Experiment MOD: Small Sun ZY-T13 with MT-G2 (now with beamshots and various measurements)
32 posts / 0 new
RaceR86
RaceR86's picture
Last seen: 5 years 10 months ago
28.07.203
-There was an issue with the analog voltage adjustment in my power supply, that explained my issues with it. Now that Im aware the issue, I can adjust it accordingly and that makes testing the driver easy. Some findings.
-If I “turn down” the trimpot the stock driver seems to output about 2,15A to an MT-G2. So quite similar to an XM-L in terms of output if using it stock.
-When the driver is adjusted for around 3,08A to an XM-L it will output around 3,3A to an MT-G2.
-If the driver is adjusted for say, 4A to an XM-L it will still only output around 3,3A to an MT-G2 with fresh NCR18650B batteries. If using (protected) 18650PD, ill get up to about 3,5A. Unprotected cells and optimized springs will probably get you a little higher.
-If input voltage are 9,14V I was able to output 4,1A to an MT-G2 if the trimput was adjusted for about high/max output. That was the max input voltage i tested it with.
-The driver can be adjusted for up toward 4,5-4,6A to an XM-L before it drops down to about 4,1A.
-The driver can be adjusted for up towards 5+A to an XP-G2 before it drops down to about 4,1A.
-The driver gets very hot if adjusted for max output.
-If the input voltage is down to about 7,1V, the driver will only output around 1,8amps to an MT-G2.
My conclusion based on this:
If you want 3A+ to an MT-G2 then that can be easily achieved with a simple resistor mod/trimpot. You might even see 3,7A+ amps with the right unprotected batteries and mods at startup.
Once input voltage starts to go down output will decline. Basically, it will not not stay well regulated with an MT-G2.
Driver does not seem to be well suited for 4,1+ amps to an XP-G2, XM-L, or MT-G2 when using a trimpot. (I don’t see how various resistors could do any difference.)
Driver can easily be adjusted for close to 4amps to an XP-G2 or XM-L. I can not comment on reliability.
I think an MT-G2 deserves at least 4++ amps. So I will not use it in this light.
26.07.2013 2nd update
Upping the juice?
Test setup. Used a power supply.
Earlier this was trimpot modded to 3+ amps to the emitter. I checked with XM-L, 2,98-3,17 amps to the emitter depending on input voltage from about 5-8,4. In this case, emitter current was higher when input voltage was less. Basically, XM-L + 2×18650 + that driver circuit = full output on high all the way til batteries are fully drained.
Same setup with MT-G2.. WHAT?? Where did my amps go? Yesteday I saw 3,29A when I tested it in the light and with same setup.
Put the light back together with the MT-G2. There they are. 3,24A at startup, that went quickly up to 3,3A with the MT-G2. I cant explain it, never seen it happen before, but for some reason it seems like this driver combined with my MT-G2 and my power supply is not a good combo?? Never seemed to have issues with MT-G2s and these types of currents before. On afterthought, maybe its the switch I used??? :~
Well, I wont let that stop me. Time to let the juices flow and crank up the trimpot! J) Ill just do the testing on the XM-L then.
4,59A seems to be about max for the driver circuit in my light, if I try to go higher Then it goes down to about 4,09. I set it to 4,5A first, but that seemed to be to close to the limit where it would easily go down to about 4,1A. I dialed it back to 4A. But depending on input current and how hot it was it was sometimes uptowards 4,1A. I dialed it down to about 3,8 -3,85A with the XM-L. Just in order to be “safe”. Not sure how safe the setup is though. Driver circuit still heats up fast!
Maybe that will give me 4A to the MT-G2 since the previous setup had higher output to the MT-G2?? 0:)
(re-use of picture). No gain was seen when testing on the MT-G2! Sad :~ :_( It was basically like it was before i tried to get higher current.
As far as I can tell based on all this, 3,3A seem to be about max output to an MT-G2 with this driver circuit.
Now I am seeing about 3,7A at the tail. I believe the resistor mod is currently pushed too far (for an MT-G2). Output to the emitter does not get higher with an MT-G2 , but input current seems higher. I believe it was considerably lower than 3,7A before I tried crank up the juices even more.
