UltraFire BRC32600 4000mAh 3.0V (Green-white)
/DSC_1047.jpg)
Official specifications:
- Voltage: 3.0V
- Capacity: 4000mAh
- No PCB protection board included
/UltraFire%20BRC32600%204000mAh%203.0V%20(Green-white)-info.png)
This is LiFePO4 batteries, this means they are 3.2 volt nominal voltage. This voltage is to low for a typical 1xLiIon flashlight.
/DSC_1046.jpg)
/DSC_1049.jpg)
/DSC_1050.jpg)
/DSC_1051.jpg)
/DSC_1052.jpg)
/UltraFire%20BRC32600%204000mAh%203.0V%20(Green-white)-Capacity.png)
The battery has a very flat discharge curve, where voltage depends on current draw, not on how much charge is left in the battery.
/UltraFire%20BRC32600%204000mAh%203.0V%20(Green-white)-CapacityTimeHours.png)
/UltraFire%20BRC32600%204000mAh%203.0V%20(Green-white)-CapacityTime.png)
/UltraFire%20BRC32600%204000mAh%203.0V%20(Green-white)-Energy.png)
/UltraFire%20BRC32600%204000mAh%203.0V%20(Green-white)-PowerLoadTime.png)
/UltraFire%20BRC32600%204000mAh%203.0V%20(Green-white)-TripCurrent.png)
This type of battery does not have a protection circuit, because the chemistry is safer.
/UltraFire%20BRC32600%204000mAh%203.0V%20(Green-white)-Charge.png)
Conclusion
The performance is good for a cheap battery, but the capacity is overstated
Notes and links
