TK75 vs BTU Shocker - Let the battle begin! (NEW UPDATE ON POST 125)
198 posts / 0 new
Chicago X
Chicago X's picture
Last seen: 9 years 1 month ago
Now I have to buy a TK75.
Owning a device that can bend the fabric of space/time is worth whatever they charge.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Pedro2013
Last seen: 9 years 5 months ago
Smile Thanks for the review and information about the BTU Shocker vs the Fenix TK75. I ordered on last Friday and get it to morrow by DHL. Maybe Can I tell all of you more over the BTU after while using the flashlight. The BTU cost totally 152 USD with DHL shipping 4 business days or shorter. I read more review…. and very happy to chosed for BTU. It is the heaviest flashlight in the world! The is no problem for my. The TBT is bigger (biggest) for this moment. I liked it very mucht. Thanks for the review again. Someone likes Fenix TK75 and I like BTU Shocker no problem! You make your choice, so I did…. Have a nice time for everybody.
Shaquille
Shaquille's picture
Last seen: 11 months 1 week ago
welcome to blf pedro Smile
chiefinspectorfinch
chiefinspectorfinch's picture
Location: Croatia, country with kleptomaniac clero-fascist government
Well that was interesting to read… There is something that both “confronted” sides are missing. Look at this post http://budgetlightforum.com/node/10267 mere difference can be caused by different mcpcb between fenix and btu. I’m not familiar with driver/wiring of both but I think we can all agree that fenix has much more experience in that field and it’s driver is probably more efficient. On top of that optical losses are also major factor… I’m quite sure that both flashlights are brutal but there are differences in a way they achieve this.
Society is like a pot full of nuts and bolts, finest pieces always end up on the bottom...
rdrfronty
Ok guys, I decided to do some more extensive testing with both lights. This time I tested the lights, keeping them on turbo as best as I could, for almost 22 minutes. Both were tested simultaneously, alternating one and then the other on my lightbox. Also took temp reading after each lumen test. AND took a video of all of this.
Now some info before any data is listed. My meter was in the X10 mode, meaning every reading needs to multiplied by 10. And as I hope most know, every lightbox needs a baseline value to calculate that number by to get the true lumens. Or estimated lumens. That number is .50. And yes that sounds like an extra easy number, but I assure after testing about 60 lights, 2/3’s of them being ANSI rated, that number is VERY close to correct. If you don’t like or trust my meter or lightbox – go buy and make your own. I know my setup works well.
Also doing these like I did quickly putting the lights on and off, the numbers will be slightly off time to time. The foam gasket I use if not properly put in place can effect the numbers a percent or two. And if the lights are not centered and flat, the numbers can be off a percent or so. Especially with the BTU which is maxing out the glass shelf inside. When doing regular lumen tests I take more care putting these big lights in position. So basically keep this in mind if you see the numbers go up or down oddly from one reading to the other. I did about 20 readings on each light, but I’m only listing here about every 5 mins or so. You are welcome to watch the clip if you want to observe every reading.
So here we go -
———————————————————————- ——————BTU—————————TK75
1 min – 2860L (82F) ——2965L (83F)
5 min – 2755L (90F) ——2900L (98F)
10 min- 2695L (100F) —-2830L (118F)
15 min- 2605L (109F) —-2790L (128F)
20 min- 2465L (120F) —-2740L (132F)
So that’s the basic results. The BTU has a soft drop from turbo to high about every 3 min. Dropping roughly to 1900-2000L. The TK75 make a quick drop from turbo to high right at about 21 min. Went to roughly 1200 with the drop. You can easily see it when it drops.
Also did minor testing with the batteries, meaning before and after voltage.
Both sets of batteries were charged with i4 interllichargers.
BTU 3ea Keeppower 3400mah protected 18650
Voltage at start – 4.20V
Voltage at finish – 3.84V
TK75 4ea Panasonic 3100mah unprotected 18650
Voltage at finish – 3.91V
Should have done the same batteries for both lights, but we didn’t think about it until afterwards.
Now for the extra BTU testing. I decided to see what difference the plain glass lens made vs no lens at all. I was surprised with this one. The test was done after the big test, perhaps 10-15 min later. The light was still a little warm and the batteries were down at the slightly weak 3.84V range. Here is the result -
BTU with lens at 30sec – 2855otf
BTU with no lens at 30sec – 2970otf
So this light would certainly benefit from a UCL or AR lens. The stock one measures about 3.6”, but inside bezel measurement is 3.86”, so 3.75-3.80” would be about perfect. With a good UCL lens, cooled down, and fresh batteries, the BTU likely would put out better numbers than the TK75 at start. Though the TK holds its lumens better so would still likely catch it and pass it.
