De-Doming the X6
55 posts / 0 new
scaru
scaru's picture
Last seen: 4 years 11 months ago
De-Doming the X6
A few people have asked about de-doming the X6 so here a how-to is. Smile
Start with the X6.
Then you unscrew the part that holds the reflector. This is not the bezel.
Then set aside everything except for this part.
Ok, so you should now see something like this.
There are many ways to do this part. I personally just used a pair of pliers but tweezers will also work. Some people use a knife to pry it up, but with the SST-90 I have found this to be the easiest.
Then you simply reassemble and check that it is still working.
It now has gone from 45kcd to 85kcd. If you want even more throw then you will need to do a driver swap.
Dale
Dale's picture
Last seen: 3 years 11 months ago
What is the down side to de-doming if any? Will it have any negative thermal effect??
scaru
scaru's picture
Thermally, no. However it will decrease the total lumen output but will make it throw further. Lemme see if I can find some numbers on lumen output.
scaru
scaru's picture
Ok, slewflash said it went from 1300 to 870 lumens.
FX-32
FX-32's picture
Last seen: 5 years 6 months ago
It still produces the same lumen output, but measuring doing the “ceiling bounce trick” is not the best way for throwers.
DarkSide
DarkSide's picture
Last seen: 4 years 2 months ago
Nice tutorial… I just received my replacement X6 and i have a 10A driver ready to go in. I didnt get a chance to see the difference with my previous X^ as i did the driver swap and de-domed the LED in the same tear down. Tearing off the dome in time for this evening…..after a Turkey Dinner
Happy Thanks Giving!!!!!
scaru
scaru's picture
FX-32 wrote:
It still produces the same lumen output, but measuring doing the "ceiling bounce trick" is not the best way for throwers.
The bare LED might but not when there is a reflector involved. Here my paint diagram is. Keep in mind each time the light hits something it will lose some light.
feilox
Last seen: 6 months 4 days ago
err just tweezers with no heating? Cuz I thought other methods like the solder iron or stove trick worked better?
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
scaru
scaru's picture
The SST-90 is really easy to de-dome.
rikr
rikr's picture
Wow, that was easy!!! And it did make a difference!!!! Man I was nervous… Thanks scaru!!!
 New Collection / Old Collection
feilox
Tempting but I’ll pass. I would like to see if you guys thought of any heat sinking ideas tho.
rikr
rikr's picture
I was really nervous, but it was so easy just grab and twist and pull up.. That’s all.. and a better brighter looking beam.
DENGOH
DENGOH's picture
Last seen: 2 years 5 days ago
Thanks for the post. I just got my X6 this weekend. Not modded yet.
Really bad quality for my X6. The lens are fogged and can’t be cleaned at all. I have to replace the lens with spare one, and incorrect o-rings size.
And the intentional mismatch of color of the body. It has two tone, dark grey and light grey. From the head, it is dark, light, dark,dark and light grey for the 5 main parts. What an ugly light, does anyone has this kind of intentional mismatch of body color tone on their X6?
The hotspot is ugly either if pointing at wall about 5 meter, there are irregular spill at the edge of the centre hotspot.
Really spoilt my expectation of Trustfire light, I have one X100, cosmetic wise it is perfect in all aspect if compare to this X6.
cool i'll see you when you get there
FX-32
FX-32's picture
DENGOH where did you buy it? I bought one about 18 months ago at DX and came in perfect condition, nice colour, the only con is the LED’s current at around 5Amps. The rest was OK.
DENGOH
DENGOH's picture
Will post later as I am contacting the seller to sort it out.
Feels like wasted money and should just get a SR95.
texaspyro
Last seen: 2 years 5 months ago
Fine steel wool and spit should clean it right up… not recommended for AR coated lenses.
Slewflash
Slewflash's picture
Last seen: 4 months 6 days ago
DENGOH wrote:
Will post later as I am contacting the seller to sort it out. Feels like wasted money and should just get a SR95.
Yup.
Slewflash
DENGOH
DENGOH's picture
The seller agreed to resend me those parts with light color as the heaviest heatsink has dark color, he will need to find the parts. Let’s see how it turns out. So I won’t publish where I got the X6 at this moment, but remember to ask for good or perfect color match if you purchase X6 next time. Looks like there are some process changed that affected this.
DENGOH
DENGOH's picture
Arghh! Almost did it last night, my pliers are 1mm away from the LED. Still struggling, do I need another thrower that can’t out throw TN31 or TK70? I am afraid it will fail or tint will shift to ugly tint.
rikr
rikr's picture
Here’s my X6 after DE-Doming it..
FX-32
FX-32's picture
rikr wrote:
DENGOH wrote:
Arghh! Almost did it last night, my pliers are 1mm away from the LED. Still struggling, do I need another thrower that can't out throw TN31 or TK70? I am afraid it will fail or tint will shift to ugly tint.
Here's my X6 after DE-Doming it.. !http://i873.photobucket.com/albums/ab299/Rickr1/RoundIIX6vsTN31vs7G5V200...!
Do you know the distance to the antenna?
rikr
rikr's picture
FX-32 wrote:
rikr wrote:
Here’s my X6 after DE-Doming it.. !http://i873.photobucket.com/albums/ab299/Rickr1/RoundIIX6vsTN31vs7G5V200...!
Nice!
Yep, sorry.. It’s 776’ feet 258 yards
DENGOH
DENGOH's picture
Definitely looks more focus than my X6 and tint is still ok to me. Does your X6 out throw TN31 or TK70? I read somewhere but can’t remember clearly that de-domed X6 still can’t out throw them.
rikr
rikr's picture
No it don’t but it does a pretty good job.. Here is a link to the beamshots I did, just scroll down to the pictures.
http://budgetlightforum.com/node/15540
nitro
nitro's picture
Where did u guys purchase the x6 at
rikr
rikr's picture
Here
http://www.aliexpress.com/store/product/Free-Shipping-Trustfire-X6-Flash...SST-90-LED-Flashlight-power-by-3×18650/610867_609433113.html
d337944
Last seen: 3 years 1 month ago
Or twist then pull up? What’s the purpose of the “twisting” action – seems like it may damage the bond wires?
I’m keen to give this a go but don’t want to destroy my prized possession just right now …
Cheers
DENGOH
DENGOH's picture
I read someone lift the dome up with sharp knife either. Looks like it is not very tightly glued at all.
But I haven’t dedome mine yet. Still waiting for the day it might happen when I suddenly have the urge to do it.
scaru
scaru's picture
The twisting doesn't hurt the bond wires because they are under a layer of gel or something. A sst-90 is much easier than an XM-L.
tatasal
Last seen: 2 hours 7 min ago
rikr wrote:
Here
Why the big price difference? Are they the same light?
Trustfire X6 SST-90 Luminus LED Flashlight Searchlight
(TX6)
US$159.99 http://www.hkequipment.net/index.php?r=9&p=1&cat0=1&cat1=54&s=d804e8f131...
d337944
scaru wrote:
The twisting doesn’t hurt the bond wires because they are under a layer of gel or something. A sst-90 is much easier than an XM-L.
Cool – thanks for the clarification mate!
Cheers
