BTU Shocker - $99 Free Ship at FF
229 posts / 0 new
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 3 years 1 month ago
Guys,
I can personally tell you even at $120 shipped the BTU is still a steal. I just got done playing with mine again outside. Throw and spill like I have never ever seen before on any other LED light I have owned. And yes I have owned a TK70. The TK70 won’t touch the BTU I got.
Rusty Joe
Rusty Joe's picture
Last seen: 1 hour 35 min ago
I picked up a 3 lb dumbbell tonight to get an idea of what it would be like to carry this sucker. hehe
ohaya
Last seen: 3 years 5 months ago
Chidwack2 wrote:
Looks like the $99 deal is over. It’s now listed at $120.
Maybe try PM’ing RIC-CN?
I don’t know if the deal ended, but I had a problem ordering last night, and was getting a popup, and PM’ed him, and he responded after “fixing” the problem. I’m not sure what he did.
Slewflash
Slewflash's picture
Tom E wrote:
 Got a Shocker sitting at home, waiting – on a mini vaca now. It’s a BTU driver, planning on the resistor mod to crank of the amps (published already here on BLF), 20 gauge wires, XM-L2 on copper stars, copper braid all springs, etc. Hoping to see 4,000 lumens and 200 kcd out of it, or really close. This is close to the ultimate setup for this light because of the BTU driver and getting higher amps out of it.
This actually looks quite obtainable. Let’s look at the math:
Stock BTU is 3000 lumens, 135kcd. This equals 45 candela for every lumen.
Modded BTU with increased amps and lower resistance estimate is 4000 lumens, 200kcd. This equals 50 candela for every lumen.
What does this mean? Well, since there’s no actual change in shape between XML and XML2, if it did put out 4000 lumens, it theoretically would have roughly around 180kcd. Unless there’s some way you could change the ratio of throw to total output (by dedoming), to achieve 200kcd you would have to increase the lumens to 4444.
These are just rough calculations based on my calculated estimates. But if you could increase the amps to the LEDs I don’t see why it’s not possible, but 200kcd would require high current! Definitely over 4.5amps each emitter.
Slewflash
ILIKEFLASHLIGHTS
Well it’s a heavy light. But man what it does at nite to your backyard and your neighbors yard and their neighbors is unbelievable.
Tom E
Tom E's picture
Last seen: 4 hours 43 min ago
I already got 190+ kcd and 3,900+ lumens on a mod'ed DRY driver Shocker, so, really close, and I'm thinking my kcd measurements may be low because I'm measuring at only 4.3 meters. Also, general rule (from real, many upgrades) -- 20% increase in lumens means 40% increase in kcd - now don't ask me why, but it's proven in measurements done by me and rdrfronty. Also, this could be only for thrower designed lights, not sure.
Also, we are getting 180 kcd out of 3,600-3,700 lumens or so on the Shocker, again, measured by more than one person.
Slewflash
Slewflash's picture
I don’t understand the math behind your results. Unless there’s a difference in throw between XML and xml2.
Theoretically the ratio should stay the same.. Anyway, when are you going to make the but a 1km light? Smile
Slewflash
Tom E
Tom E's picture
Slewflash wrote:
I don't understand the math behind your results. Unless there's a difference in throw between XML and xml2. Theoretically the ratio should stay the same.. Anyway, when are you going to make the but a 1km light? :)
There's no math, just actual measured results. But, you have to consider what kcd is - it's very different from lumens (brightness, total light output). kcd is not distance directly, in fact if you double kcd, you don't double the distance, it's actually a lot less than double. It's  the measurement of brightness at one small measurable point, back computed to 1 meter. So many say 10% increase in lumens isn't noticeable, and 10% increase in kcd would be less noticeable because it's less than 5% increased in rated distance (632m to 663m for example, going from 100 kcd to 110 kcd).
Slewflash
Slewflash's picture
I realize that much, but what I’m thinking is:
If you have an XML and xml2 in two identical reflectors, and both had 800 lumens would the throw be the same?