Well that’s all folks. I give the victory on this lumen and runtime test to the TK75. If you intend to run your light for 15 min. or longer at a time and want to keep the full 2500-3000 lumens, then the TK75 is likely the smarter choice. And it’s lighter weight will help prevent hand fatigue. However running the BTU on turbo for 5-10 mins and then a 2000L high until the batteries run out will still give you tons of light and more run time (then it kept on turbo).
With all the testing now and previously, I still prefer my BTU’s throw, UI, and heft. I fully respect the TK75 power and regulation. It’s a heck of a light.
Well guys here is the video clip if you feel like sitting through 22min of pretty boring clip. And remember we’re amateurs on this clip and VERY little talking is done.
Here we go -
-JOE-
-JOE-'s picture
Last seen: 4 months 1 week ago
Thanks for the testing, you did a very nice job.
The TK75 looks like an awesome light.
Shaquille
Shaquille's picture
Thanks fronty Smile for your precious time and patient in doing the tests.
 . so the lens is holding back a 100 lumens .its full of impurities. Better AR lens needed from Ric free of charge to all customers . Im changing mine to U3 and it should go above 3000 lumens at turbo
rdrfronty
With just a quality lens, fresh batteries, and a cool light, I’m confident ithe BTU will post a reading over 3000otf at 30sec.. Add U3’s or XM-L2’s will be gravy on top.
rdrfronty
No question there. The TK75 is an awesome light. Fenix did their homework on this one.
Slim Pickens
Slim Pickens's picture
Last seen: 1 day 21 hours ago
Thanks for the wicked detailed trial run on these lights Smile
Did you take any temp readings of the emitters? That + external temps reveal a lot about overall heatsinking effectiveness.
C-channel
C-channel's picture
Last seen: 2 years 4 months ago
What a great testing pal.
I believe both lights are winners. I think we won’t go wrong with both
How bright is bright enough...
Runtime VS Lumens...
Shaquille
Shaquille's picture
Yup im Adding U3’s asap .
rdrfronty
I didn’t do any at the emitters. Didn’t know if I could do that. Will these infrared guns work through the glass?
rdrfronty
I’ll likely leave my U2’s in there for now. If I upgrade, it will be a ways down the road and likely XM-L2’s.
I would like to do a UCL or AR lens swap. It was suppose to have that from the factory anyway.
relic38
relic38's picture
Last seen: 4 years 7 months ago
IR temp guns do not work through glass.
Thanks for the testing.
It looks like the BTU could use a little better thermal coupling to get the heat away from the emitters. A 400 lm drop is significant IMHO.
I’m thinking of doing 3x XM-L2 U2 on copper SinkPads in the future.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
rdrfronty
The IR temp gun thing is new for me. Never used them before and just got this one Saturday. Wanted to play it safe just in case one of the lights started getting very hot. Both did ok I think on temps. But yeah, looks like the TK does a better job of getting the heat away from the emitters. A 395L drop for the BTU vs 225L drop for the TK75. I still wonder if the drop was partially due to the driver trying to bring it down slowly to high. I think the drop figures about a 13.7% drop on the BTU and about 7.6% drop for the TK. The TK did very well for sure.
But I’m not too worried about it. I never intended to use the light for 20-30 min. anyway. I got it for fun. And if I want to use it for extended periods, I’ll just let it go naturally into a 2000L high and leave there. But I know now I can run it on turbo longer if needed.
Swap in XM-L2’s on copper sinkpads, along with a UCL – the BTU would be even more beastly then.
Dale
Dale's picture
I had XM-L2 U2’s installed… Had some resistor work done. It’s just under 4a on turbo… Really happy with it. ( btu )
DENGOH
DENGOH's picture
Last seen: 21 min 50 sec ago
Thank you rdrfronty for testing them out.
Your TK75 result match with runtime chart I have seen that output drop about 5% in 20 minutes Turbo mode. That is very good performance I would say.
