Very nice thread. Didn’t know it existed.
My last batch was not as worthwhile as past finds. Had 6 die on the charger and several red ones (no markings) generate too much heat to feel safe using, charging @ 0.5A. Have yet to check capacity of the survivors of this batch.
Previous batches were pretty successful with most rate over 2000mAh and 10+ up to 2700mAh.
Will certainly take notes from now on to see if there is info I can offer.
Have used and upgraded several items around the house.
Shark 20V hand vacuum
Portable O2Cool fan
Harborfreight 3W spotlight to 6 cell.
Just install a 5.5X2.1mm connector and use my balance charger on them.
New here but I pulled 6x Samsung ICR18650-26D 2600maH out of a Dell PT434 and it read 11.1v 56Wh manufactured Feb 2009
Is anyone else getting charged from their local bulk e-waste centers for these old laptop batteries by the pound? They told me they could sell it to me for $1.20 per pound because that’s what they sell it to scrappers for or so they say. This is the only e-waste center for at least 30 miles and majority of the corporations send their packs to them so they do have many newer ones. That breaks down to less than $1 per 6-cell pack. Is it worth it?
hp td09
9 samsung icr-18650-28a.
lilac.
btw a battery shop near me gives me tool and laptop packs.
they do not have a buyer for them in less than container loads.
and everyone there uses 18650 now.i make sure they have a lifetime supply and a good charger.
they even make sure that any battery device they buy can use 18650 natively or i can mod it to.
talk about spreading the disease!
hp mu06.
screwed controller.customer used 2 times then stored since mid 2013.reported design capacity of 3.8wh.
laptop gave bad battery nag but runtime good but would not recalibrate.
6 sanyo ur18650a 2200.red with white ring.
average 2280mah 70mohm.
HP HSTNN-CB1A ___ 6x SONY US18650GR 6F
HP HSTNN-OB2R ___ 6x LG LGDAS31865
HP HSTNN-OB51 ___ 6x SONY US18650GR 6F
HP HSTNN-OB88 ___ 6x SONY US18650GR 6F
i wound up with 300 6 cell aftermarket packs condaining dlg d18650.
they were all at 3.6x v and testing them at 1a all i tested were over 2200mah.
2 years later ones i have built into items are still fine.
these were new packs that had sat a while then brought for recycling by a business associate.
sold a lot to the flea market flashlight dealers at several large markets here.nothing but good reports.
masione outlet on ebay.
dell e64xx 6 cell “5200” mah
this was a dud pack.seller sent replacement and didnt want it back.
so teardown time!
lo and behold 6 +fp 18650 1800mah green cells.
testing them now but it appears 5200mah is a big fat lie!
edit.these cells are averaging 1811.
cells truthfully marked but pack capacity grossly overstated!
Hi guys can someone help me how to disassemble my defective xiaomi 16000mah powerbank to pull those 18650s inside and determine which one is still usefull. Can anyone share links for pics or videos. Thank you very much!
I pulled apart a HP HSTNN-LB89. Label was removed prior to me getting hold of it….
Contained 8x18650 cell - marked as ZD ICR18650 SY.
Nothing more……any idea of who makes these ? Only thing i can find online is ZD refering to Zhongdao…….
Any thoughts welcome - they are wrapped in a dark blue.
alienware 17 laptop would not charge.indicated no battery installed.replaced it and laptop is fine.
“92wh standard’.hole in one mosfet so something bad happened.
pack contained 8 lg e1 3200mah 4.35v cells.
they were all at 3.1v.
testing under way.
Hello BLF,
I have an Acer 1810TZ Notebook from 2009, and the Accu-Pack UM09E36 wont charge at Least, so i open it now, after i found this Thread. So i will Tell what i Found, for your List at Page 1.
I found 6 Cells and 4 Of them have 3,48V and 2 have 0V
The Pack was Ratet with 11,1V 5600mah
At the Wrap (Orange) from the Cell it stand Sanyo UR18650ZT N25A
The Internet say: Sanyo UR18650ZT 2800mAh (4,3V)
I have in December giftet my first 18650 Flashlight, so i dont have a Li-Ion Charger right now, i charge at the Moment in the Flashlight(s), so i cant say anything about the Rest Capacity. When i have buy a Charger, i test the cells and post it.
I don’t see the Dell 60Wh Type T54FJ in your table. It contains 6 X LGABC21865 4.35 volt 2800mAH cells. Here is a link to a post on them: Which laptop battery pack yields the best, highest capacity 18650's - #51 by Ansarogu - Rechargeable Batteries - BudgetLightForum.com I’ve gotten a couple packs of these for free from work. I guess charging to 4.2V they will be 2500mAH to 2600mAH and I’m ok with that for free! It sure beats the Crapfires. They come from Dell 6420 - 6430 laptops.
lygte-info.dk has a review of them titled LG 18650 C2 2800mAh (Orange) I cannot get a link to that review to work here for anything.
