Though not cheap I find this cool enough to have ordered one with tube, thanks.
Pre-Order placed for a Nichia S41s colored and colored 18650 tube.
I used their anniversary code 10annv11 and got an additional $0.99 off. Paid for my shipping insurance.
$51.03 USD
Someone should try 10annv99 and see if they get 99% off…. - tried, didn’t work. Also won’t give the $0.99 off for me anymore.
Ordered too… with 18650 tube. Comes to like $68 CAD with the 12% discount code 10annv12%.
I’m in trouble.
Ha!
Ordered standard SS Nichia + Tube
Thanks !!!
Preordered the plain SS nichias + tube.
Ta freeme!
Ordered!!! Woohoo
I asked the same thing earlier but no one responded. Is the XP-G3 6500K? Won’t that be a really WARM WHITE tint?
That’s cool white. 3-3500K is warm white.
Hi,
Ok, thanks. Are both the XP-G2 AND the XP-G3 cool white? Also, how “purplish” would those be?
Xpg3 is a newer iteration of LED, newer than xpg2. They are both available in warm, neutral or cool. 6500K is a colour temperature so I guess you could say it’s more purple then warm or neutral white.
You can’t really guess tint without a tint bin code (eg. 1A, 3B etc).
Why aren’t they telling us the tints for the emitters? Are we all just hoping that there’s no green tint? Or are you all planning to mod yours straight away?
I read that the green is caused by the AR lens. Sheeeessh…dunno
Both of 219B and XP-G3 have very similar tint at first glance, that was why I needed time to verify if they were indeed different emitters under the hoods.
I have to redo everything I shot yesterday because I shot them with grey background with did not turn out when warmer dim light setup. I have hard time looking for pure white wall, and I ended up using a large piece of acrylic sheet (reflective) for this purpose. As usual, this may not be 100% representative in their beam tint due to poor dynamic range in digital camera, post processing in JPEG and they are not accurately color corrected. I could only ensure they were shot in same environment and exactly same camera settings.
I will work on another group with them projecting against my color cards now.
Nichia looks brighter all round than XPG3, anyone else see that? Or just me?
They both seem to have that nice rosy tint
Wow!
I was expecting the tint of XP-G3 to look like the XPL-HI 1A if it is rated for 6500K.
Considering I already have XP-G2, 219B, 219C in triple or quad emitters, I might jump on the new XP-G3 as my S41 is already in 219B
Disregard the brightness for now as I am using the same battery for both lights without recharging. I did a quick tailcap current measurement a few days ago. Both lights also achieved fairly similar drained at 6.8A +/- 0.2A with NITECORE IMR18350. NC 219B has higher CRI than XP-G3 without doubts, result is quite visible with trained eyes.
Ordered SS and SS colored, tube for each, Nichia for each.
I already have a (newer, w/washers under the screws) Manker E14 with Nichias, all 4 LEDs have the same rose tint on moonlight setting and the beam is a pure, neutral white on higher settings. I agree with Freeme about the high-CRI of the Nichia emitters, it is very evident to me and I also have well-trained eyes (photographer and graphic designer, have calibrated many monitors, films, and applied color-correction professionally since the late 80s in print and digital). The color rendition of these emitters is absolutely stunning compared to any other constant-on hand-held artificial light source I have ever seen - I wouldn't hesitate to use this light in a pro setting for accurate color. It's that good.
Also - I have those same Nitecore 18350s as Freeme, and the new 3500ma Orbtronic 18650s (protected) are significantly brighter on turbo - the other settings look too similar to differentiate if they differ at all. Moonlight is moonlight, no matter what battery, as far as I can tell by eyesight alone. I have also tried "de" brand protected 18350s, and it would only flash (once, like a camera flash) trying to go into turbo, so protected 18350s may not work at all settings unless someone knows of a specific one that will.
Anyway, can't wait for the 2 new ones to get here! Thanks, Freeme!
Nice pic Freeme!
Both look like very nice tint.
Hi,
Thanks for the pics, but I thought someone said the 6500K was a CW? From the pics, the XP-G3 looks almost the same as the 219B?
EDIT: And the one on the leftmost is more of a CW, right?
If that’s the case, I’ll go with the XP-G3 since I don’t have any XP-G3 lights yet :)!
6500K is cool white. It should not look the same as Nichia 219B if that is the correct bin. Freeme can comment since he has the lights in hand.