I should do more testing, especially some testing with lower input voltage. Generally 3 cells are recommended in order to drive an MT-G2 with constant high regulated output. Im not sure how much emitter current will drop when using this driver in combination with MT-G2. Maybe others will test it.
With my close to zero electronics skills I would say 3,3A is the limit to an MT-G2 with this driver circuit. If I decide to keep and MT-G2 in this light, Ill dial the trimpot several steps back. At the moment, I only have this one MT-G2, and I am working an a more exiting project for that emitter… J) 0:)
26.07.2013
Beamshots. White balance was set to auto, so differences in tints are not properly showed. These pictures are taken with wide angle (17mm on APS-C).
9 XM-L fandyfire. About 74 watt (with fresh batteries)
SRK, modded to 3A+ to the emitters and NW XM-L2 (80+ CRI). 30+Watt
ZY-T13 MT-G2 @ 3,29A. About 21 watt
UF-X6S, 5 amps to NW XM-L2 (80+ CRI) About 18 watt
ZY-T619 with 4A to a de-domed XM-L U2. About 14 watt
N-Light XT50 (aspheric zoom light), 3A to a de-domed XP-G2. About 10 watt.
25.07.2013
Some time back I modded my ZY-T13. I was inspired by this thread:
Modded: Small Sun ZY-T13 3.2 Amps or Sunwayman T40CS Clone.
I made this post. It was one of my first mods and my first thrower. I put on a trimpot (did not have any suitable resistors then) and used a crappy setup to adjust it to 3+ amps.
Later I put in and XM-L2 on copper…
Since then I have gotten several other throwers, and my ZY-T13 was not the best in terms of throw, tint, or anything. I was thinking about selling it.
Today I saw the CRELANT 7G5MT MT-G2 P0 NOCTIGON 2*18650 FLASHLIGHT.
And that got me thinking.. “I have one of those emitters” Smile
A little later…
I measured 3,29A on the emitter.
Ill get back to beamshots and such. I have barely used the light, but based on first impression I like it better, it has much less throw, but it puts out a lot more light. Beam is nice too.
I need to make the pill nicer though, because its not 100% flat and had a tiny dot of aluminium sticking up in the middle.
Anyone know how much further this driver circuit can be pushed? 0:)
I need to do various testing, more updates to come..
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Edited by: RaceR86 on 07/29/2013 - 00:06
eebowler
eebowler's picture
Last seen: 1 week 2 days ago
I’m curious, which driver is it? (Really excited to see beamshots!)
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
RaceR86
RaceR86's picture
Stock driver (modded with trimpot and adjusted from about 2 amps to 3+)
Beamshots and comparison with a few other lights will come within a few days, don’t expect anything extreme. Its “only” running 3,3 amps…
ImA4Wheelr
Last seen: 4 months 6 days ago
I say Push It, Push It Real Good. Sorry, for some reason that stupid song came to mind. I don’t know the answer, but I hope a lot. It’s just such a convenient mod. Well maybe not. I imagine that reflector is hard to clear. Do you have a build thread for copper xml2 mod?
RaceR86
RaceR86's picture
Normally I would push it real good, but this is a driver circuit that I would prefer not to destroy due to not having any good replacement that seems to be on level with the stock driver (in terms of UI). Or maybe someone know of some good options in case I should mess it up if aiming for 4++ amps?
Here is a little post about the XM-L2 change. Nothing special. It does not show the plastic insulator I cut and used over the wires though.
At the moment, Im just using kapton tape under the reflector where there is a risk that the wires could touch. Its thinner than the plastic insulator stuff so I often use that instead.
bdiddle
Last seen: 2 weeks 1 day ago
Are those amps emitter or tail cap?
I have ~2.3 amps tail cap on mine to an XP-G2
Newb
relic38
relic38's picture
Last seen: 4 years 3 weeks ago
Nice mod!
Pushing 3A into an MT-G2 will get you close to 1500 lumens OTF, I’d guess. Based on my results with the ZY-T08. That’s a nice mod, and someone (garrybunk I think) was just asking about this host/emitter combo.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
RaceR86
RaceR86's picture
Not a huge difference between emitter and tail though when using the MT-G2.
Thanks for the info! Smile
If you have 2,3 on the tail, then you have modded it for roughly 4,6A to the emitter when using an XP-G2. If so, that is the furthest I have read someone have pushed the stock driver circuit (you have modded the stock driver circuit right?), and way higher than Im at now.