No comment from me for BTU.
cool i'll see you when you get there
relic38
relic38's picture
I confirmed from preliminary testing that the driver current does drop during the first minute or so. It started out at 3.7A and dropped to 3.5A rather quickly (emitter current). Nothing huge, but it should contribute a bit to the fallout. I’ll be tweaking my output a bit to compensate, shooting for 3.8-4A on turbo.
Once I move to XM-L2 U2 on copper, I might bump it up closer to 4.5A (depends on output curves from XM-L2 when they are done). This driver seems to be comfortable with high current output.
Welcome the night.
ZT
Last seen: 7 years 10 months ago
Thank you for the performance analysis and the temperature / lumens statistics.
Was really looking forward to your report.
Now, for a ton of light and extended use, the BTU is good with a conservative 10 to 15 mins on turbo and the rest on high. This is a 2000 + lumens light all the way until battery failure. Now, with a little tinkering, the BTU is set up for an even greater performance and greatness.
In the flashlight universe, rarely does a torch delivers both – massive throw and flood of over 2000 lumens all the way. The BTU is a truly living testament to all discerning owners and lovers of led flashlights.
Great job RDR. I am certainly impressed.
rdrfronty
That slight current drop is good to know. Thanks for that little detail. So perhaps the light loses maybe 200 lumens or so due to heat and 200 lumens due to driver output dropping slightly.
relic38
relic38's picture
I think a 200mA reduction across three LEDs would be quite close to 150-200 OTF lumens of loss (around 50 or so per emitter). The rest is likely heat sag. Since the driver sage is quite quick, one could compensate by jumping up to 4A drive, which would fall back to 3.8A within a minute.
Welcome the night.
Shaquille
Shaquille's picture
so we all agree Ric Awes us a nice coated lens ??Laughing
rdrfronty
I’ve been hunting around for one without much luck yet. Found one company, but they have a minimum of 25.
It would be nice of Ric would upgrade us, but I’m not going to dwell on it.
Shaquille
Shaquille's picture
Shaquille]</p><p>[quote=rdrfronty wrote:
I've been hunting around for one without much luck yet. Found one company, but they have a minimum of 25. It would be nice of Ric would upgrade us, but I'm not going to dwell on it.
My U3 has been shipped by fasttech and my soldering iron is all sharpened up tinned and ready muahahahahaLaughing
I strongly suggest to stop using that fujic crap .scrap it out and use a thin coat of "silver thermal compound" or artic silver and similar cpu products .It will  greatly increase heat transfer from the emmiter
so heres my upgrade FOR MY BTU asap to beat the tk75 now
1- change over to U3 for higher lumens----AVAILABLE-
2- Remove all cheap fujic crap and use expensive silver thermal compound for better heat Transfer. ---AVAILABLE
3- change lens to ar coated lens -? ----NOT AVAILABLE--cant find ...hoping Ric has answer to this
applevalleyjoe
Last seen: 3 years 5 months ago
This has been and informative and very excellent thread. Thanks to all participants. Both of these lights have been on my short list for a while. I’m now thinking of going with the TK75 even though it’s $70 more .
Shaquille
Shaquille's picture
good choice Smile
InfinitusEquitas
InfinitusEquitas's picture
Last seen: 6 years 2 weeks ago
I was looking at getting a BS Terminator, but having seen the TK in action, this, and another review with the TN31mb, where the TK75 was the only semi-flooder to touch the target, went with the TK.
It's my most expensive light to date, and I couldn't be happier.  One of the three LEDs is a bit off center, but I don't think it's affecting much of anything.
applevalleyjoe
Has anyone upgraded their TK75 with the newer L2 led? Any report on its effect lumen wise?
rdrfronty
Shaquille]<p>[quote=Shaquille wrote:
rdrfronty wrote:
I’ve been hunting around for one without much luck yet. Found one company, but they have a minimum of 25. It would be nice of Ric would upgrade us, but I’m not going to dwell on it.
I strongly suggest to stop using that fujic crap .scrap it out and use a thin coat of “silver thermal compound” or artic silver and similar cpu products .It will  greatly increase heat transfer from the emmiter
1- change over to U3 for higher lumens——AVAILABLE
2- Remove all cheap fujic crap and use expensive silver thermal compound for better heat Transfer. —-AVAILABLE
3- change lens to ar coated lens -? ——NOT AVAILABLE—cant find …hoping Ric has answer to this
I have a possible source for a lens. Give me a few days to hopefully get mine in and to check fit & etc. If all is good then I’ll post up details on it for others looking.
