these flashlights can throw way better with smaller dye leds , like xpl / xpg2 dedomed)
Hmmm…. So I’m not convinced about this driver then. It seems that the XHP35 is only more interesting for flashlights, if you drive it harder to get more like 2500 lumens like with the Acebeam K70 to step up the lumen game compared to XM-L2. And as you indirectly mentioned, if yo have a 3 cell host, then you could direct drive the XHP35. But that will result in quite some more amps than 1.5 that this LD-51 driver is pushing.
Dont be, i got 5 of those, already modded an L2 host( with 5mins machine work ofc) with 2 x 26350s ,this driver and a D4 1A binned emitter - viola,2000 lumens 228k cds lovely flashlight, quite pocketable too: it has a huge halo also: great as an offhand hunting searchlight or something simmilar
at 1.5amps the torch is runing an idea cooler than a hard puched V6 one
Yeah….personaly i am quite impatient for it to be shipped Will dismantle it asap, that huge reflector needs atention!
