Install a small diammeter star in a P60 host?
10 posts / 0 new
fran82
Last seen: 9 months 2 weeks ago
Hi folks.
Correct me if I am wrong. The default diammeter size in a P60 host for a LED star = 20mm. Yes or not?
Is there any problem about installing a 14 or 16mm star on a P60 pill? the reflector will continue pressing the star into the pill?
Thanks
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
brted
brted's picture
Last seen: 5 months 5 days ago
14's are pretty standard, but a 16 will usually fit. You just don't want to cover up the holes for the LED leads.
fran82
SO a P60 pill can acept maximun 20mm?
Nautic
Nautic's picture
Last seen: 2 years 3 months ago
No!  Its only 16 mm. 14 and 12 mm are OK, but have to be centered with the
help of heatsink compound. A 20mm star is to big.
Cheap quality is good - Expensive crap isn´t
Don
Don's picture
Last seen: 10 months 3 weeks ago
The two empty P60's i have here will not take any star of over 16mm diameter.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Budgeteer
Budgeteer's picture
Last seen: 7 years 11 months ago
All my dropins q5(defunct),r2,r5 are all mounted on 16mm stars. The only 20mm star was in my ex romisen RC-C8 twisty zoomie. A 16mm star is indeed better to aid aligning it properly. I use the goop fujik from dx. Not awesome but does the job. Be carefull as to not make it float in it. A small amount and hard pressed on the base is the best metod i believe since heatsinking leds can't be that different from CPU's, all in all it is the same principle, unfortunately there is nothing to keep pressure on the star.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
fran82
Understood 100%. Thanks to all for the confirmation
brted
brted's picture
The reflector screws down and bears on it usually in a P60. At least most of mine do, but they are really bearing on the solder where the leads connect to the star.
Budgeteer
Budgeteer's picture
Yap, thats correct. A nice rubber washer for plumbig but thin could be just the thing to put enough pressure and put just a smear of thermal glue underneath. That along with alu foil is actually all you can do to aid thermal transfer to p60 hosts.
Kokopelli
Kokopelli's picture
Last seen: 2 years 5 months ago
And that alu foil trick works really well Smile
