Good point. Thanks.
I care the quantity simply because our 60W 6 port seems to fulfill all the expections you mentioned but best sellers always fall on the 2-port (of other brands like Anker, iClever). One of our customers told us he only used our 6 port when travel with family and he prefered 2 to 3 port.
I have communicated with other customers and received so many different answers. So I started this poll, hoping to gather more data to better analyze.
Thanks again.
Thatās really a bold proposal. :+1: But till now, I have seen no typical product of any famous brands having both two functions, and more important, both functions can be performed equally and perfectly.
I guess it will be a big boy if itās possible, right?
I will communicate this idea to our engineers and see whether we can make it. Thank you for your advice.
You speak out the same puzzle I have. I always wonder what people will do with those 12 ports. But search ā12 port USB chargerā there will ba aboudant sellers and they do have sales, even Anker has a Powerport 10 with 10 ports.
In fact, we will not consier more than 6 ports at present, but since itās a poll, I guess itās better to take more peopleās special needs into consideration.
Thank you.
We really appreciate HKJās hardwork on reviewing products with so excellent insights. His review for our CU6 is really professional and helpful. He is absolutely the first reviewer from whom I would like to see our product review.
Four ports usually is enough for daily use but not more than six . Please allow spacing of one USB port space between each of the four ports for easier plugging in and removal of USB plug. ( most of the multi ports charger are of the standard spacing type )
Also, a switch on the back, a small one, like the Tronsmart Titan has. When not in use, you donāt have to unplug it, just switch it off.
And oh, 6 ports is enough, with at least 2 QC3.0 ports.
In new charger please pay attention to EMI/RFI switching power supply generate. Use proper filtering on primary and secondary circuit etc.
Iām ham radio operator and 90% of chargers or switching power supplyās are pain in the ass, because it generate huge amount of radio interference can be heard in ham/CB even FM radio in car or home.
Besides I would like to have on/off switch, 4 USB ports with at least 1 QC port.
+1. Great Idea. Even though the Allmaybe CU6 uses very little power when it is connected to the mains, but isnāt charging any device, it would be nice to have a switch on the back to be absolutely safe.
I also agree that 6 ports is enough.
Edit>> I canāt vote 6 ports *and *at least 1 QC3.0?
Everyoneās use case is different, and we all think ours is the ārightā one. :sunglasses:
I have a couple 5 port BlitzWolf chargers, one with a quick charge port and one without. I think if you are making a new charger, QC ports (at least a couple) are mandatory. Having extra space so a USB meter can be used on any given, or even adjacent ports is a very good idea. I would prefer that the power supply have a standard power cord rather than a wall wart brick so I can plug it in and keep it on my desk without finding space for another transformer. If you do use an external power supply, please use 12VDC in, with a center positive, āstandardā connector. By doing so, it could fairly easily be used in a car, boat or anywhere a 12V deep cycle battery might show up.
USB C capable seems like it is where the industry is going, I donāt have anything that needs it yet, but if it is backward compatible with USB 2 & 3, go for it.
Having the charger be functional as a high speed USB hub would be absolutely marvelous, and I would buy one immediately right after HKJ approves it, and probably 3 or 4 more soon thereafter. I work with several High School competitive robotics teams (FIRST) and being able to (quick) charge multiple devices between matches while still using them to program changes and debug would be very helpful.
An onboard power switch with LED indicator would also be nice.
To Minimoke: Thanks for your advice, quite practical.
To Maukka: May I further ask, if there is a LCD screen on the charger itself displaying charging current, voltage and things like that, will you still prefer using power meters when charging?
