Test / Review: UltraFire BRC32600 4000mAh 3.0V (Green-white)
Official specifications:
  • Voltage: 3.0V
  • Capacity: 4000mAh
  • No PCB protection board included
This is LiFePO4 batteries, this means they are 3.2 volt nominal voltage. This voltage is to low for a typical 1xLiIon flashlight.
The battery has a very flat discharge curve, where voltage depends on current draw, not on how much charge is left in the battery.
This type of battery does not have a protection circuit, because the chemistry is safer.
Conclusion
The performance is good for a cheap battery, but the capacity is overstated
Notes and links
Wow, I'm surprised it did so well at a 20 amp load. Thanks for the test HKJ!
The extremely flat voltage vs. time discharge curves really are impressive.
Thanks very much! Frontpage’d and Sticky’d.