If so, I have a feeling it should be able to do that current to an MT-G2 as well then… 0:)
ohaya
Last seen: 3 weeks 10 hours ago
Hi,
I was wondering – will the stock ZY-T13 driver output 6V (for the MT-G2) then?
RaceR86
RaceR86's picture
ohaya wrote:
Hi,
yupp!
ryansoh3
ryansoh3's picture
Last seen: 1 month 1 week ago
Very nice, thanks for sharing!
The MT-G2 looks like a nice fresh egg yolk. Smile
BLF ≠ B-grade Flashlight Forum
ImA4Wheelr
Thanks R86. I totally understand. That driver would be hard to replace. Best wishes on your endeavor.
bdiddle
I have not measured led current, so I am guessing 4 amps max after losses. Or less.
Newb
MRsDNF
MRsDNF's picture
Last seen: 5 months 6 days ago
Nice mod RaceR86. Is the reflector in this light identical to the HD2010. From memory the internal reflector measurement is 53mm. The reflector in the Small Sun ZY-T621 is identical to the HD2010 and one day I was planning om modding it to MTG-2. Just got to much other stuff on.
garrybunk
garrybunk's picture
Very cool! I want to do this (some day)!  Will that trimpot work FTP adjust to 4.0A output?
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
ohaya
Looking at this post in the other thread:
http://budgetlightforum.com/node/11830#comment-206682
he just shorted the outer resistor and got 4.8 amps.
So, how would this work if you just took a stock light, replaced the emitter with an MT-G2, and shorted that one resistor? Would that be ok?
ImA4Wheelr
I’m pretty sure that the HD2010 and ZY-T08/T13 reflectors are different. I’m going off memory. I have a particularly painful one of grinding through into the finished side when trying to clear wires in the HD2010. The beam profile is a little different too. The HD2010 has a bigger hotspot and more friendly to use in midrange.
RaceR86
RaceR86's picture
-Garry
Im not sure how far the trimpot will let it go in terms of output. Ill get back to you if I find out.. Could always use resistors though. I normally use resistors.
Based on what I have seen with this driver and an XM-L it seems like LED current are pretty equal to tail cap current x 2.
But if you are seeing 2,3A at the tail with and XP-G2, then that seems promising in terms of what the driver can handle.
Ill take beamshots with the setup I have right now (MT-G2 at 3,29A), then I might be tempted crank up the lumens! J)
bdiddle
Of all the cheap drivers I have looked at, the T13 driver seams built to stand the most current. I need to try driving one with a dedomed XML2…..
Newb
garrybunk
garrybunk's picture
Crank it up man! Gotta at least push 4A through it! And definitely report back on heat management. (I just noticed "FTP" in my last post - stupid iPhone autocorrections even though the word was typed correctly!)
-Garry
ohaya
Bumping my own post (sorry), but doesn anyone know the answer to the above?
RaceR86
RaceR86's picture
Ohoya, I can not answer your question direcly, maybe others will, but you may find my various measurements with this driver interesting.
Lots of info have been added to the OP! Various beamshots too! Smile
ohaya
RaceR86 wrote:
Ohoya, I can not answer your question direcly, maybe others will, but you may find my various measurements with this driver interesting. Lots of info have been added to the OP! Various beamshots too! Smile
Hi,
Ok, thanks, I understand. FYI, the reason for my question is that I’m interested in trying this light and the MT-G2 but with increasing the current, but don’t have a trimpot, so was trying to take the “easy way out”.
RaceR86
RaceR86's picture
ohaya wrote:
Hi,
Unless/until someone with more electronics knowledge finds an easier or better solution I would say don’t bother if extreme output is your goal.
For those who are happy with a budget alternative to the 100$ CRELANT 7G5MT MT-G2, this light is a good option.
But people should ask themselves, is it worth modding the ZY-T13 when you have other lights out there like the King, KUNG, Warrior, M6 etc etc that can be modded too.
If you like the form factor it might be worth it…
ImA4Wheelr
Thank you R86 for all the hard work and reporting. Very informative.