If you don’t mod it, (and for arguments sake assume that my previous calculations were correct) and decrease the output from 3000 lumebs to say 1000 lumens, then the kcd would just be 45kcd… Right?
My entire reasoning is based on that premise. I will measure this next week to confirm, unless someone else volunteers (its a 2 min experiment).
Slewflash
doslyn
jamjar wrote:
My monthly commission cheque goes in tonight -is the only way I can buy stuff with out the wife catching on to how much I spend Smile
Hopefully there will be another sale down the track.
I bought one for $99 so I am sure it will be $79 soon.
Rusty Joe
Rusty Joe's picture
They are back up to $120 now.
Nightbird95
Nightbird95's picture
Last seen: 1 year 8 months ago
I hope that happens soon. Its back to $120 for now.
rdrfronty
My two personal examples of the XM-L2’s offering a higher percentage of Kcd vs lumens -
TN31 XML U2 – 1075 otf at 30sec – 122Kcd
TN31 XM-L2 U2 – 1275 otf at 30sec (18.6% increase in lumens) – 157Kcd (28.6% increase in throw)
BTU XMl U2 – 2975 otf at 30sec – 132Kcd
BTU XM-L2 U2 – 3670 otf at 30sec (23.3% increase in lumens) – 181Kcd (37.1% increase in throw)
All these were done with the same batteries and same meter before and after testing. Not sure why, but XM-L2’s to appear do be better throwers than XML’s.
Slewflash
Slewflash's picture
If you could get them to the same level of output, it would make calculating this a lot easier as the relationship between lumens and kcd is unknown.
Slewflash
bibihang
bibihang's picture
Last seen: 14 hours 32 min ago
XM-L has wires across the die, while the XM-L2 does not. Don’t know if this matter.
dazed1
dazed1's picture
Last seen: 11 months 2 weeks ago
I send them offer, for I4 v2 + BTU Shocker for 120, lets say if they agree Sad
Fenix TK61 MOD> resistor, transistors, copper heatsink, Artic Cooling MX4, dedome, 3A > 5.7A ~ 1700 lumens > (600.000cd)
ohaya
Hi,
Got email that mine is coming via Fedex – ordered on 6/8, and in Memphis, TN today, and scheduled for 6/19 arrival :)!
Should be an interesting week :)!
ILIKEFLASHLIGHTS
Your gonna love it.
Just wait until dark. And then go play. :bigsmile:
ohaya
ILIKEFLASHLIGHTS wrote:
Your gonna love it.
We have two of my nieces, with their families (7 in all) over this week. Should be an interesting Wednesday night :)!!
ILIKEFLASHLIGHTS
I was showing mine off all week. My son and daughters friends were amazed. It’s like turning on a streetlight in your backyard. Any light that smokes my TN31’s to me is pretty damn mean. This BTU is mean.
kelly1
Last seen: 7 months 2 weeks ago
Good idea!,training in preparation for ownership..now that is a sign of commitment Wink ..kelly
FMcamaroZ28
FMcamaroZ28's picture
Back again!
Now with XM-L2 and SINKPADS for $15 more!
kelly1
Awesome,well worth the extra
zeremefico
zeremefico's picture
Last seen: 11 min 24 sec ago
Is BTU shocker compared, anywhere in this forum, with SP03?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
PhatPhil
Last seen: 2 years 8 months ago
FMcamaroZ28 wrote:
Back again!
Ordered direct from Ric?
FMcamaroZ28
Yes. Same link as in the OP.
You click the selection boxes on the right.
http://www.fancyflashlights.com/goods.php?id=446
PhatPhil
Thanks Smile
dazed1
dazed1's picture
Trust me, the Shocker destroyes the SP03 in every possible aspect.
zeremefico
This was enough clear for me.
Gonna order one.
1B & DRY, right?
My YouTube channel
K40M F16
Slewflash
Slewflash's picture
Gonna order one.
1B & DRY, right?
That is the brightest possible option available, yes.
Slewflash