So I guess one easy solution (should one want to go MGT2 and high current in this host) would be to just go direct drive. Save the fairly unique driver and use a contact board in its place. Not sure if the tail switch could take 7 or so amps though.
garrybunk
garrybunk's picture
Thanks RaceR86! So perhaps a Dry driver is in order for this light?
-Garry
ohaya
RaceR86 wrote:
ohaya wrote:
Hi,
The reason that I’m interested in this is not so much achieving high current, but I am interested in easy way to get an MT-G2 light that has “good” throw.
Have you, or anyone else, measured the lux with the resistor mod(s)?
RaceR86
RaceR86's picture
No, I don’t have a lux meter, but as you can see from the beamshots its not really a serious thrower in anyway. If it had 5 amps to the emitter (30+ watt) I suspect it would be more impressive and would very easily and clearly outthrow a 30+Watt SRK.. The beam is more of a large hotspot “thrower” with good spill. In order to get more throw, it needs lots of current. The stock driver circuit in the ZY-T13 does not seem to be able to do that (At least not by the typical resistor tweaking).
I believe there is no such thing as an easy way to get an MT-G2 to have good throw without having a very high amount of amps combined with a large reflector. Unless you are using an aspheric.
If you want good throw with less watts, then stick to hard driven XM-Ls. Or several smaller emitters.
There are a bunch of alternatives to an MT-G if you are looking for good throw and high output.
Just to name a few that could be good options.
5 XP-E2s in a SRK sized 5 emitter reflector.
3 XP-G2s in a SRK type reflector.
3 de-domed XM-L2s in a SRK type type reflector.
I suspect those three options could be somewhat similar to an MT-G2. But you have advantages with a more compact reflector/light. The advantage of using various types of AMC7135 based drivers. You also get more tint options, and also the ability to mix emitters. Ill be testing options like that in the future.
relic38
relic38's picture
The T08 is not a thrower at 5Amps, IIRC, about 25-30kcd. The T13 should be similar.
However, that throw is in a hotspot about three times the diameter of the original T08. Very useful for broad searching close range.
Using a trimPot would only be useful if you intend to adjust the current. If you are going for max, then short out the sense resistor and hope the driver can handle direct drive. Based on my experience, if the emitter is on a Noctigon and making decent heatsink contact, 2×18650 cannot kill an MT-G2. I tried with two Pana 18650PDs, nothing but 20ga wire and a 25 milliohm ammeter, and got 7A.
That’s a long way from the 16A that djozz pumped through one trying (and failing) to kill it.
Now, 7A (~45W) in a flashlight gets mighty toasty in short order, so maybe avoid tailstanding and walking away Wink
Welcome the night.
RaceR86
RaceR86's picture
Updated OP.
Latest update on the top. That post is starting to become fairly long and messy now… But I think im done with this MT-G2 project now.
Garry, Im not familiar with how a DRY driver works in combination with MT-G2 and 2-cells. I assume it would work quite nicely in terms of output, and I could be fitted in the light. But you would loose the UI of the ZY-T13, and to me, that is some of what I like about this light.
You can easily use the ZY-T13 for an MT-G2, but if very high output is your goal, then I would say there are better suited hosts out there if you want a 2-cell thrower style light.
Relic38, I agree. Its no thrower and probably very similar to the ZY-T08.
Ill pass on shorting the resistor, I don’t want to risk killing the driver any more than I have already pushed it. It does not seem to want to output much more than 4 amps to any emitter as far as I can see.
Just a queastion, Im I right in assuming that the ZY-T08 with MT-G2 at 5A will +slightly+out-throw a SRK modded to 2,8A to each emitter? Both of those should have around 30W of power.
What I do like about the ZY-T13 with MT-G2 is the useful beam for what I would consider close to mid-range.
But personally I can not justify putting an MT-G2 in it and only running it at 3++ amps max. That makes it too similar to a modded TR-3T6.
relic38
relic38's picture
My SRK is no where near stock anymore (3xXM-L2 U2 2.8A/emitter), and it reaches 33.4kcd. The ZY-T08 MT-G2/DRY driver at 5A hits 39kcd.
So yes, a slight advantage to the ZY-T08.
I agree, there’s not much point in doing this mod without pushing it to 5A territory. The output becomes typical and can be reached with a very hard driven XM-L2 U2 and at the same time get waay better throw.
Welcome the night.
